POV-Ray : Newsgroups : povray.general : qtpovray-3.80.1 for Linux Server Time
28 Apr 2024 22:27:50 EDT (-0400)
  qtpovray-3.80.1 for Linux (Message 28 to 37 of 37)
Subject: Re: qtpovray-3.80.1 for Linux
Date: 1 Aug 2018 04:33:08
Message: <5b617044$1@news.povray.org>
Am 31.07.2018 um 23:49 schrieb hugo giulietti:
> Confirmed using /usr/share/qtpovray-3.8/include/colors.inc
> The message does appear and say :
>   Statistics Stream to console....On
>   Warning Stream to console.......On
> version in colors.inc is 3,00
So you currently have
    #version 3.5;
    #debug concat("version in colors.inc is ",str(version,0,2),"\n")
in that `colors.inc`, right?
Then that's certainly a bug. Somehow the `#version` statement fails to
set the correct effective language version.
I also notice that the debug message says `3,00`, rather than `3.00`. Is
that a typo, or is that in the actual message?
In the latter case, that's another bug.
Oh, can you please try the following in an empty .pov file:
    #declare Foo = 3.14;
    #declare Bar = 314/100;
    #debug concat("Foo is ", str(Foo,0,2), "\n")
    #debug concat("Bar is ", str(Bar,0,2), "\n")
This /should/ output
    Foo is 3.14
    Bar is 3.14
but I have a hunch that it might output
    Foo is 3,00
    Bar is 3,14
in which case I guess I know what the problem may be.
Say, your name sounds italian, and in Italy they normally use commas as
decimal separators (just as they do here in Germany), right?
@dick: Are you actively changing the C/C++ locale in qtpovray, or do you
happen to know whether Qt does so by default? (buzzword `setlocale`)
Date: 1 Aug 2018 05:02:40
Message: <5b617730$1@news.povray.org>
Am 01.08.2018 um 10:33 schrieb clipka:
Never mind that question. According to StackOverflow, QCoreApplication
(on Unix/Linux) does indeed invoke
    setlocale(LC_ALL,"")
which screws up things. The suggested solution is to invoke
    setlocale(LC_ALL,"C")
right after initialization of QCoreApplication or QApplication. See here:
https://stackoverflow.com/questions/25661295/why-does-qcoreapplication-call-setlocalelc-all-by-default-on-unix-linux
Unfortunately there is no portable way to fix this in POV-Ray itself,
short of completely re-writing all code that currently depends on the
C/C++ locale setting. At the moment, there is probably a host of such
locale-dependent sections in the POV-Ray source code, only very few of
which have already been identified as such.
The C and C++ standards guarantee that at program startup the locale is
set to the "C" locale, and all locale-dependent code in POV-Ray relies
on this remaining unchanged.
Date: 1 Aug 2018 05:33:20
Message: <5b617e60$1@news.povray.org>
On 07/31/2018 06:03 AM, hugo giulietti wrote:
> Hello,
> I installed qtpovray in my lubuntu 16.04 using the ppa for automatic updates.
> After my first test using "optics.pov" i got this parse error from the povray's
output:
> "Parse Error: Macros require #version 3.1 or later but #version 3.00 is set.
> at File: colors.inc Line: 167 Col: 2"
> Very rare message. The colors.inc file is standard; i have not touched in any way. I
don't know how to fix this because the #version directive was not modified at all.
Do you have other versions of POV-Ray installed?
Where did you get optics.pov from?
I assume you are trying optics.pov from
file:///usr/share/qtpovray-3.8/scenes/advanced/optics.pov
I assume you installed qtpovray-includes and qtpovray-extras
since you have colors.inc and optics.pov
What happens if you try "Basic scene 01 - Checkered plane" from the
insert menu?
I just tried it on two machines and it was fine.
ubuntu 16.04, which is my primary workstation
and
mint 18.3 which is a clean "install from the ppa" machine (no compiling,
no multiple working versions)
cornell.pov worked for me too.
file:///usr/share/qtpovray-3.8/scenes/radiosity/cornell.pov
What cpu are you using?
You don't have the "Dynamic optimizations:" in the banner. i.e.
Support libraries used by POV-Ray:
  ZLib 1.2.8, Copyright 1995-2012 Jean-loup Gailly and Mark Adler
  LibPNG 1.2.54, Copyright 1998-2012 Glenn Randers-Pehrson
  LibJPEG 8, Copyright 1991-2016 Thomas G. Lane, Guido Vollbeding
  LibTIFF 4.0.6, Copyright 1988-1997 Sam Leffler, 1991-1997 SGI
  Boost 1.58, http://www.boost.org/
  OpenEXR 2.2.0 and IlmBase 2.2.0, Copyright (c) 2002-2011 Industrial
Light &
 Magic.
  CPU detected: Intel,SSE2,AVX,AVX2,FMA3
  Noise generator: avx2fma3-intel (hand-optimized by Intel)
Parser Options
  Input file: cornell.pov
  Remove bounds........On
  Split unions.........Off
  Library paths:
  Clock value:    0.000  (Animation off)
This is a really strange problem. It's like the parser is broken.
