POV-Ray : Newsgroups : povray.general : Serializing a dictionary Server Time
7 Oct 2025 00:31:48 EDT (-0400)
  Serializing a dictionary (Message 1 to 10 of 17)
Subject: Serializing a dictionary
Date: 5 Jul 2025 21:42:26
Message: <6869d482$1@news.povray.org>
I have a dictionary in 3.8 and one of the elements is an array.
I'm trying to write the definitions out to a text file:
#macro WriteTileSet(fname)
   #fopen TILE fname write
   #for(I, 0, MaxEntropy-1, 1)
     #write (TILE, "#declare TileSet[", S(I), "] = dictionary {\n")
     #write (TILE, "  .name = ", TileSet[I].name, ";\n")
     #write (TILE, "  .edges = array[", S(TileEdges),"] {"
     #for(E, 0, TileEdges-1, 1)
       #write (TILE, TileSet[I].edges[E], ", ")
     #write (TILE, "};\n")
     #write (TILE, "  .pidx = ", S(TileSet[I].pidx),";\n")
     #write (TILE, "  .rot = ", S(TileSet[I].rot), ";\n")
     #write (TILE, "}\n"
   #end // for I
   #fclose TILE
And I'm getting an error:
Parse Error: Can't nest directives accessing the same file.
Is there a way around this? I don't want to have to manually write each
element out.
I think it requires another macro to convert the .edges element to a
string that I can then slap into the #write directive. Is this the only
way or am I missing something?
Uncle Josh
Josh
Subject: Re: Serializing a dictionary
Date: 6 Jul 2025 00:10:00
Message: <web.6869f5bde086e5d13ecaab5e6cde94f1@news.povray.org>
hi,
> element out.
I've been looking at (un)serialising dictionaries using my 'Filed()' macro[*],
and have not yet found a "good way" for dealing with arrays, especially
multi-dimensional.  I think converting the array to a string, and storing that,
will work, eg "3.1415:1.23:0.1" for an array of three floats; have a look at my
'strSplit()' macro[**] for the unserialising.
[*] <wiki.povray.org/content/User:Jr>
[**] <news.povray.org/web.64b08576d08f3556b49d80446cde94f1%40news.povray.org>
regards, jr.
Date: 6 Jul 2025 01:47:39
Message: <686a0dfb$1@news.povray.org>
You are missing a couple of closing parens.
     #write (TILE, "  .edges = array[", S(TileEdges),"] {"    // <--
     #write (TILE, "}\n"                                      // <---
   #end // for I
   #fclose TILE
The parser is seeing another #write directive start, while being in the
middle of parsing a prior #write directive. As long as the .edges
element is a string, you should be on your way after adding the closing
parens.
Bill P.
Date: 6 Jul 2025 15:48:47
Message: <686ad31f$1@news.povray.org>
> Bill P.
AAARGH! Thank you. Yeah, that was the problem (and the missing quotation
marks in the resulting text file).
I wish the Windows UI had a better way to tell me where the errors
actually are. I make mistakes like this and it fails in some other part
of the code.
I want to build a linter for POV-Ray some day, maybe that will help.
Thank you again.
Josh
Date: 6 Jul 2025 15:51:00
Message: <686ad3a4$1@news.povray.org>
On 7/5/2025 9:05 PM, jr wrote:
> hi,
>> element out.
> regards, jr.
I'll look into it. I've found it's generally easier just to build an
include file that can be imported later than trying to manage
customizing serialization.
Now if POV-Ray 4.0 could read and write JSON or XML, I'd be in heaven,
but I don't think that's in the plans.
Uncle Josh
Date: 7 Jul 2025 10:30:00
Message: <web.686bd980e086e5d1f625f77c25979125@news.povray.org>
> of the code.
So, this is a common problem, with start and end bracketing "directives" or
whatever we call them
#if #end
#while #end
texture {     }
function {     }
etc
I use large (5-space) TABS to maximize the visual placing of the start and end
of my code blocks.
I have also (mostly) trained myself to type the opening AND closing parts first,
and then fill in the space between.
On top of that, if I'm not being lazy, I specifically comment my closing
directive to match the opening one.  I will number or name nested code blocks.
"Outer", "Middle", "Inner"
"#if 1", "#if 2", "#if 3"
I wrote a bunch of macros to help keep track of where in the hierarchy I am when
my code craps out.
Maybe someone can suggest a command-line script to grep opening and closing
parentheses and give a count.
Might be able to paste it into a spreadsheet and get a count that way.
- BE
Date: 7 Jul 2025 11:45:00
Message: <web.686bea5ce086e5d13ecaab5e6cde94f1@news.povray.org>
hi,
very good practice/advice.  fwiw, a suitable editor helps, for instance using
'vim' makes jumping between opening and closing brace/parenthesis/bracket a
single (shifted) key press.
not totally what you're after, you only get the line count of occurrence, but,
in practice, the opening/closing counts should be the same.  (no time to write a
script, sorry :-))
  $ grep -ce '[{]' myscene.pov
  $ grep -ce '[}]' myscene.pov
do you use 'sc(1)' ?
regards, jr.
Date: 7 Jul 2025 12:45:00
Message: <web.686bf940e086e5d13ecaab5e6cde94f1@news.povray.org>
> not totally what you're after, ...(no time to write a script, sorry :-))
no script, but a (simple) re-purposed program (named "brace parenthesis bracket
counts"), attached.  compile with:
  $ gcc -std=c99 -O2 -o bpbcounts bpbcounts.c
(sorry, no spreadsheet importer :-))
enjoy, jr.
Download 'bpbcounts.c.txt' (2 KB)
Date: 8 Jul 2025 04:08:56
Message: <686cd218$1@news.povray.org>
> enjoy, jr.
A long time ago, I started doing the same thing (but in Perl). I stopped
because I got stuck on a problem: even if the number of pairs is
correct, the syntax isn't necessarily right. You could be missing a
brace in one place and have one too many in another. All in all, the
count is good, but the syntax is not.
But indeed, this kind of script already gives good indications.
kurtz le pirate
compagnie de la banquise
Download 'analyser.pl.zip' (3 KB)
Date: 9 Jul 2025 00:41:01
Message: <686df2dd$1@news.povray.org>
> #if #end
> #while #end
> texture {     }
> function {     }
> etc
> of my code blocks.
Yeah, I should get into that practice. I don't do that in any other
language, though, so I suspect an uphill battle.
I might be able to scribble out some Python to do that, come to think of it.
Uncle Josh
