POV-Ray : Newsgroups : povray.general : colors map interpolation Server Time
5 Nov 2025 01:18:12 EST (-0500)
  colors map interpolation (Message 1 to 6 of 6)
Subject: colors map interpolation
Date: 20 Nov 2022 11:28:21
Message: <637a55a5$1@news.povray.org>
Hello,
Let's assume that we have a colors map :
#declare MyColorMap = color_map {
  [ 0.00 rgb < 1.00, 0.00, 0.00> ]
  [ 0.50 rgb < 1.00, 1.00, 0.00> ]
  [ 1.00 rgb < 0.00, 0.00, 1.00> ]
Is there a way to recover the color for specific index ?
Something that looks like : GetColor(MyColorMap, index)
Kurtz le pirate
Compagnie de la Banquise
Subject: Re: colors map interpolation
Date: 20 Nov 2022 12:50:00
Message: <web.637a680ff841873a1f9dae3025979125@news.povray.org>
kurtz le pirate <kur### [at] gmailcom> wrote:
> Hello,
Sure - I think you could take something like a gradient pigment pattern, apply
that color mapping to it, and then use that as a function.   Then you could pass
in a space coordinate with a vector component parallel to that gradient, and the
function would return the interpolated color vector as a result.
You would of course, have to write / generate 3 functions - one for the .r, .g,
and .b components.
https://wiki.povray.org/content/Reference:Color_Map
Alternatively, you could roll your own and use a spline function to do the
interpolation, in case there something special that the above can't handle.
Date: 20 Nov 2022 15:10:00
Message: <web.637a8917f841873a1f9dae3025979125@news.povray.org>
> and .b components.
Like this:
#version 3.8;
global_settings {
 assumed_gamma 1.0
#include "math.inc"
#declare E = 0.000001;
#declare Camera_Orthographic = true;  //
#declare Camera_Position = <0, 0, -20>;  // front view
#declare Camera_Look_At  = <0, 0,  0> ;
#declare Fraction = 1;     // functions as a zoom for the orthographic view: 4
zooms in 4x, 8 zooms in 8x, etc.
#declare Aspect = image_width/image_height;
 #if (Camera_Orthographic = true)
  orthographic
  right     x*image_width/(Fraction)
  up   y*image_height/(Fraction)
 #else
  up y
 location  Camera_Position
 look_at   Camera_Look_At}
sky_sphere {pigment {rgb 1}}
light_source {<0, 0, -image_width> color rgb 1}
#declare Gradient = pigment {gradient x color_map {MyColorMap}}
box {<0, image_height/3, 0>, < image_width, 2*image_height/3, 0.01> pigment
{Gradient scale image_width} translate -x*image_width/2}
#declare GradientFunction = function {pigment {Gradient}}
#for (XX, 16, 640-16, 16)
 #local R = GradientFunction (XX/image_width, 0, 0).red;
 #local G = GradientFunction (XX/image_width, 0, 0).green;
 #local B = GradientFunction (XX/image_width, 0, 0).blue;
 sphere {<XX, 0, 0> 5 pigment {rgb <R, G, B>} translate -x*image_width/2}
Download 'colormapinterpolation.png' (18 KB)
Preview of image 'colormapinterpolation.png'
Date: 21 Nov 2022 11:29:57
Message: <637ba785$1@news.povray.org>
>> and .b components.
> Like this:
Waouh, impressive !!!
Based on your brilliant example, here is the macro :
#macro GetColor(thisColorMap, thisEntry)
 #local index = max(0.0, min(thisEntry, 1.0));
 #local Gradient = pigment { gradient x color_map { thisColorMap } }
 #local GradientFunction = function { pigment { Gradient } }
 #local R = GradientFunction (index, 0, 0).red;
 #local G = GradientFunction (index, 0, 0).green;
 #local B = GradientFunction (index, 0, 0).blue;
 rgb <R, G, B>
And used like that :
sphere {
  <XX, 0, 0> 5
 pigment { GetColor(MyColorMap, XX/image_width)  }
Kurtz le pirate
Date: 22 Nov 2022 07:15:00
Message: <web.637cbc5ef841873aaaf434a689db30a9@news.povray.org>
> >> and .b components.
> > Like this:
>  rgb <R, G, B>
> #end
Hi Kurz
I don't know if it was your intention to not extract the filter and
transmit components of the color.
If you write the macro like this:
#macro GetColor(ThisColorMap, ThisEntry)
    #local Index = max(0.0, min(ThisEntry, 1.0));
    #local Gradient = pigment { gradient x color_map { ThisColorMap } }
    #local GradientFunction = function { pigment { Gradient } };
    #local Color = color GradientFunction(Index, 0, 0);
    Color
#end // macro GetColor
- then it will extract all the color components.
You'll also get a faster macro because of only one call to the pigment
function instead of three.
The value returned from the pigment function is a rgbft vector, so if all
of the components are of interest then there's no need to disassemble it
and then reassemble it.
Tor Olav
http://subcube.com
https://github.com/t-o-k
Date: 22 Nov 2022 11:02:51
Message: <637cf2ab$1@news.povray.org>
On 22/11/2022 13:11, Tor Olav Kristensen wrote:
> Hi Kurz
Hello
Yes, in this case, I am not interested in the values of t and f.
I want to use the color_map as a lookup table to draw the julia sets.
>     Color
Well seen !
Thanks
Kurtz le pirate
