POV-Ray : Newsgroups : povray.general : Offset surface Server Time
25 Apr 2024 17:24:54 EDT (-0400)
  Offset surface (Message 11 to 20 of 33)
Subject: Re: Offset surface
Date: 20 Jul 2018 12:35:00
Message: <web.5b520eeda78a3750c437ac910@news.povray.org>
"And" <49341109@ntnu.edu.tw> wrote:
> Many years ago I ever do something for the same goal.
http://news.povray.org/povray.binaries.images/thread/%3Cweb.5264d1b954cff585cc1fd1150%40news.povray.org%3E/?ttop=4230
56&toff=750
> But not the same, I used the math formula, not parametric formula. And just suit
> for a small offset(a thin shell)
> Because it is just an approximation.
Outstanding!  :)
This is exactly something I was trying to do and was having trouble with.
Hopefully I'll have time to look this over in detail tonight or over the
weekend.
Thanks so much for posting the link to that thread.  :)
Great work!
Date: 20 Jul 2018 22:44:41
Message: <5b529e19$1@news.povray.org>
Wow, thanks!!
I haven't tested it yet, but I saw your note about performance. Do you
think the parametric object is slower than an isosurface? I prefer the
parametric, since all the "sketches" I've been doing in GeoGebra so far
have been with parametric formulas, and in general I find them easier to
understand. Isosurfaces always make my brain freeze.
Mike
On 7/20/2018 7:39 AM, Bald Eagle wrote:
> So, I think I started this around 10 last night and [mostly] solved it by
> midnight.
> I did it in parametric form, but then I couldn't get the stupid parametric to
> render, so I somehow was able to see my way to doing it in implicit form for an
> isosurface.
> We already know the equation for the ellipsoid
> https://en.wikipedia.org/wiki/Ellipsoid
> In order to derive a normal vector for each point on its surface, we need to
> know the equation of the plane tangent to the ellipsoid at those points.
http://www.math.ucla.edu/~ronmiech/Calculus_Problems/32A/chap12/section6/811d45/811_45.html
> and that says that the coefficients for the polynomial are the scalars of the
> normal vector.
> Then ya just plug that into vnormalize to get a unit normal vector and tack that
> onto the ellipsoid formula.
> Hit the documentation to see what the formulae for vnormalize, vlength, and vdot
> are, and you have:
> #declare R = 1;
> #declare a = 1;
> #declare b = 0.7;
> #declare c = 1;
> #declare F_ellipsoid = function {(pow(x,2)/pow(a,2)) + (pow(y,2)/pow(b,2))
> +(pow(z,2)/pow(c,2)) - R}
> #declare F_Normal = function {
> ((pow(x,2)/pow(a,2)) / pow(a,2)) +
> ((pow(y,2)/pow(b,2)) / pow(b,2)) +
> ((pow(z,2)/pow(c,2)) / pow(c,2)) }
> #declare FVdot = function {pow(((pow(x,2)/pow(a,2)) / pow(a,2)), 2) +
> pow(((pow(y,2)/pow(b,2)) / pow(b,2)), 2) + pow(((pow(z,2)/pow(c,2)) / pow(c,2)),
> 2)}
> #declare Normalized = function {F_Normal (x, y, z) / sqrt (FVdot (x, y, z))}
> My full scene is here.
> Perhaps someone better versed in the parametric object can determine why I can't
> get it to render the full surface, since the exact same equations are used in
> the nested loop of spheres to correctly approximate the surface.
> I think the only additional thing I'd do is find some way to verify the
> correctness of this solution by verifying that the distance between the offset
> curve and the ellipsoid is constant over the entire surface.
> For that, I'd likely use a trace() method for the offset and the ellipsoid, and
> then calculate the shortest Euclidean distance.
> Might be able to do that and rewrite my trace() based curve making script to
> plot out an approximation, and then either use a triangular grid or a series of
> rectangles to make a smooth triangle approximation of the surface like Nylander,
> Loney, TOK, and Jaap Frank.
> #version 3.8;
> global_settings {assumed_gamma 1.0}
> // Offset / Parallel surface of an ellipsoid.
