Le 18-02-18 à 21:45, Sven Littkowski a écrit :
> On 18.02.2018 21:22, clipka wrote:
>> Am 18.02.2018 um 22:24 schrieb Sven Littkowski:
>>> I am trying this
>>> #declare MyRandomer = seed(CURRENTTIMESTAMP);
>>> and this
>>> #declare MyRandomer = seed(msg:CURRENTTIMESTAMP);
>>> but only errors. please assist. Thanks!
>> Out of pure curiosity: How did you come up with that particular syntax?
>> The keyword you're looking for is `now`, which returns the time elapsed
>> since 2000-01-01, 00:00:00 GMT, in (fractional) days.
>> Note that since `seed()` converts its parameter to an integer, you need
>> to scale the result of `now` to whatever granularity you need for the
>> seed. For instance, for the seed to change every hour, use:
>> #declare MyRandomer = seed(now * 24);
>> Note that the value of `now` changes even during parsing.
>> Also note that the resolution of the underlying timer may vary between
>> systems, and may be as poor as a second per tick.
>> Finally, due to the nature of the inbuilt random number generator, the
>> first few values pulled from the generator may remain somewhat similar
>> between consecutive seeds, so you may want to choose your granularity
>> somewhat higher than absolutely necessary, or always discard the first
>> few random numbers (maybe a dozen or so) pulled from the generator.
> Hi.
> The POV-Ray help file did not mention "now", and so I started to search
> online but without knowing what exact keywords to look for. Eventually,
> I came accross a web page thatwas about POV-Ray and also featured
> "CURRENTTIMESTAMP". I believed it was more about programming then
> anything I could use in a scene, but i wanted to give a try, and that's
> how I got these variations you saw.
> I use "now" but the renders still look the same, like the seed would
> remain the same. I make the renders in intervals of less than a minute.
> Thus, a seed that changes each second would be nice.
> Diese E-Mail wurde von AVG auf Viren geprüft.
> http://www.avg.com
Try something like :
#declare SecondPerDay = 60*60*24; //or 86400
#declare MyRandomer = seed(now * SecondPerDay);
You can artificially make your seconds smaller by increasing the value
to your liking :
#declare Over = 1.5;
#declare SecondPerDay = 60*60*24*Over;
Next, use some dumy uses to skip a few initial values from the stream.
Le 18-02-19 à 09:18, Sven Littkowski a écrit :
> Thanks, that is what was needed!
> I think, the SEED chapter of the POV-Ray help file really need to
> mention "now" and "now * 24*60*60", as many users might be in need of
> irregularly random renders. "Now" is not even mentioned at all there,
> now does the key "F1" open any content help for "now".
> In fact, even with many existing keywords in the help file, only this
> happens when clicking them: the HELP opens a new page, but that is just
> the begin of the documentation, not the part dealing with that
> particular keyword.
> http://www.avg.com
The included help was not completely updated since version 3.6.0, and
now did not exist back then.
You may have beter results using the wiki based help.
Thanks. For me it is fine, to use seconds as smallest unit. Nonetheless,
I am learning something new with your answer.
But I want to say, that I appreciate a lot the good will and great
spirit in our group!
http://www.avg.com
