POV-Ray : Newsgroups : povray.general : Brick wall with thick glossy paint Server Time
18 Apr 2024 06:44:21 EDT (-0400)
  Brick wall with thick glossy paint (Message 1 to 8 of 8)
Subject: Brick wall with thick glossy paint
Date: 27 May 2019 06:47:33
Message: <5cebc045$1@news.povray.org>
I want to replace this image on Wikipedia:
https://commons.wikimedia.org/wiki/File:RGB_illumination.jpg
I have already created the lights. The problem I have is the brick wall.
How do I make a smooth glossy painted brick wall in POVray? All the
brick wall macros I've looked at have sharp edges.
I am open to using a texture instead of an isosurface. In fact, I like
this one very much:
https://www.sketchuptextureclub.com/textures/architecture/bricks/white-bricks/white-bricks-texture-seamless-00526
Unfortunately, that's not a FOSS image. Does anyone have any suggestions
on where else to look?
Thanks.
Michael
Subject: Re: Brick wall with thick glossy paint
Date: 27 May 2019 08:25:01
Message: <web.5cebd68cac74da924eec112d0@news.povray.org>
I suppose you could use an image map as a blurred / smoothed heightfield or
normal map.
Or blob together isosurfaces of a collection of bricks and a plane.
Maybe difference spheres sweeps of varying radius away from a perturbed plane to
create the rounded mortar areas.
Date: 28 May 2019 12:39:47
Message: <5ced6453$1@news.povray.org>
> normal map.
I have two functions.
	#undef f_Height
	#local f_Height = function {f_wrinkles(x*(BUSY+TRANS), y*(BUSY+TRANS),
z*(BUSY+TRANS))}
	#undef f_What
	#local f_What = function
		max
			abs(x)-(W-ROUGH*f_Height(x, y, z)),
			abs(y)-(H-ROUGH*f_Height(x, y, z)),
			abs(z)-(D-ROUGH*f_Height(x, y, z)/4)
How do I feed them to a heightfield? For instance, the following creates
an error:
	height_field
		function  1, 1
		{ f_What(x,0,y).gray * 0.04 }
		smooth
		texture
			pigment{ color srgb <0.6,0.55,0.5>}
			normal { bumps 0.1 scale 0.005}
			finish { phong 0.1 phong_size 400}
Thanks.
Date: 28 May 2019 12:43:43
Message: <5ced653f$1@news.povray.org>
> this one very much:
> Thanks.
> Michael
Have you tried the various tiling patterns options ?
Patterns 1, 4 are for a regular square pattern and pattern 10 looks good
for a brick wall.
I did some tests using tiling as a function for an isosurface and I got
something interesting. Try using a different wave type instead of the
default ramp_wave, like scallop_wave.
Date: 28 May 2019 13:35:07
Message: <web.5ced7062ac74da924eec112d0@news.povray.org>
I think you need to use the functions to define a pigment, which is THEN fed
into the heightfield.
http://wiki.povray.org/content/HowTo:High_precision_heightfields
Also, you can use your functions to generate an isosurface directly, which will
look just like a heightfield.
Date: 28 May 2019 14:17:19
Message: <5ced7b2f$1@news.povray.org>
That tutorial doesn't show how to pipe the functions back into a
height_field object. It just shows how to generate a bitmap image that
is then used in a later step.
I am using isosurfaces already, but don't know how to smooth them. I
posted my code in p.t.s-f.
Michael
Date: 28 May 2019 14:35:03
Message: <web.5ced7f19ac74da924eec112d0@news.povray.org>
http://www.povray.org/documentation/view/3.7.0/468/
Scroll down to:
2.7.12.1.1 The HF Macros
There are several HF macros in shapes.inc, which generate meshes in various
shapes. All the HF macros have these things in common:
The HF macros do not directly use an image for input, but evaluate a
user-defined function. The macros deform the surface based on the function
values.
Sounds like they should all be in the Insert Menu
> Michael
I'll take a look.
Date: 29 May 2019 02:30:04
Message: <5cee26ec$1@news.povray.org>
>> heightfield or
>> normal map.
>      #undef f_Height
> y*(BUSY+TRANS), z*(BUSY+TRANS))}
>      #undef f_What
>          max
> an error:
>      height_field
>          function  1, 1
>          smooth
>          texture
Have you tried:   function 1, 1 {f_What(x,0,y).hf*0.04}  ?
