POV-Ray : Newsgroups : povray.general : Feature request : OTF (and other) font format(s) support Server Time
18 May 2024 15:38:30 EDT (-0400)
  Feature request : OTF (and other) font format(s) support (Message 1 to 2 of 2)
Subject: Feature request : OTF (and other) font format(s) support
Date: 21 Feb 2021 15:30:05
Message: <web.6032c2863fa95d8ea5d10390@news.povray.org>
Hello again,
At the moment, if we have OTF-only fonts, we have to convert them to TTF. It's a
long work to do when using big font families having
Regular/Bold/Italic/Bold-Italic/... plus condensed versions plus wide versions
plus... plus... 8P
It would be so nicer if povray could simply support at least OTF fonts too.
( You could ever try to use the freetype library to do so ? ← If it could
help )
Thank you.
Subject: Re: Feature request : OTF (and other) font format(s) support
Date: 25 May 2021 15:18:27
Message: <60ad4d83$1@news.povray.org>
Am 21.02.2021 um 21:28 schrieb zebulon 1er:
> plus... plus... 8P
> help )
I had actually started work on exactly that back in early 2019. I think
the code hasn't made it into POV-Ray proper yet, but it is there in the
official POV-Ray repo, as the `experimental/freetype` branch, and the
`v3.8.0-x.freetype` series of binaries
(https://github.com/POV-Ray/povray/releases/tag/v3.8.0-x.freetype.3).
I'd have to take a closer look again to see what the last status of the
code was, but IIRC it already supported PS-style OpenType fonts (in
addition to TrueType fonts and TT-style OpenType fonts). Or actually any
outline font supported by the FreeType library.
IIRC there were some issues with fringe cases, in which the render
result would differ from POV-Ray's old proprietary TT handling, but that
was a bullet that I considered worth biting.
(The render differences have their roots in the fact that
PostScript-style fonts differ fundamentally from TrueType-style fonts,
in that they use spline outlines of 3rd order rather than just 2nd
order. Even with FreeType there would be no sane way to translate
PS-style fonts into the form the old `text` primitive core code needs.
However, the `prism` primitive does pretty much exactly the same job,
and is already well equipped to handle 3rd order splines. So in the
experimental branch mentioned above, all the `text` primitive handling
has been stripped out entirely, except for a bit of code in the parser
that now secretly just translates any `text` objects into corresponding
`prism` primitives, interfacing to the FreeType library for the glyph
outline details. The caveat is that the old `text` primitive, while
having been very similar in functionality to the `prism` primitive for
2nd order splines, behaved slightly different in certain situations.)
