POV-Ray : Newsgroups : povray.general : Some more image to POV stuff in exchange for a good name Server Time
13 Jul 2025 15:08:52 EDT (-0400)
  Some more image to POV stuff in exchange for a good name (Message 10 to 19 of 19)
<<< Previous 9 Messages Goto Initial 10 Messages
Subject: Re: Some more image to POV stuff in exchange for a good name
Date: 24 Dec 2024 12:35:00
Message: <web.676af04ab095aa55d97b426e25979125@news.povray.org>
Ilya Razmanov <ily### [at] gmailcom> wrote:
> Hm, I've seen "Input_File_Name" in "Command-Line and INI-File Options",
> and I always assumed that all this work only with ini and stuff.
It does not control anything.  It's a defined identifier.
> So, it works within scene as well? Where can I learn more about this
> (beside thin NG, I mean.
Always the WIKI:
https://wiki.povray.org/content/Reference:Strings
It also looks like
the link for input_file_name at
https://wiki.povray.org/content/Reference:Keywords
is supposed to have a reference to this keyword - but doesn't.
> Surely I ask questions here sometimes, but
> still I understand that teaching me POVRay is not the main reason for
> this NG existence)?
No way.  Our time machine was invented just to go back and make it all for you!
We all are learners being taught, and become teachers of our own little areas of
experience and expertise.
> There are ways to control stuff from the scene that
> are normally controlled from ini?
.. . . sort of.
If you look at the way the sample scenes get automagically generated from a
script, the script is actually doing the controlling, but it uses the image
sizes that it reads from within the scene file.
Also, if you look up my self-including include file, then you might invent a way
 to parse values in the scene, (over)write to the file, and then include it
again....
You might be able to (re)write the resolution.ini file, or something - but I
think POV-Ray generally doesn't allow for potentially malicious coding exploits.
- BW
Date: 26 Dec 2024 04:00:18
Message: <676d1b22$1@news.povray.org>
Well, as major Kaprov said, "if I did something wrong please report and
then I will be thinking". I guess I will follow this old army procedure
and be thinking :-)
Don't worry, I'm famous for my capabilities to send PC into an infinite
loop, filling all the memory. That's what recursions (see "Recursions")
are invented for.
Ilyich the Toad
https://dnyarri.github.io/
Date: 27 Dec 2024 06:30:02
Message: <676e8fba$1@news.povray.org>
Ok, I just discovered #ifndef which makes it easy to have defaults in
.inc yet override them with .pov stub.
Dementia is great decease - no pain, and you learn something new every
day! (c) local saying
Ilyich the Toad
Date: 3 Jan 2025 10:38:25
Message: <67780471$1@news.povray.org>
On 24.12.2024 18:03, Bald Eagle wrote:
> So what you do is this:
> #if (input_file_name = "MySceneFile.inc")
>     Camera
>     Lights
>     whatever else
> #end
> Then rest of your scene is _just_ the include file.
Well, don't quite like this solution since it's not immune to simple
file rename. But I started to think (yes, following comrade major
scheme) and eventually and inevitably came to conclusion that
#declare extension = substr(input_file_name, strlen(input_file_name) - 3, 4)
#debug extension
shows me
.pov
and even subsequent
#if (extension = ".pov")
   #debug "Match!\n"
says "Match!"
Combining it with your suggestion, I guess I can produce files that work
as a whole scene when they are .pov, and as include after renaming to .inc
But this is not confirmed experimentally yet ;-)
Ilyich the Toad
Date: 3 Jan 2025 10:55:00
Message: <web.677807f5b095aa55327467e125979125@news.povray.org>
> file rename.
It ought to be.
Write a tiny .pov file that outputs the value of input_file_name to the debug
stream.   Rename the file.  Render it again.
Since you're opening the file as the main .pov file, that's what input_file_name
gets defined as.
If you write another .pov file that INCLUDES the first .pov file, then it's the
main file that gets its filename assigned to input_file_name.
That's why this ought to be a good solution for you.
Just try it - you'll see.
- BW
Date: 3 Jan 2025 11:28:37
Message: <67781035$1@news.povray.org>
Yep, already tried my idea with extensions out - oops, it seems like
.inc file gets extension from master file, which is .pov, so my idea
with extensions doesn't work. Guess it was just too beautiful for this
world...
Ilyich the Toad
Date: 3 Jan 2025 12:42:47
Message: <67782197$1@news.povray.org>
...on the other hand, I still may use extension trick to make
self-rendering .inc as you suggested, but reacting to extension only
rather that a whole file name...
Ilyich the Toad
Date: 3 Jan 2025 14:45:00
Message: <web.67783d99b095aa5536bcdbf3f712fc00@news.povray.org>
> Found it.
https://news.povray.org/povray.general/message/%3CXnsAC0E5196CA622seed7%40news.povray.org%3E/#%3CXnsAC0E5196CA622seed
7%
>    Camera
>    Lights
>    whatever else
> #end
> That way, if you're including your file in another file, it doesn't run the
> extra scene setup code.
> But if you're running it as a standalone file, you obviously need the scene
> setup stuff to render anything - and so it's all right there.
> - BW
That works alright. But, I've use this for a long time
#ifndef(Get)
 do what ever
Then define 'Get' in the calling file. This works even if you change the name of
 the inc file. Which I do often when I'm testing ideas.
I really should use the 'input_file_name' test more.
Have fun!
Date: 3 Jan 2025 16:19:01
Message: <67785445$1@news.povray.org>
> #ifndef(Get)
>   do what ever
> #end
LOL. That's too simple to think of it ;-)))
Ilyich the Toad
Date: 3 Jan 2025 16:28:35
Message: <67785683@news.povray.org>
>> #ifndef(Get)
>>   do what ever
>> #end
The includes from the distribution use a trick like that.
#ifndef(Flag)
#declare Flag=version;
  do include stuff
This prevent parsing the include multiple times if it get formally
included and included by another include.
