POV-Ray : Newsgroups : povray.general : Function: Problem in Defining Server Time
18 Aug 2025 09:00:14 EDT (-0400)
  Function: Problem in Defining (Message 1 to 10 of 16)
Subject: Function: Problem in Defining
Date: 5 Apr 2018 10:21:21
Message: <5ac630e1$1@news.povray.org>
I try to create (for the very first time) an own function, after i saw
it inside the POV-Ray online help files. Well, i do something wrong.
Basically, the purpose of my function is to create a negative or
positive float number, that I then can use to rotate something clockwise
or counter-clockwise. At the moment, it is my brain that is rotating
counter-clockwise.
Can you assist?
#declare Number = function(MyNumber)
 #declare MyAngle = rand(NySeed)*MyNumber;
 #declare MyPositive = rand(MySeed)*1.0;
 #if(MyPositive<0.5)
  MyAngle*(+1) // no #declare and no ;
 #else
  MyAngle*(-1) // no #declare and no ;
rotate < 0.0, Number(1.2), 0.0 >
ORIGINAL
#declare factorial = function(C)
 prod(i, 1, C, i) // no #declare and no ;
#declare A = factorial(5);
Diese E-Mail wurde von AVG auf Viren geprüft.
http://www.avg.com
Subject: Re: Function: Problem in Defining
Date: 5 Apr 2018 11:36:22
Message: <5ac64276$1@news.povray.org>
Am 05.04.2018 um 16:21 schrieb Sven Littkowski:
> Hi,
> counter-clockwise.
You can NOT use directives (such as #if..#else..#end) in functions.
Well, technically you can, but they do something entirely different than
one would naively expect - because they are evaluated only once, when
the function is initially defined.
For example, the scene code
    #declare MySeed = seed(4711);
    #declare MyFn = function(x)
      #if(rand(MySeed) > 0.5)
        x
      #else
        -x
does NOT construct a function that randomly returns its parameter or the
negative thereof, but rather
randomly constructs EITHER a function that returns its parameter, OR a
function that returns the negative of the parameter.
In other words, it is completely equivalent to:
        x
    #else
        -x
Likewise, your scene code
>  #if(MyPositive<0.5)
>  #else
>  #end
    #if(MyPositive<0.5)
    #else
(which is broken in multiple ways)
Date: 5 Apr 2018 11:57:34
Message: <5ac6476e$1@news.povray.org>
Thanks. Yes, I assumed that there are many errors in my function. But I
am still not sure, how to develop a code that does what I need to be done.
See at the very bottom (end) of this posting an excerpt of the scene
where it is important for me to create random numbers "right at that
spot" (Number(1.2) as otherwise too many extra lines of code would be
required.
How can I create random numbers, in the range from negative to positive,
within each line?
  box { < 0.11,  0.0, -0.00 > < 2.99, 0.3, -0.05 > texture { MyYellow }
rotate <  0.0, 0.0, Number(1.2) > translate < -4.0, 0.4, -7.50 > scale <
1.0, 1.0, -1.0 > } // Horizontal Planks Boiler Area
1.0, 1.0,  1.0 > } // Horizontal Planks
rotate <  0.0, 0.0, Number(1.2) > translate < -4.0, 0.9, -7.50 > scale <
rotate <  0.0, 0.0, Number(1.2) > translate < -4.0, 1.4, -7.50 > scale <
rotate <  0.0, 0.0, Number(1.2) > translate < -4.0, 1.9, -7.50 > scale <
rotate <  0.0, 0.0, Number(1.2) > translate < -4.0, 2.4, -7.50 > scale <
rotate <  0.0, 0.0, Number(1.2) > translate < -4.0, 2.9, -7.50 > scale <
rotate <  0.0, 0.0, Number(1.2) > translate < -4.0, 3.4, -7.50 > scale <
rotate <  0.0, 0.0, Number(1.2) > translate < -4.0, 3.9, -7.50 > scale <
rotate <  0.0, 0.0, Number(1.2) > translate < -4.0, 4.4, -7.50 > scale <
  box { < 0.01,  0.0, -0.00 > < 1.99, 0.3, -0.05 > texture { MyYellow }
rotate <  0.0, 0.0, Number(1.2) > translate < -1.0, 0.4, -7.50 > scale <
rotate <  0.0, 0.0, Number(1.2) > translate < -1.0, 0.9, -7.50 > scale <
rotate <  0.0, 0.0, Number(1.2) > translate < -1.0, 1.4, -7.50 > scale <
rotate <  0.0, 0.0, Number(1.2) > translate < -1.0, 1.9, -7.50 > scale <
rotate <  0.0, 0.0, Number(1.2) > translate < -1.0, 2.4, -7.50 > scale <
rotate <  0.0, 0.0, Number(1.2) > translate < -1.0, 2.9, -7.50 > scale <
rotate <  0.0, 0.0, Number(1.2) > translate < -1.0, 3.4, -7.50 > scale <
rotate <  0.0, 0.0, Number(1.2) > translate < -1.0, 3.9, -7.50 > scale <
rotate <  0.0, 0.0, Number(1.2) > translate < -1.0, 4.4, -7.50 > scale <
http://www.avg.com
Date: 5 Apr 2018 12:21:25
Message: <5ac64d05$1@news.povray.org>
Am 05.04.2018 um 17:57 schrieb Sven Littkowski:
You can't do it with a function, because `rand()` cannot be called from
within a function.
