POV-Ray : Newsgroups : povray.general : Dumb trig question Server Time
16 May 2026 02:00:37 EDT (-0400)
  Dumb trig question (Message 1 to 7 of 7)
Subject: Dumb trig question
Date: 28 Mar 2021 18:20:46
Message: <6061013e$1@news.povray.org>
I want an animation of a circle whose radius starts at x and ends up at
infinity. If x were zero then I would use `tan(clock*pi/2)`. But x is
not zero. What should I use instead? Please answer my dumb maths
question, thanks.
Mike
Subject: Re: Dumb trig question
Date: 28 Mar 2021 18:56:08
Message: <60610988$1@news.povray.org>
> question, thanks.
> Mike
(1-1/(1-clock))-(1-x)
Date: 28 Mar 2021 19:00:24
Message: <60610a88$1@news.povray.org>
>> at infinity. If x were zero then I would use `tan(clock*pi/2)`. But x
>> is not zero. What should I use instead? Please answer my dumb maths
>> question, thanks.
>> Mike
you could also use tan, starting at atan(x) going to pi/2
Or log(1-clock)+x
Any function that goes to infinity at a known point could be used, I
suppose, but those are the three I can think of.
Date: 28 Mar 2021 19:18:35
Message: <60610ecb$1@news.povray.org>
You mean this?
tan(clock * (pi/2 - atan(x)) + atan(x))
Not sure what to do.
Mike
Date: 28 Mar 2021 19:52:32
Message: <606116c0$1@news.povray.org>
> You mean this?
you want a function that starts at x at clock=0 and goes to infinity at
clock=1, and for some reason you want to use tan() :)
you have:
tan(u)=x <=> atan(x)=u
and tan(v)=infinity <=> v=pi/2
but you want tan(f(clock)) with f(clock) a function that gives you the
desired results.
So you need to convert clock (which goes from 0 to 1) to the range
atan(x) -> pi/2
Let's figure this out:
you can't just add atan(x) to clock, or it would go from atan(x) to
1+atan(x)
So you also have to scale the clock-value.
Let's do that first, the range should be between atan(x) and pi/2, and
we know that atan(x) is smaller than pi/2.
So the difference is (pi/2)-atan(x), that is the scale. The offset is
indeed atan(x)
So we get: fClock=((pi/2)-atan(x))*clock+atan(x)
and then tan(fClock) should give you the desired result.
I think.
I haven't used POV-Ray in a while, so you might have to translate some
parts into POVese
Date: 28 Mar 2021 20:16:40
Message: <60611c68$1@news.povray.org>
> I think.
I think that's the same as what I came up with.
Mike
Date: 29 Mar 2021 12:01:18
Message: <6061f9ce$1@news.povray.org>
> question, thanks.
> Mike
This one goes from 1 at zero to infinity at pi/2 :
1/cos(clock*pi/2)
Just add 1 to the value returned by the tangent :
tan(clock*pi/2)+1
