POV-Ray : Newsgroups : povray.general : Procedural realistic mountain ranges? Server Time
19 Apr 2024 23:38:40 EDT (-0400)
  Procedural realistic mountain ranges? (Message 11 to 20 of 35)
Subject: Re: Procedural realistic mountain ranges?
Date: 29 Dec 2017 03:12:43
Message: <5a45f8fb$1@news.povray.org>
Hi(gh)!
Am 29.12.2017 um 00:54 schrieb dick balaska:
> On 12/28/2017 06:10 AM, Jörg 'Yadgar' Bleimann wrote:
>> I forgot to mention that I use either Windows XP Professional
>> (32-bit), Windows 7 64-bit Professional or Debian Linux 8.9,
> I wondered if there were povers still using 32 bits.
Windows XP only on my slow ancient 512 MiB laptop...
See you in Khyberspace!
Yadgar
Date: 29 Dec 2017 03:42:58
Message: <5a460012$1@news.povray.org>
Hi(gh)!
Am 29.12.2017 um 08:51 schrieb Thomas de Groot:
> You are welcome Yadgar. Glad to be of help. I hope you will find what
> you want. If there is something fundamental that I have learned since I
> started modelling (with POV-Ray of course!) back in the nineties, it is
> that for each scale you often need a different tool/procedure. It is
> almost impossible to use the same output for a planetary view /and/ for
> a landscape. Both need different approaches.
Not necessarily... at least when it comes down to heightfields. Of
course, for an Earth-sized planet with a circumference of about 40,000
kms, a decent looking heightfield without needing vertical exaggeration
should be at least 400,000 by 200,000 pixels, the larger the better -
but this full size is mostly not needed, as it is only worthwile at
"pedestrian views" - and then you need only a tiny fraction of the whole
planetary surface. Which leads me to the next question: Does POV-Ray's
eval_pigment() also handle 16-bit grayscale pngs correctly?
Yadgar
Date: 29 Dec 2017 07:17:29
Message: <5a463259$1@news.povray.org>
On 29-12-2017 9:42, Jörg 'Yadgar' Bleimann wrote:
> Hi(gh)!
>> I started modelling (with POV-Ray of course!) back in the nineties, it
>> is that for each scale you often need a different tool/procedure. It
>> is almost impossible to use the same output for a planetary view /and/
>> for a landscape. Both need different approaches.
I don't know about eval_pigment. Somebody else might be more knowledgeable.
I tend to disagree with you about those height_fields. A planetary
height_field used for a 'pedestrian' view will show horrible jaggies
imho. Or you will need insane resolution values if you are using functions.
Date: 29 Dec 2017 10:42:04
Message: <5a46624c$1@news.povray.org>
Am 29.12.2017 um 09:42 schrieb Jörg 'Yadgar' Bleimann:
Absolutely. Everything you can use in a pigment, eval_pigment() will
handle correctly - for technically feasible definitions of "correctly".
Beware however the gamma monster. When using images as terrain elevation
maps, you'll typically want linear values. Ideally, the generating
software should use linear encoding and set the `gAMA` chunk
accordingly, but not all software is that well-behaved. To be on the
safe side, specify "gamma 1" in the image map. (Unless the generating
software uses non-linear encoding.)
(When using images in genuine height fields or bump maps, "gamma 1" is
the default. But for eval_pigment() you'll need to load the image as a
pigment first, in which case POV-Ray defaults to whatever gamma is
indicated in the PNG file, or sRGB if the file doesn't contain gamma
information.)
Date: 29 Dec 2017 10:59:56
Message: <5a46667c$1@news.povray.org>
On 29/12/2017 08:42, Jörg 'Yadgar' Bleimann wrote:
> Hi(gh)!
I agree with Thomas. The difference in scales between domestic and
geographical is too great for the resolution of heightfields.
But the link below might help. It is Gilles Tran's Spherical height field.
http://www.oyonale.com/modeles.php?lang=en&page=24
Regards
Date: 29 Dec 2017 14:30:00
Message: <web.5a4697907060b52089df8d30@news.povray.org>
Stephen <mca### [at] aolcom> wrote:
> On 28/12/2017 09:19, clipka wrote:
> > "new WinXP"???
> > Ouch.
> Some people keep things that work.
> Going from Leroy's site. It was new in 2006
I wish I still had mine. :-(  It was ... STABLE. And a workhorse. But the stupid
crummy power supply eventually fried the motherboard. (an Emachines computer,
BTW.)
Date: 29 Dec 2017 20:21:30
Message: <5a46ea1a@news.povray.org>
Hi(gh)!
