POV-Ray : Newsgroups : povray.general : Bug in processing #while loop for low comparison values? Server Time
16 Apr 2026 09:33:45 EDT (-0400)
  Bug in processing #while loop for low comparison values? (Message 1 to 4 of 4)
Subject: Bug in processing #while loop for low comparison values?
Date: 12 Apr 2005 18:26:07
Message: <64io51tbvdhf1jpee5h2f7ed9lomqd8gf0@4ax.com>
Hi all,
POV-Ray for Windows version 3.6.1a.icl8.win32
Windows XP sp2
I believe I have discovered a bug with #while loop processing when
comparing conditional values that are less than one.  When checking
the "Loop" variable for less than one, the #while block is still
processed when the value one is reached.
The bug can be best explained and reproduced with the following code.
>>> snip >>>
// demonstration of possible bug in POV-Ray for Windows
// Version 3.6.1a.icl8.win32
  location <0, 0.5, -2>
  look_at <0, 0.5, 0>
// bug - should not enter while block when "Loop" = 1
#declare Loop = 0.0;
#while ( Loop < 1 )
  sphere {
    <-0.1, Loop, 0>, 0.05
    pigment { rgb <1, 0, 0> }
    finish { ambient 1 }
  #declare Loop = Loop + 0.1;
// example for comparison
#while ( Loop < 0.99 )
  sphere {
    <0.1, Loop, 0>, 0.05
    pigment { rgb <0, 1, 0> }
>>> snip >>>
The #while loop that produces the red spheres is executed for the
"Loop" value of one when it should stop at 0.90, similar to "Loop <=
1".  The #while loop that produces the green spheres is there for
comparison.
The #while loop processes properly if the comparison is changed to a
higher value, such as "Loop < 10".  It also fails for lower values,
such as "Loop < 0.90", so the problem seems to be for values of one or
less.
Unless I'm really missing something obvious, this seems to be a bug.
Thanks to everyone involved for such a great product!
Best Regards,
Kyle Johnson
Subject: Re: Bug in processing #while loop for low comparison values?
Date: 12 Apr 2005 19:04:53
Message: <425c5415@news.povray.org>
  Not a bug. A limitation of floating point numbers.
  The number 0.1 is pathological in that it cannot be represented
accurately in the base-2 floating point format of the FPU (for the
same reason that for example 1/3 cannot be represented accurately
with a base-10 floating point representation).
  When you add 0.1 like this, the error caused by this accumulates
in such way that after you have added it ten times the result is
not 1 but a tiny fraction less.
  If you use integers only (ie. "#declare Loop = Loop + 1;") then
there's no such problem (because floating point numbers can
represent integers accurately up to a quite big value).
Date: 13 Apr 2005 04:46:16
Message: <425cdc58$1@news.povray.org>
news:425c5415@news.povray.org...
The following link may be of interest
http://tinyurl.com/272fa
Date: 13 Apr 2005 22:30:52
Message: <jblr51h65afmpqffqgr3mfq2ll1g19hvf0@4ax.com>
Thanks to Warp and Tom.  This clears things up quite a bit.  The link
was very helpful.
Kyle
On Wed, 13 Apr 2005 09:46:15 +0100, "Tom Melly"
