![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Given a circle with known radius, what is the length of the arc segment
formed between two radii with a known angle?
if you understand what I mean; that description feels awkward... :-/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 12/9/19 2:39 AM, also sprach Thomas de Groot:
Wouldn't it be some fractional part of the circumference?
given degrees angle a=10, angle b=100 radius r=20
length = pi*r*2*(b-a)/360
dik
Rendered 46,077,465,600 of 49,882,521,600 pixels (92%)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Op 09/12/2019 om 10:49 schreef Dick Balaska:
>> segment formed between two radii with a known angle?
I didn't think of that! Thanks!! :-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
You only need to convert that angle into radiant, then multiply by the
radius :
Just use the builtin macro :
#declare ArcLength = radians( AngleInDegree ) * Radius;
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Op 10/12/2019 om 01:04 schreef Alain Martel:
> radius :
Initially, I had something like that in the back of my mind but was
unable to move it to the front ;-)
Thanks indeed; I now have /two/ paths to achieve it.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> radius :
This is good to know!
I came across the other way on my own.
This way is shorter and less likely to have errors!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
