Has anyone here devised a method to write properly flowing text
including lines that wrap inside containers, line breaks, etc.?
Thanks.
Michael
> Thanks.
> Michael
As a patch, in hgpovray38,
http://wiki.povray.org/content/User:Le_Forgeron/galley
You can probably make a macro for the same purpose when using a
monospaced font, but doing such things for an usual font is going to be
hard: you would need to create every pair of consecutive letters (to get
the kerning), measure, put the letter in the current line and repeat.
What is in your "etc." ?
Thanks!
Does "internal" keyword mean that the kerning has been pre-calculated?
Tab characters I guess. I can't think of anything else at the moment.
Michael
Sorry, I mean, does it represent the internal number of a font whose
Michael
No, it is the same as for text{} object, an embedded font.
The kerning is a table, potentially large, indexed by pair of chars (the
one before and the one you want), in the TTF file (or embedded in internal).
it modify the current character metrics for its placement.
When a pair is not found, the metrics of the current character are
unmodified.
Typical kerning is for pair like "VA" & "AV" where the space between the
two letters should be different (smaller) from "AMV" and "VMA", from the
aesthetic point of view.
> Michael