Like clipka said, in your colors.inc problem, the version is set at line
#13, yet is reporting something different at line #167.  This makes no
sense (so far).
https://github.com/dickbalaska/qtpovray/blob/qtpovray/distribution/include/colors.inc
dik
Rendered 328976 of 330000 (99%)
Date: 1 Aug 2018 05:53:41
Message: <5b618325$1@news.povray.org>
Reading that, it seems that I need to wrap POV-Ray with
setlocale(LC_ALL,"C") and let Qt be Qt. Like, call setlocale when
creating a session. Hmm, that will be messy; when getting a message from
POV-Ray I would have to setlocale(LC_ALL, "") and then set it back to
"C" after processing the message.
But, iirc, the povray parser doesn't like umlauted characters ("C"
locale) so maybe I should just force "C" all through the program and
abandon hope of spiffy translations.
dik
Date: 1 Aug 2018 08:40:43
Message: <5b61aa4b$1@news.povray.org>
Am 01.08.2018 um 11:53 schrieb dick balaska:
No, that would just risk screwing up things even more. Unfortunately,
the locale is global to the entire process, not thread-local, so you
can't just tamper with it while there's other threads running and
potentially invoking locale-dependent code.
From what I understand, Qt has its own locale mechanism, and only calls
`setlocale(LC_ALL,"")` for (a) Unix/Linux tradition and (b) to probe a
thing or two during QCoreApplication initialization; it doesn't seem to
need it to /remain/ set to that at all.
So once QApplication or QCoreApplication has been initialized, it should
be safe to just invoke `setlocale(LC_ALL,"C")` once and never touch the
C/C++ locale again afterwards.
There's a potential workaround for GNU/Linux machines in invoking
`uselocale()` during thread initialization, which sets the locale for
the individual thread only. However, this function is not part of the
C/C++ standard.
Date: 1 Aug 2018 16:22:48
Message: <20180801172247.61786f61d97daa5f4b503ed0@gmail.com>
My locale is set wide system to spanish. Just for confirm, i added this lines to
cornell.pov:
#version 3.7;
#debug concat("version in cornell.pov is ",str(version,0,2),"\n")
and the output result is:
  Render Stream to console........On
version in cornell.pov is 3,00
Foo is 3,00
Bar is 3,14
Parse Warning: In POV-Ray v3.5 and later a radiosity{}-block will automatically turn
on radiosity if the output quality is set to 9 or higher. Read the documentation to
find out more about radiosity changes!
It's clear. My decimal separator is a spanish "," (comma) rather the english "."
(point)
On Wed, 1 Aug 2018 10:33:07 +0200
>     #version 3.5;
>     Foo is 3.14
>     Bar is 3.14
>     Foo is 3,00
>     Bar is 3,14
hugo giulietti <hug### [at] gmailcom>
Date: 1 Aug 2018 17:01:46
Message: <5b621fba$1@news.povray.org>
I will create a "C" locale version and push that out tonight.
cornell.pov:
> #version 3.7;
> Foo is 3,00
> Bar is 3,14
(point)
dik
Date: 1 Aug 2018 18:16:00
Message: <20180801191559.5db76ff231ab4eebafc9a2a1@gmail.com>
On Wed, 1 Aug 2018 05:33:20 -0400
> > Hello,
output:
I don't know how to fix this because the #version directive was not modified at all.
  I have installed povray 3.7 from the Ubuntu repos, using the standard software
manager Synaptics. The optics.pov (and all demo scene files) are from this
installation.
  I did not know that there is qtpovray-includes and qtpovray-extras. I have not
installed this packages. I will install these after posting this writing.
  The installation of qtpovray installed a folder with *.inc files in:
/usr/share/qtpovray-3.8/include, so it is using that
folder.
> insert menu?
> and
> Light &
>  Magic.
> Parser Options
>   Library paths:
  I'm using an very old 1-core cpu AMD Sempron LE-1150 2.0 Ghz without AVX,AVX2,FMA3
support *but* with SSE2 instructions. I don't know why these was not detected.
> sense (so far).
> dik
I think that the "macro" declaration in line 167 needs a "#version" > 3.1 but the
"detected" version is 3.0. Resolving
the version issue will resolve the macro issue. (I'm guessing)
Date: 2 Aug 2018 03:37:53
Message: <5b62b4d1$1@news.povray.org>
Am 02.08.2018 um 00:15 schrieb hugo giulietti:
>   Hi,
installation.
> folder.
The `qtpovray` package probably pulled in the other packages already.
Anyway, the include files are not at fault here. We've nailed down the
culprit to the locale settings.
Subject: [Solved] Re: qtpovray-3.80.1 for Linux
Date: 2 Aug 2018 12:43:40
Message: <20180802134340.7cec9d13436e13c1f628ee32@gmail.com>
Yeah! Solved.
Now qtpovray is working at 100% after the software actualization! Thanks dick, thanks
clipka!
On Wed, 1 Aug 2018 17:01:46 -0400
cornell.pov:
> > #version 3.7;
> > Foo is 3,00
> > Bar is 3,14
turn on radiosity if the output quality is set to 9 or higher. Read the documentation
to find out more about radiosity changes!
(point)
> dik
