POV-Ray : Newsgroups : povray.general : #switch #case in function? Server Time
2 Aug 2024 18:12:01 EDT (-0400)
  #switch #case in function? (Message 3 to 12 of 12)
<<< Previous 2 Messages Goto Initial 10 Messages
Subject: Re: #switch #case in function?
Date: 16 Jun 2024 07:45:00
Message: <web.666ecfaebf6d15f1869a24876cde94f1@news.povray.org>
hi,
Ilya Razmanov <ily### [at] gmailcom> wrote:
> Yet another stupid question from me: can I use "case" operator withing
> function? I can't figure it out.
you can use the 'select' function from within your 'function {}', but I think
that's as good as it gets.  BE and or WFP are the people with the "function
nous".
<https://wiki.povray.org/content/Reference:Numeric_Expressions#Functions>
regards, jr.
Date: 16 Jun 2024 19:46:45
Message: <666f7965@news.povray.org>
Well... technically it is possible use #switch #case in a function
definition, but it will be evaluated only at parse time, freezing the
function definition at whatever the parse state was at that point.  This
is not generally useful.
So, do as Bill and Jr say: use select().  (I had to find this out the
hard way.)
Date: 17 Jun 2024 05:19:28
Message: <666fffa0$1@news.povray.org>
On 16.06.2024 14:37, Bald Eagle wrote:
> I've done various versions of your Boolean product approach, but most often, it
> just comes down to using nested select () statements.
> Just think of them as #if - (then) - #else statements and it will all make
> sense.
I'm trying to think but nothing happens (on the other side, this is, at
least, reproducible, and I like reproducibility).
> That way you can also have plenty of #debug statements and whatever else you
Don't tell me about debug messages, it's too tempting. There is nothing
I like more than making my programs say something stupid to the user.
Nobody know but my programs are full of stupid sayings, like buttons
"Allons-y!", "As you were!" and "Dismissed!". Nobody knows it because
they are redefined at runtime to something human-friendly like "Ok" and
"Cancel".
Well, anyway, I stepped onto weird artifacts with continuous
nonmonotonous functions already, which guarantees keeping me busy. "She
had no problems, therefore she bought a pig" (c) local proverb
Ilyich the Toad
https://dnyarri.github.io/
Date: 17 Jun 2024 05:57:29
Message: <66700889$1@news.povray.org>
I definitely want it to change between objects, and even worse, between
triangle angles.
Okey then, seems like I'd better try to do something reasonable with my
boolean*float + boolean*float switches at this time.
Ilyich the Toad
Subject: Using splines to map arbitrary value (was Re: #switch #case in function?)
Date: 17 Jun 2024 23:27:05
Message: <6670fe89$1@news.povray.org>
Ok, since my previous silly question was about piecewise functions
rather than #switch per se (that is, case was supposed to be used to
make function piecewise), I think I'll publish a solution for initial
problem here, although it's not directly related to #switch.
Initially, I wanted piecewise linear function, as most simple to edit.
Resulting solution looks somewhat like this:
#declare scl = function(c, lin, hin, lout, hout) {
     (c-lin)/(hin-lin) * (hout-lout) + lout
   }  // Linear rescale function from lin..hin to lout..hout range
#declare map_4 = function(c) {      // Piecewise rescaling example start
   (c <= 0.7) * scl(c, 0, 0.7, 0,1)  // rescale 0-0.7 to 0-1
   + (c > 0.7 & c <= 0.9) * scl(c, 0.7, 0.9, 1, 0.5)  // rescale 0.7-0.9
to 1-0.5
   + (c > 0.9) * scl(c, 0.9, 1, 0.5, 1)  // rescale 0.9-1 to 0.5-1
   }  // Piecewise example end
yes, I managed to overcome my laziness and pack rescaling into separate
scl function with simplified syntaxis.
But later I realized (yes, good ideas always come to me later) that
piecewise interpolation is somewhere in POVRay already. For example, in
splines. After a long attempts to understand what's written in manual I
came up with the following:
#declare interpol = function {
   spline {
     linear_spline
     0.0, <0.0,0,0>
     0.7, <1.0,0,0>
     0.9, <0.5,0,0>
     1.0, <1.0,0,0>
#declare map_5 = function(c) {interpol(c).u}
and well, map_5 seem to give the same result as map_4 above, while being
much easier to edit.
Surely, all this is too simple and obvious for people here, but well, at
least next time I need interpolation, I can find it in this NG archives :-)
Ilyich the Toad
Subject: Re: Using splines to map arbitrary value (was Re: #switch #case infunction?)
Date: 18 Jun 2024 09:31:14
Message: <66718c22$1@news.povray.org>
Thanks for posting your solution. It's good to be reminded of useful
approaches to need.
On your original question about #switch inside a function{} block, I saw
your switch by multiplication as good as anything else for clarity. As
others said, using select()s is the more common function{} block switch
alternative.
It is perhaps useful to add that there is a performance trade-off
between the two approaches. The select()s are often faster, though it
depends some on the details.
Bill P.
// Example requires the yuqk fork for f_boom() which throws after
// printing six values. It's a user function debugging aid.
