POV-Ray : Newsgroups : povray.general : Macro return value on failure Server Time
5 Mar 2026 04:34:47 EST (-0500)
  Macro return value on failure (Message 1 to 6 of 6)
Subject: Macro return value on failure
Date: 21 Jul 2018 21:55:50
Message: <5b53e426$1@news.povray.org>
I have two macros that calculate the intersection of two lines and
return a 2D vector <x,y>.
#macro line(p1, p2)
	#local A = (p1.y - p2.y);
	#local B = (p2.x - p1.x);
	#local C = (p1.x * p2.y - p2.x*p1.y);
	<A,B,-C>
#macro line_intersection(l1, l2)
	#local D  = l1.x * l2.y - l1.y * l2.x;
	#local Dx = l1.z * l2.y - l1.y * l2.z;
	#local Dy = l1.x * l2.z - l1.z * l2.x;
	#if (D != 0)
		#local out_x = Dx / D;
		#local out_y = Dy / D;
		#local out_value = <out_x,out_y>;
	#else
		#local out_value = false;
	out_value
#declare L1 = line(<0,1>, <2,3>);
#declare L2 = line(<2,3>, <0,4>);
#declare R = line_intersection(L1, L2);
//#if (R != false)
     #debug concat("\n\n\nIntersection detected: <", vstr(2,R,",",0,-1),
">\n\n\n")
//#else
//    #debug concat"No single intersection point detected")
//#end
Normally this works okay, but it is possible for the macro to fail if
the lines are coinciding. But, how can I signal a failure? I tried
passing the result to a conditional statement, but POVRay then complains
that it needs a float value but got a color value. There also is no
"null" or "undefined" value in POVRay SDL. I would appreciate some tips,
thanks.
Mike
Subject: Re: Macro return value on failure
Date: 21 Jul 2018 22:45:38
Message: <5b53efd2$1@news.povray.org>
Am 22.07.2018 um 03:57 schrieb Mike Horvath:
> thanks.
You could return a 3D vector, using the 3rd dimension for a status value.
If you are using POV-Ray v3.8.0, you could also use:
    #macro Line_Intersection(...)
        #if (D != 0)
            #local Out_Value = <out_x,out_y>;
            #local Out_Ok = true;
        #else
            #local Out_Value = <0,0>;
            #local Out_Ok = false;
        (Out_Value, Out_Ok)
    #declare (R, R_Ok) = Line_Intersection(...);
    #if (R_ok)
    #else
(As an unrelated side note, it is highly recommended to /not/ use
all-lowercase variable names; such names might be used as new keywords
in future versions without special notice.)
Date: 22 Jul 2018 00:04:36
Message: <5b540254$1@news.povray.org>
>          #if (D != 0)
>          #else
>          #end
>          (Out_Value, Out_Ok)
>      #end
>      #if (R_ok)
>      #else
>      #end
Thanks!
Now I am afraid because I use lower case for variable names almost
exclusively.
Date: 23 Jul 2018 10:40:01
Message: <web.5b55e8431b471102be7517870@news.povray.org>
> Thanks!
> exclusively.
I too am afraid. Many of my local variables are all lower case, though my #macro
names do start with e.g. AA_......
Something that doesn't seem to be well known (or maybe clipka has warned against
it in the past) is if you #declare a variable before you pass it into a #macro
and change it using #local in the #macro, when the #macro finishes it retains
the changed value. Obviously (since clipka says so) you can pass back the 3rd
component of a 3 vector, but then you would have to unpack the <x,y>
intersection point from the <x,y,z> vector. I would just add a 3rd argument to
line_intersection() and use that as the switch.
#version 3.7;
global_settings { assumed_gamma 1.0 }
#macro line(p1, p2)
 <A,B,-C>
#macro line_intersection(l1, l2, unique_int_point)
 #if (D != 0)
     #local unique_int_point = 1;
 #else
  #local out_value = <0,0>;
  #local unique_int_point = 0;
 out_value
#declare p1 = <0,1>;
#declare p2 = <2,3>;
#declare p3 = <2,6>;
//#declare p3 = <2,3>;
#declare p4 = <0,4>;
#declare L1 = line(p1, p2);
#declare L2 = line(p3, p4);
#declare unique_int_point = 1;
#declare R  = line_intersection(L1, L2, unique_int_point);
#if(unique_int_point = 1)
  #debug concat("\n\n\n Intersection detected: <", vstr(2,R,",",0,-1),">\n\n\n")
  sphere{R 0.1 pigment{Blue}}
#else
  #debug concat("\n\n\n No single intersection point detected.\n\n\n")
cylinder{p1 p2 0.05 pigment{Red}}
cylinder{p3 p4 0.05 pigment{Green}}
camera{orthographic location <0,0,-100> look_at <0,-0.00001,0> angle 12}
light_source{<0,0,-100> color rgb <1,1,1>  shadowless}
background{White}
Date: 23 Jul 2018 18:49:40
Message: <5b565b84$1@news.povray.org>
>> Thanks!
>> exclusively.
> #version 3.7;
> #macro line(p1, p2)
>   <A,B,-C>
> #end
>   #if (D != 0)
>   #else
>   #end
>   out_value
> #end
> #else
> #end
> background{White}
Wow, I thought local variables only worked in the local scope. E.g. the
globally declared variable in the code you supplied would retain its
original value.
Mike
Date: 24 Jul 2018 04:09:26
Message: <5b56deb6$1@news.povray.org>
Am 24.07.2018 um 00:49 schrieb Mike Horvath:
> original value.
For clarification - what JimT is describing is the following behaviour:
    #macro Foo(A)
      #local A = 42;
    #declare A = 1; // just for clarification
    #declare X = 1;
    Foo(X)
    #debug concat("A = ",str(A,0,0),"\n") // still 1
    #debug concat("X = ",str(X,0,0),"\n") // now 42
So `#local A` in a macro does not change the global variable named `A`.
It does, however, change the macro parameter named `A`. If a global
variable happens to be passed to that macro parameter, that global
variable (no matter what its name outside the macro) is also changed.
This call-by-reference behaviour is intentional, as a means to pass
additional information back out of a macro.
