POV-Ray : Newsgroups : povray.general : Dumb clock animation question Server Time
14 Jul 2025 18:58:05 EDT (-0400)
  Dumb clock animation question (Message 1 to 10 of 15)
Subject: Dumb clock animation question
Date: 17 Feb 2019 05:36:39
Message: <5c693937$1@news.povray.org>
This involves probably some very easy algebra.
I want a cylinder to spin 360 degrees when the clock is between 0 and
0.6667. I want another object to spin when the clock is between 0.3333
and 0.6667. Finally I want the camera to rotate 90 degrees when the
clock is between 0.6667 and 1.
How do I set this up? Thanks.
Michael
Subject: Re: Dumb clock animation question
Date: 17 Feb 2019 06:09:29
Message: <5c6940e9$1@news.povray.org>
> Michael
PS - I was thinking of maybe a macro that takes a start time and an end
time, and outputs a value between 0 and 1?
Michael
Date: 17 Feb 2019 07:30:00
Message: <web.5c69532030cdf98241e3d39f0@news.povray.org>
> > Michael
#macro MacroName(StartTime, EndTime)
    #local R = (clock - StartTime)/(EndTime - StartTime);
    #local S = min(max(0, R), 1);
    S
#end // macro MacroName
object {
    YourCylinder
    rotate MacroName(0/3, 2/3)*360*y
object {
    YourOtherObject
    rotate MacroName(1/3, 2/3)*SomeAngle*y
    YourCamera
    rotate MacroName(2/3, 3/3)*90*y
Tor Olav
http://subcube.com
https://github.com/t-o-k/
Date: 17 Feb 2019 12:36:11
Message: <5c699b8b@news.povray.org>
> Michael
Assuming that the clock goes from 0 to 1 :
To be added to the object of interest.
First case :
#if(clock <= 2/3) rotate x*360*3/2 #end
// *360 for a full rotation
// *3/2 adjust to the desired clock interval
Second case :
#if(clock > 1/3 & clock < 2/3) rotate y*(clock - 1/3)*720*3/2 #end
// *720 two full rotation, just because...
Third case :
#if(clock > 2/3) rotate z*(clock - 2/3)*90*3 #end
That should do it.
Date: 18 Feb 2019 07:47:31
Message: <5c6aa963$1@news.povray.org>
>      S
Thank you! That's perfect.
Mike
Date: 18 Feb 2019 12:40:05
Message: <web.5c6aed9530cdf982c97227110@news.povray.org>
> >      S
> Mike
I hesitate to try to improve on a TOK solution, but in my animations, a very
early line will be
#declare MyTime = clock;
then I use MyTime wherever I would use clock. This lets me #declare MyTime =
0.6667, for example to go to a position in the animation to test a particular
stage without running the whole animations. You would pass MyTime to the #macro.
This may be obvious, but it is an improvement.
Date: 19 Feb 2019 00:15:33
Message: <5c6b90f5@news.povray.org>
>>>       S
>> Mike
> early line will be
I'll keep that in mind, thanks! What I usually do is set the clock value
using the +K switch if I need to. I get confused by all the INI settings
sometimes too.
Mike
Date: 19 Feb 2019 00:18:05
Message: <5c6b918d$1@news.povray.org>
>      S
What do you think would be a good way to gradually speed up and then
slow down the motions using this macro? I'm thinking it would require a
sine wave (or some other bell curve), but am not sure how to apply it.
Mike
Date: 19 Feb 2019 04:28:04
Message: <5c6bcc24$1@news.povray.org>
Am 19.02.2019 um 06:18 schrieb Mike Horvath:
>>      S
A spline might help with this.
Date: 19 Feb 2019 07:15:00
Message: <web.5c6bf27730cdf982765e06870@news.povray.org>
> >      S
insert
#declare S = sin(S*Tau);
or
#declare S = abs(sin(S*Tau));
before the line
S
However you're running it.