> // Bill Walker "Bald Eagle" 7/20/2018
> // for Mike Horvath "posfan12" at
> http://news.povray.org/povray.general/thread/%3C5b513fd2%241%40news.povray.org%3E/
> // parametric only renders a small section - not functional yet, and SLOW
> #include "colors.inc"
> //#include "shapes.inc"
> //#include "shapes2.inc"
> #include "shapes3.inc"
> #declare Zoom = 128;
> camera {
>    orthographic
>     location <0, 0, -20>    // position & direction of view
>    look_at  <0, 0, 0>
>    right x*image_width/Zoom           // horizontal size of view
>    up y*image_height/Zoom // vertical size of view
> camera {
>     location <0, 0, -4>    // position & direction of view
>    look_at  <0, 0, 0>
>    right x*image_width/image_height         // horizontal size of view
>    up y // vertical size of view
> sky_sphere {pigment {rgb <0.5, 0.5, 1>}}
> plane {y, -3 pigment {checker}}
> light_source {<5, 5, -30> color White}
> #declare Ellipse = torus {1, 0.01 rotate x*90 pigment {Red} scale <0.5, 1, 1> }
> #declare n=2;
> //object {Ellipse}
> //object {Ellipse scale <n, n, 1>}
> #declare R = 1;
> #declare a = 1;
> #declare b = 0.7;
> #declare c = 1;
> 2)}
> // for dynamic adapting of the max_gradient value
> #declare Min_factor = 0.6; // between 0 and 1
> #declare MaxGradient = 4;
> #declare P0 = MaxGradient*Min_factor;
> #declare P1 = sqrt(MaxGradient/(MaxGradient*Min_factor));
> #declare P2 = 0.7;  // between  0 and 1
> #declare Ellipsoid =
> isosurface {
>   function {F_ellipsoid (x, y, z)}
>   accuracy 0.001
>   max_gradient 3
>   //evaluate P0, P1, min (P2, 1)
>   contained_by {sphere {0, R}}
>   //contained_by {box {<-R, -R, -R>, <R, R, R>}}
>   pigment {rgb <0, 0, 1>}
> #declare MaxGradient = 3;
> #declare PEllipsoid =
> isosurface {
>   function {F_ellipsoid (x, y, z) - Normalized (x, y, z)/5 }
>   accuracy 0.001
>   max_gradient 5
>       contained_by {sphere {0, R*2}}
>   //contained_by {box {<-R, -R, -R>*2, <R, R, R>*2}}
>   pigment {rgbt <1, 1, 0, 0.8>}
> object {Ellipsoid}
> object {PEllipsoid} // translate x*R*2}
> #declare EllipseX = function (u, v) {a*cos(u)*sin(v)}
> #declare EllipseY = function (u, v) {b*sin(u)*sin(v)}
> #declare EllipseZ = function (v) {c*cos(v)}
> #declare FNormalX = function (u, v) {EllipseX (u, v) / pow(a,2)}
> #declare FNormalY = function (u, v) {EllipseY (u, v) / pow(b,2)}
> #declare FNormalZ = function (v) {EllipseZ (v) / pow(c,2)}
> #declare FVDot = function (u, v)
> {pow(FNormalX(u,v),2)+pow(FNormalY(u,v),2)+pow(FNormalZ(v),2)}
> #declare FVnormalizeX = function (u, v) {FNormalX (u, v) / sqrt (FVDot (u, v))}
> #declare FVnormalizeY = function (u, v) {FNormalY (u, v) / sqrt (FVDot (u, v))}
> #declare FVnormalizeZ = function (u, v) {FNormalZ (v) / sqrt (FVDot (u, v))}
> #declare Step1 = pi/18;
> #declare Step2 = pi/36;
> #for (V, 0, tau, Step2)
>   #for (U, 0, pi, Step1)
>    //#declare X = a*cos(U)*sin(V);
>    #declare X = EllipseX (U, V);
>    //#declare Y = b*sin(U)*sin(V);
>    #declare Y = EllipseY (U, V);
>    //#declare Z = c*cos(V);
>    #declare Z = EllipseZ (V);
>    sphere {<X, Y, Z> 0.01 pigment {Blue}}  //point at <x, y, z> on the ellipsoid
>    #declare Normal = <X/pow(a,2), Y/pow(b,2), Z/pow(c, 2)>;
>    sphere {<EllipseX (U, V) + FVnormalizeX (U, V)/10, EllipseY (U, V) +
> FVnormalizeY (U, V)/10, EllipseZ (V) + FVnormalizeZ (U, V)/10> 0.01 pigment
> {Red}} // surface normal at <X, Y, Z>
>   #end
> #end
> // --------------------------------------- parametric surface --------------
> #declare Parallel = parametric {
>   function {EllipseX (u, v)}
>   function {EllipseY (u, v)}
>   function {EllipseZ (v)}
>   <0, pi>, <0, 2*pi>  // start, end (u,v)
>   max_gradient 50
>   accuracy 0.005
>   precompute 5 x,y,z
>   texture {pigment{ color rgb <0, 1, 0>}}
> //object {Parallel}
Date: 20 Jul 2018 23:10:12
Message: <5b52a414$1@news.povray.org>
Okay I have been testing your scene. I've attached an orthographic
render of an ellipsoid with equal axes (so, a sphere). You can tell in
the render that there are thicker regions at the top-left, top-right,
bottom-left, and bottom-right. So I don't think the code is working as
it should.
Mike
> midnight.
> isosurface.
> normal vector.