However, since you're only using it to generate a scene (as opposed to
using it for something where it would have to be evaluated during
rendering, such asn in an isosurfaces or function pattern), the good
news is that you don't need a function anyway - a macro will do nicely.
For example, to define a "pseudo-function" that gives you a random
number in a specific range, you might use:
    #macro MyRand(Min,Max)
      // compute stuff
      #local Rand = rand(MySeed);
      #local Result = Min + (Max-Min)*Rand;
      // "return" the computed value
      Result
Date: 5 Apr 2018 12:35:00
Message: <web.5ac64f683ce80830c437ac910@news.povray.org>
>  #if(MyPositive<0.5)
>  #else
>  #end
What you're doing is not a function, but a macro.
A function operates like this:
#declare PosOrNeg = function (N) {select(N, -1, 1)};
#declare Seed = seed(123);
#for (Num, 1, 10)
 #declare N = rand (Seed)-0.5;
 #debug concat( " Result = ", str(PosOrNeg(N), 3, 1), "\n")
You can then incorporate that into a calculation to give you an angle multiplied
by 1 or -1.
Date: 5 Apr 2018 17:00:00
Message: <web.5ac68da13ce80830c437ac910@news.povray.org>
And you don't even really need a separate function or macro - just use
#include "rand.inc"
then use (IIRC)
RRand (0, 360)
or
RRand (-180, 180) to give you your rotation angles directly.
Date: 5 Apr 2018 18:40:59
Message: <5ac6a5fb$1@news.povray.org>
Tttttsssssssssssssssssssssssss.
That is insider knowledge! Thanks! I would never have discovered this
option on my own. Giving a try.   :-)
http://www.avg.com
Date: 5 Apr 2018 21:02:06
Message: <5ac6c70e$1@news.povray.org>
>        // compute stuff
>        Result
>      #end
I wrap the return value in parenthesis. The intent is a little clearer
in the macro def and may avoid usage problems.
     (Result)
I know clipka, legally this is not required, because Result is a single
number. But I tend to do
     #local V=<1,2,3>;
     (Result+V)
where it is morally (debuggingly?) required.
sven, this is because when you use it, think of the expansion.
     #local R = MyRand(low, high) * 2;
which without parens, is
     #local R = Result + V * 2
which of course evaluates as
     #local R = Result + (V * 2)
which is not at all what you want.  With the parens, you get
     #local R = (Result + V) * 2
which is the intent of your usage.
dik
Rendered 328976 of 330000 (99%)
Date: 6 Apr 2018 02:47:16
Message: <5ac717f4$1@news.povray.org>
> #include "rand.inc"
> then use (IIRC)
> RRand (0, 360)
> or
To be correct:
#declare R=seed(1234);
RRand (-180, 180, R)
Date: 6 Apr 2018 03:32:37
Message: <5ac72295@news.povray.org>
Everybody can discover it. No "insider knowledge" here at all imo. When
you need randomness, you naturally go and look at the content of
rand.inc and its description in the docs. Nothing arcane involved.
