POV-Ray : Newsgroups : povray.general : Glass for v3.8 finish features Server Time
16 May 2024 23:16:44 EDT (-0400)
  Glass for v3.8 finish features (Message 1 to 6 of 6)
Subject: Glass for v3.8 finish features
Date: 2 Aug 2022 11:30:00
Message: <web.62e942de1adc8eb48a3c0aee5cc1b6e@news.povray.org>
Whenever I create a scene that contains objects made of glass, I spend a lot of
time tweaking the various pigment, finish, and interior parameters of the
material to try and get something that looks realistic.  Sometimes I start with
what I can find in glass.inc, but it doesn't appear to have been updated since
v3.5.
Has anyone worked on something similar to RC3Metal for glass that takes
advantage of all of the new finish features in later versions?  It might be
something I'd be willing to explore, but I don't have a great grasp on how all
of combinations, including fresnel interact, so it's going to be hit and miss.
Thanks,
-- Chris R.
Subject: Re: Glass for v3.8 finish features
Date: 3 Aug 2022 13:00:06
Message: <62eaa996$1@news.povray.org>
> v3.5.
> Thanks,
> -- Chris R.
Normally, for a transparent object having an IOR, you use reflection{1
fresnel} to control the reflectivity. There is usually no need to use
another value here.
Fresnel reflection depends entirely on the ratio between the ior on each
sides of the surface and the angle of incidence. A ratio of 1 mean NO
reflection. A standalone object without an interior defining an ior
different from 1 will also show no fresnel reflection.
When the fresnel keyword is present, it always default to ON.
falloff and exponent should be left to their default values. Don't use
those.
Do not use metallic.
Then, you should also use the fresnel option for the highlights. Need
the latest version. IIRC, it was not implemented in version 3.7, but is
supported in the latest V1.8 beta.
Examples : specular 0.7 fresnel roughness 0.001, phong 0.7 fresnel
phong_size 500
Also, you should use transmit 1 or filter 1 as your pigment.
If you want the object to be coloured, use fading in the interior
statement :
interior{ior 1.5 fade_color rgb<1, 0.6, 0.6> fade_distance 1 fade_power
1001}// A pink object.
Adjust fade_distance for the dimension and scale of your object. It's
easily the most important parameter when using fading colours in an
interior.
ALWAYS use conserve_energy.
Sample glass :
texture{
	pigment{rgbt 1}
	finish{specular 1 roughness 0.001 fresnel
		ambient 0 diffuse 0
		reflection{ 1 fresnel }
		conserve_energy
interior{ ior 1.5 //typical glass IOR
	fade_color rgb<0.9, 1, 0.9>//slightly greenish
	fade_distance 2 // Adjust to the size and scale of the object
	fade_power 1001}
Date: 4 Aug 2022 14:15:00
Message: <web.62ec0c2be6447231ec2018a5cc1b6e@news.povray.org>
> > v3.5.
> > Thanks,
> > -- Chris R.
> another value here.
> those.
> phong_size 500
> statement :
> interior.
> Sample glass :
> texture{
>  pigment{rgbt 1}
>   ambient 0 diffuse 0
>   conserve_energy
>  fade_power 1001}
Thanks for the insights.  I am trying them out now.
I don't have a good understanding of when to use the albedo keywork for specular
and diffuse reflection.  I note that you do not use it above.
-- Chris R.
Date: 5 Aug 2022 13:23:53
Message: <62ed5229$1@news.povray.org>
> -- Chris R.
I'm attaching a text file which amounts to my current notes related to
finish concerns with POV-Ray - and to some degree what I've been playing
with in povr to address them(a).
Near the top are my general finish recommendations related to albedo use.
(a) - The file is packaged with my povr tarballs. The version attached
being my most current - with updates last done in February of this year.
I started investigating and writing the file with a hope of creating
better albedo documentation. I too find the albedo keyword use and
behavior confusing. Today, despite the file name, it's grown to be my
'notes / current thinking' related to all finish block concerns.
Bill P.
Download 'albedofresnelstory.txt' (31 KB)
Date: 5 Aug 2022 13:29:07
Message: <62ed5363$1@news.povray.org>
>>> v3.5.
>>> Thanks,
>>> -- Chris R.
>> another value here.
>> those.
>> phong_size 500
>> statement :
>> interior.
>> Sample glass :
>> texture{
>>   pigment{rgbt 1}
>>    ambient 0 diffuse 0
>>    conserve_energy
>>   fade_power 1001}
> -- Chris R.
You use albedo when you also use a brilliance that differs from the
default of 1.
As I did not use brilliance in my example, it was not useful to use albedo.
Example of the use of albedo and fresnel with an opaque pigment :
pigment{rgb< 0.7, 1, 0.2>}
finish{
	brilliance 10 //high brilliance for a very highly polished surface
	diffuse albedo 0.7 // albedo needed to have correct illumination
	specular albedo 1 roughness 0.01// albedo also needed due to the high
brilliance
// I like to put the roughness on the same line as specular as they work
together
// Same thing for phong and phong_size.
	fresnel // have the IOR also affect the highlights
	reflection{1 fresnel}
interior{ior 1.7}
Date: 5 Aug 2022 13:55:51
Message: <62ed59a7$1@news.povray.org>
> default of 1.
FWIW. In the latest v3.8/v4.0 code only the diffuse component of finish
changes on the brilliance value. Further, the diffuse value as used by
radiosity changes on brilliance of other than 1.0 only 'without' the use
of albedo. With albedo only the non-radiosity diffuse value is adjusted.
Bill P.