> are, and you have:
> #declare R = 1;
> #declare a = 1;
> #declare b = 0.7;
> #declare c = 1;
> 2)}
> #version 3.8;
> camera {
>    orthographic
>    look_at  <0, 0, 0>
> camera {
>    look_at  <0, 0, 0>
> #declare n=2;
> //object {Ellipse}
> #declare R = 1;
> #declare a = 1;
> #declare b = 0.7;
> #declare c = 1;
> 2)}
> isosurface {
>   accuracy 0.001
>   max_gradient 3
> isosurface {
>   accuracy 0.001
>   max_gradient 5
> object {Ellipsoid}
>   #end
> #end
>   max_gradient 50
>   accuracy 0.005
>   precompute 5 x,y,z
> //object {Parallel}
Download 'bald_eagle_text.png' (27 KB)
Preview of image 'bald_eagle_text.png'
Date: 20 Jul 2018 23:32:56
Message: <5b52a968$1@news.povray.org>
Just to be clear, the offset surface of a perfect sphere should be
another perfect sphere.
Mike
Date: 21 Jul 2018 02:22:15
Message: <5b52d117$1@news.povray.org>
http://news.povray.org/povray.binaries.images/thread/%3Cweb.5264d1b954cff585cc1fd1150%40news.povray.org%3E/?ttop=423056
> &toff=750
Very nice, thanks!
I did a test, but there are graphical artifacts related to max_gradient
I think. The docs say a warning should appear if max_gradient is too far
off, but I don't see such a warning.
#version 3.8;
camera
	orthographic
	location	-z * 128		// position & direction of view
	direction	+z
	rotate x * 15
	rotate y * 45
camera
	look_at  <0, 0, 0>
	rotate x * 15
	rotate y * 15
light_source {<30, 30, -30> color rgb 1 parallel point_at 0}
#declare surf_thick = 0.1;
#declare f_spheroid = function(var1,var2,var3, a,b)
{var1*var1/a/a+var2*var2/a/a+var3*var3/b/b-1}
#declare f_spheroid_normalized = function(var1,var2,var3, a,b)
{f_spheroid(var1,var2,var3,
a,b)/sqrt(4*(var1*var1+var2*var2)/pow(a,4)+4*var3*var3/pow(b,4))}
//than difference these two isosurfaces
difference
	isosurface
		function {f_spheroid_normalized(x,y,z,1,2)-surf_thick}
//		accuracy		0.001
		max_gradient	4
		contained_by {sphere {0, 4}}
	isosurface
		function {f_spheroid(x,y,z,1,2)}
//		accuracy		0.001
		max_gradient	4
	plane {-y, 0}
	pigment {color rgbt <1,1,1,1/4>}
Date: 21 Jul 2018 03:15:28
Message: <5b52dd90@news.povray.org>
It's all working now, thanks to you all!
I've attached the latest test code and render.
Mike
Download 'and_test.pov.txt' (2 KB) Download 'and_test.png' (40 KB)
Preview of image 'and_test.png'
Date: 21 Jul 2018 04:57:53
Message: <5b52f591$1@news.povray.org>
Am 21.07.2018 um 04:46 schrieb Mike Horvath:
> Wow, thanks!!
My gut feeling is that for any given task there's nothing slower than
isosurfaces. After all, isosurfaces are pretty much the pinnacle of
flexibility, so they also provide the least potential for optimization.
Date: 24 Jul 2018 18:20:00
Message: <web.5b57a510a78a3750a47873e10@news.povray.org>
That's some really nice math work and problem-solving. I played around with the
bowl thickness and object scaling in your code, just to test the 'uniform wall
thickness' idea-- which works well!
You might try scaling the final bounded_by object to more closely fit the
resulting isosurface (for the sole purpose of making the scene render a bit
faster.) Even though the initial two isosurfaces' contained_by spheres can't be
scaled (that is, *non-uniformly* scaled), the final bounded_by sphere can. For
my render, I used <2.0,0.8,0.7> in the two initial functions...
         function {f_spheroid(x,y,z,2.0,0.8,0.7)}
             and
         function {f_spheroid_normalized(x,y,z,2.0,0.8,0.7)+surf_thick}
.... with surf_thick = 0.4, and bounded_by{sphere{0,1 scale <2.0, 0.8, 0.7>}}
This works well; I even tested the resulting (hidden) 'bounding box' shape with
min_extent/max_extent, to make sure of the close fit.
Of course. maybe a scaled BOX for the bounded_by shape could be an even closer
fit (to coincide with the differenced PLANE object in your code.)
I did notice some artifacts, in the self-shadowing area of the bowl. From
testing various things, it seems to be solely due to the isosurface 'accuracy'
value. I changed that from 0.001 to 0.000001, which appears to eliminate the
Moire patterns there. (I actually don't know how *small* a value that accuracy
can be, before it has no further effect.)
I was going to attach an image here of my tests, but I can't (using the web
interface, anyway.) I'll post it to the images section instead.
Date: 24 Jul 2018 18:36:48
Message: <5b57aa00$1@news.povray.org>
Thanks!
>               and
I'm not too worried about the artifacts, since 99% of the shape is
hidden behind another texture. Only the edges are important to me. (See
globe render in p.b.i.)
Mike
Date: 24 Jul 2018 18:38:30
Message: <5b57aa66$1@news.povray.org>
> Mike
p.b.a rather