Am 29.12.2017 um 16:42 schrieb clipka:
Obviously not, at least not with POV-Ray for Windows... I used a 16-bit
PNG generated with Wilbur to be parsed to a spherical mesh2 with this
script:
// beginning of code
#include "functions.inc"
#declare xx=1024;
#declare yy=512;
#declare minrad=22;
#declare maxrad=38;
#declare AsteroidRelief =
pigment
   image_map { tga "asteroid1.tga" }
#declare vertices=2+xx*(yy-2);
#fopen asteroid_mesh_inc "asteroid_mesh.inc" write
#write (asteroid_mesh_inc,
         "#declare asteroid_mesh =\n
         mesh2\n
         {\n
           vertex_vectors\n
           {\n",
             vertices,"\n",
             <0, -35.678431, 0>," // south pole \n") // number of
vertices: 2+b*(a-2) [2+xx*(yy-2)]
#declare a=1;
#while (a<yy-1)
   #declare b=0;
   // #declare rdcum = 0;
   #while (b<xx)
     #declare redval=eval_pigment(AsteroidRelief, <(0.5+b)*(1/xx),
(0.5+a)*(1/yy), 0>).red * (maxrad-minrad);
     #declare greenval=eval_pigment(AsteroidRelief, <(0.5+b)*(1/xx),
(0.5+a)*(1/yy), 0>).green * ((maxrad-minrad)/255);
     #declare rd=minrad+redval+greenval;
     /* #if (a=1 | a=yy-2)
       #declare rdcum=rdcum+rd;
     #end */
(rd*<sin(radians(b*(360/xx)))*cos(radians(-90+a*(180/(yy-2)))),
sin(radians(-90+a*(180/(yy-2)))),
cos(radians(b*(360/xx)))*cos(radians(-90+a*(180/(yy-2))))>)," // ",rd,"\n")
     #declare b=b+1;
   #declare a=a+1;
#write (asteroid_mesh_inc, <0, 35.741176, 0>,"// north pole\n
                         }\n
                         face_indices\n
                         {\n",
                            xx*2+xx*2*(yy-3),"\n") // number of faces:
b*2+b*2*(a-3) [xx*2+xx*2*(yy-3)]
#declare a=0;
#while (a<yy-1)
   #declare b=0;
   #while (b<xx)
     #switch (a)
       #case (0)
         #if (b < xx-1)
           #write (asteroid_mesh_inc, <0, a+1+b, a+1+mod(b+1,xx)>, "\n")
// b faces, all sharing first vertex (#0)
         #else
           #write (asteroid_mesh_inc, <0, a+1+b, 1>, "\n" // last
triangle connecting to first one
       #break
       #range (1, yy-3)
         #if (b < xx-1)
           #write (asteroid_mesh_inc, <1+(a-1)*xx+b,
1+(a-1)*xx+mod(b+1,xx), 1+a*xx+b>,",",<1+a*xx+b, 1+a*xx+mod(b+1,xx),
1+(a-1)*xx+mod(b+1,xx)>, "\n") // b*2*(a-3) faces
         #else
           #write (asteroid_mesh_inc, <1+(a-1)*xx+b, 1+(a-1)*xx,
1+a*xx+b>,",",<1+a*xx+b, 1+(a-1)*xx, 1+a*xx>, "\n") // last pair of
triangles in row connecting to first pair
       #break
       #case (yy-2)
         #if (b < xx-1)
1+(a-1)*xx+mod(b+1,xx), vertices-1>) // b faces, all sharing last vertex
         #else
vertices-1> // last triangle connecting to first one
       #break
     #declare b=b+1;
   #declare a=a+1;
#write (asteroid_mesh_inc, "  }\n}")
#fclose asteroid_mesh_inc
// end of code
It seemed to parse correctly - but POV-Ray crashed immediately
afterwards, regardless how big or small values I used for xx and yy. I
didn't try yet whether it still produced a valid mesh2 - but I don't
think so.
Yadgar
Date: 30 Dec 2017 07:35:40
Message: <5a47881c$1@news.povray.org>
Am 30.12.2017 um 02:21 schrieb Jörg 'Yadgar' Bleimann:
> script:
https://youtu.be/tc2tDFPlyWY?t=1h51m5s
/Some/ day I'll teach you folks to specify the version number when
reporting an issue ;)
> think so.
If the scene parses, it's not an issue with `eval_pigment()`, as that's
called during parsing. Rather, the /scene/ created must have some
problematic properties.
Also, that's a TGA file you're using there, not PNG ;)
To further diagnose the issue, I'd probably need a copy of the image.
Date: 30 Dec 2017 11:00:39
Message: <5a47b827$1@news.povray.org>
> reporting an issue;)
That's a bit subtle, for us.
Just say what you mean before we grow beards. ;)
Regards
Date: 30 Dec 2017 20:26:07
Message: <5a483caf@news.povray.org>
If you don't provide the version number, there is no way to know if the
issue is an old one, maybe already fixed in later version, or a new one
accidentally introduced.
Where you using version 3.5, 3.6, 3.7, the latest test build...?
