POV-Ray : Newsgroups : povray.general : Cross-stitch and print on canvas (RFC, sort of) Server Time
9 Nov 2026 14:38:35 EST (-0500)
  Cross-stitch and print on canvas (RFC, sort of) (Message 1 to 5 of 5)
Subject: Cross-stitch and print on canvas (RFC, sort of)
Date: 9 Feb 2024 08:40:26
Message: <65c62b4a@news.povray.org>
Greetings hunams,
I'm sort of in hopes of some feedback. As some may have noticed, I keep
exploring idea of turning 2D image pixels into POVRay 3D objects and
seeing what happens, and keep trying to use Python for that.
Attached are two small programs and one combined preview. One program
turns image into something like print on canvas, while other turns image
int cross-stitch.
The main problem is I'm not satisfied with normal. I did simulation os
textile long ago and have some algorithmic normals witten in mini-C,
but, unfortunately, I don't see the way to reproduce in with POVRay. SO
far, I used spiral, but it's far from ideal.
Also I'm not quite satisfied with finish, but that's mostly problem of
my not so perfect vision.
I have a high hope that someone take a look at it, dare to start it
(hopefully Python is installed already) and probably give some feedback.
Note that these programs are not released yet, only sent here since I
hope for feedback allowing me to improve it.
Ilyich the Toad
https://github.com/Dnyarri/  -  image to POV utils
Download 'torimix.png' (185 KB) Download 'tori.zip' (7 KB)
Preview of image 'torimix.png'
Subject: Re: Cross-stitch and print on canvas (RFC, sort of)
Date: 9 Feb 2024 10:00:00
Message: <web.65c63d80a5dd03951f9dae3025979125@news.povray.org>
Hi Ilya,
You can certainly do that in POV-Ray itself, using the eval_pigment macro.
Post the code for the normal, and we'll see if we can convert it into something
POV-Ray can do.
Until then, here's a few link that you might find interesting:
http://news.povray.org/povray.binaries.images/thread/%3C4a1e679e@news.povray.org%3E/
http://news.povray.org/povray.binaries.images/thread/%3C39f3b2ee@news.povray.org%3E/?mtop=8&moff=26
https://news.povray.org/povray.newusers/message/%3C64744689%241%40news.povray.org%3E/#%3C64744689%241%40news.povray.org
%3E
- BW
Date: 9 Feb 2024 10:29:54
Message: <65c644f2$1@news.povray.org>
> POV-Ray can do.
I'm using POVRay normal spiral1 scallop_wave with scale, rotate etc. It
very roughly simulate threads, but is completely useless for multythreads.
I would like to superimpose several different wavy patterns, and
probably something else for fluff. Maybe add, of maybe multiply them to
each other. But for doung so, I need writing my own functions for
normals, and I have no idea whether it's possible or not.
I'm trying to limit scene to static primitives, preferrably small, to
avoid slow rendering.
Ilyich the Toad
Date: 9 Feb 2024 13:10:00
Message: <web.65c66a32a5dd03951f9dae3025979125@news.povray.org>
Of course.
I gave you the link to the documentation on POV-Ray's functions.
Pigments and normals are just functions that take x, y, and z as their arguments
and use that to create the procedural pattern.
You can access them by using the pigment {} statement as a sort of look-up table
into the function, and then use normal {function {}} to apply it.
Here's a small scene to show how that's done.
#version 3.8;
global_settings {assumed_gamma 1.0 }
#include "functions.inc"
 location <0, 20, -50>
 up y
 look_at <0, 10, 0>
 rotate -y*20
light_source {<20, 50, -50> rgb 1} // for documentation illustrations
sky_sphere {pigment {rgb 1}}
#declare fmod = function (Value, Modulo) {select (Value, 1 - mod (abs (Value),
Modulo), mod (abs (Value), Modulo))}
#declare BW = color_map {
 [0 rgb 0]
 [1 rgb x+y]
#declare Spiral = function {pigment {spiral1 5}}
#declare Leopard = function {pigment {leopard}}
#declare Checker = function {pigment {checker 0 1 scale 3}}
#declare Crackle= function {pigment {crackle}}
#declare Mesh = function {f_mesh1 (x, z, y, 1, 0.2, 1, 0.1, 2)}
#declare Mesh2 = function {max(Mesh (x, y, z), 0)}
#declare Mixed = function {select (Checker (x, y, z).red, 0, Spiral(x, y,
z).red, Crackle (x, y, z).red)}
box {-10, 10 texture {pigment {rgb z} finish {specular 0.4} normal {function
{Spiral(x, y, z).red} bump_size 2}} }
{Spiral(x, y, z).red*Leopard (x, y, z).red} bump_size 2}} translate x*20}
{Spiral(x, y, z).red*(sin(x)+1)/2} bump_size 2}} translate -x*20}
{Mixed (x, y, z)} bump_size 2}} translate -x*20 translate y*20}
box {-10, 10 texture {pigment {function {Mesh2(x, y, z)} color_map {BW}} finish
{specular 0.4} normal {function {Mesh (x, y, z)} bump_size 2}} translate x*20
translate y*20}
- BW
Download 'normal function.png' (790 KB)
Preview of image 'normal function.png'
Date: 9 Feb 2024 14:30:45
Message: <65c67d65$1@news.povray.org>
- Directions even your brother can understand. (c) Hudson Hawk
Well, basically for now it seems like all I need are functions of
coordinates, once I manage to understand syntaxis, I'll manage to
combine functions into something. And it seems like I understand your
example (surely, nothing cant stop me from being wrong, lol); well,
basically.
So thank you very much, I'll try to gather some understanding.
Ilyich the Toad