#include "functions.inc"
#declare Fn_switch =
     function (_V,_Default) {
         select(-(_V=1),f_boom(1,0,0,0,0,0),
         select(-(_V=2),f_boom(2,0,0,0,0,0),
         select(-(_V=3),f_boom(3,0,0,0,0,0),
         select(-(_V=4),f_boom(4,0,0,0,0,0),
             _Default)
#declare Fn_switchByMult =
         (_V=1)*f_boom(1,0,0,0,0,0) +
         (_V=2)*f_boom(2,0,0,0,0,0) +
         (_V=3)*f_boom(3,0,0,0,0,0) +
         (_V=4)*f_boom(4,0,0,0,0,0) +
         ((_V<1)|(_V>4))*_Default
     #debug concat("\nFn_switch returned <",
         str(Fn_switch(5,0),1,0),">\n\n")
//  --- Fn_switchByMult always throws as f_boom(1,0,0,0,0,0)
//      always runs. Everything is evaluated in a 'switch by
//      multiplication'
//  #debug concat("\nFn_switchByMult returned <",
//      str(Fn_switchByMult(5,0),1,0),">\n\n")
#error "Stop early\n"
Subject: Re: Using splines to map arbitrary value (was Re: #switch #case infunction?=
Date: 18 Jun 2024 10:05:00
Message: <web.667193726b7c39638519c45d25979125@news.povray.org>
WFP,
I was trying to think of some additional way to lay things like this out for
clarity, and I wondered if you might think about a way to evaluate functions in
a structure like a color_map.
Or perhaps more like a prism or a spline.
Then it would be easy to see what ranges any given function would be evaluated
in.
function_map {
     [0.0 FunctionA (x, y, z)]
     [0.3 FUnctionA (x, y, z)]
     [0.3 FunctionB (N)]
     [0.7 FunctionC (j, k)]
     [0.7 FunctionD (clock)]
     [1.0 FunctionD (clock)]
What are your thoughts on this type of data structure and how much work would
require its implementation?
- BW
Subject: Re: Using splines to map arbitrary value (was Re: #switch #caseinfunction?)
Date: 18 Jun 2024 10:10:24
Message: <66719550$1@news.povray.org>
Too many math operators in a row make it difficult for me to remember
"what was that and what I did it for?" Besides, it allows non-continous
functions to be created, which, in my particular case, is a disadvantage
- I'm not going to think of what POVRay will do in areas where function
is not defined, and debug all this. With splines I only have to watch
for endpoints 0 and 1 to exist.
In fact, I made a decision to remove all various mapping functions and
replace them with just spline. Using it completely match Photoshop and
GIMP "Curves" so is absolutely intuitively clear to me and hopefully
clear enough for other people, and instead of several algorithms with
explanatory comments I'll be having just one control points table. The
only problem is that in POVRay input-output pairs are written left to
right, while in Photoshop visualized as 2D plot, but I think I can stand
it :-)
Ilyich the Toad
Date: 18 Jun 2024 10:55:00
Message: <web.66719eaeaf1180ff8519c45d25979125@news.povray.org>
You can always just use POV-Ray itself to graph your functions, and then you
will know exactly what will happen.
https://news.povray.org/povray.binaries.images/thread/%3Cweb.5926c5ddec053131c437ac910%40news.povray.org%3E/?ttop=44359
4&toff=900
https://news.povray.org/povray.text.scene-files/thread/%3Cweb.5926c60f1312c693c437ac910%40news.povray.org%3E/?ttop=4435
39&toff=100
https://news.povray.org/povray.text.scene-files/attachment/%3Cweb.5926c60f1312c693c437ac910%40news.povray.org%3E/graphf
unction.pov.txt
- BW
Date: 19 Jun 2024 09:33:51
Message: <6672de3f$1@news.povray.org>
> WFP,
> in.
> function_map {
>       [0.3 FunctionB (N)]
For clarity about when each function runs an how they are interpolated -
your suggest a start.
Handling all those individual function arguments would be messy. We'd
have to deal with vector vs scalar functions. An encapsulating
performance concern is that when any map interpolates / blends you need
the value at both ends of each interpolation segment(*). Needing both
values means two function calls for each interpolation segment - whether
you need the interpolation aspect or not.
(*) Unless you are sitting on an index value or at at one of the ends of
the overall set of interpolation segments. Most implementations grab two
end values to keep the internal code simple. There is some optimization
in POV-Ray's code base; I had to fix a bug where the new to v3.8
blend_mode feature got tangled in one of those optimizations IIRC.
If the interpolations needed are not too complicated and fit into the
available blend_mode, blend_gamma mechanisms, you can implement pigments
which can be used as functions in a way similar to the way splines can
be used in functions for such a purpose.
I have a bell ringing in my head that I played with some sort of
function selection approach in years past. One based on 'gradient x'
while creating isosurfaces I think - green, ugly shapes.
We have user_defined{} pigments / density too with which something might
be doable.
There is in the fork yuqk the inbuilt f_mult1to8pairs() function, which
in part, is aimed at cleaner representations / handling of sets of up to
eight functions each having a corresponding multiplier/boolean. It was
also aimed at being more efficient, but it won't especially be so over
an in function select sequence - unless I get around to implementing
some solid method of passing function pointers into inbuilt functions.
There is too in yuqk f_morph2to9fncts() which enables all sorts of crazy
weights and normalizations of a collection of input functions. I should
get back to play more with this one! Maybe it's more animation related,
but the idea is anything from morphing a sphere into a box to maybe
including shipped shape classes with configuration options. It is,
though, not a simple or especially clean function to use at this point.
Maybe with some practice / refinement.
At the moment, I see a general, clean representation/solution to
combining functions as messy - and an significant chunk of work.
Ah, there is too the 'average' back door to using functions as indexes
which could be used in some simpler cases. Though the overall
representation isn't itself that clean as using functions as variable
weighting indexes is head twisting itself.
We can write macros as Cousin Ricky suggested with a simpler interface
which would write / compile to SDL using select(s).
The thing nice about the spline and pigment_map based approaches is so
long as the need fits into the available feature set, you get
interpolation more or less for free.
How to more easily handle collections of functions / function code is an
aim for the yuqk fork. All makes me think implementing Ingo's gradient
macro collection as an inbuilt function collection, sooner rather than
later, would be good. Especially, if I get back to playing with
f_morph2to9fncts() and similar.
Bill P.
