POV-Ray : Newsgroups : povray.general : QUESTION: How to Emit Light? Server Time
25 Feb 2026 01:18:47 EST (-0500)
  QUESTION: How to Emit Light? (Message 1 to 10 of 11)
Subject: QUESTION: How to Emit Light?
Date: 1 Dec 2017 23:24:52
Message: <5a222b14$1@news.povray.org>
Please see the code below, and let me know, how I can make these rings
illuminate their neighborhood?
union
 torus { 2.475 0.025 rotate < 0.0, 0.0, 90.0 > translate < 20.0, 0.0,
0.0 > rotate < 0.0, 000.0, 0.0 > }
0.0 > rotate < 0.0, 120.0, 0.0 > }
0.0 > rotate < 0.0, 240.0, 0.0 > }
 hollow
 pigment { color rgb < 0.8784314,  0.2,  0.003921569 > }
 interior
  media
   samples 20
//   absorption < 3.0, 4.0, 0.5 >*1.0
   emission   < 1.0, 1.0, 1.0 >*10.0
   scattering
    1
    < 0.5, 0.75, 1.5 >*3.0
    extinction 0.5
 finish { emission 10.0  }
Diese E-Mail wurde von AVG auf Viren geprüft.
http://www.avg.com
Subject: Re: QUESTION: How to Emit Light?
Date: 2 Dec 2017 00:01:45
Message: <5a2233b9$1@news.povray.org>
Am 02.12.2017 um 05:24 schrieb Sven Littkowski:
What do you mean by "illuminate their neighborhood"? Do you want the
rings to cast light onto nearby objects, or do you want a glowing "halo"
around the rings?
Date: 2 Dec 2017 03:04:32
Message: <5a225e90$1@news.povray.org>
> around the rings?
Hi, thanks for your time. :-)
I want to cast light onto nearby objects without having to use radiosity
(I get already a nice illumination with radiosity, but I like it without
radiosity, too, if possible), but I also want a glow around the objects.
http://www.avg.com
Date: 2 Dec 2017 04:51:51
Message: <5a2277b7@news.povray.org>
Am 02.12.2017 um 09:04 schrieb Sven Littkowski:
>> around the rings?
To cast light onto nearby objects, the only alternative to radiosity I'm
aware of would be fill lights (light sources with `shadowless`), but I'd
expect them to be difficult to set up for your use case (you don't want
the ring itself to be illuminated by the fill lights, for instance).
For the glow around the objects, you'll need emissive media.
Date: 2 Dec 2017 05:26:48
Message: <5a227fe8$1@news.povray.org>
>>> around the rings?
Would everything but the rings in a light group, work?
Regards
Date: 2 Dec 2017 14:10:56
Message: <5a22fac0$1@news.povray.org>
> union
>   hollow
>   interior
>    media
>     samples 20
>     scattering
>      1
>      extinction 0.5
> http://www.avg.com
Your pigment is opaque, so, you never see the media.
If you only want the tori to illuminate the area, you need to use radiosity.
Can be turned on, using default parameters, by adding an empty radiosity
block in the glabal_settings block:
glabal_settings{radiosity{}}
You parbably need to use beter parameters.
Start with count, something around 100 as a starter.
Reduce pretrace_end from default 0.04 to maybe 0.01.
With emission 10, you get an apparent yellow for the torus, but the
illumination will be orange.
If you want some kind of aura around them, then you need to have a
slightly larger torus around then that will be filled with some emissive
media.
Date: 2 Dec 2017 14:30:35
Message: <5a22ff5b$1@news.povray.org>
>> around the rings?
> http://www.avg.com
Remove the interior as it's not needed.
Add "no_shadow" to your torus.
Place a few lights inside the torus along it's major radius.
Make sure that they are fading lights.
#declare Light_Torus = union{
  torus { 2.475 0.025 }
  #for(P, 0, 330, 30)//add 12 lights
   light_source{2.475*x, rgb < 0.8784314,  0.2,  0.003921569 >
    area_light 0*x, 0.3*z, 1, 5 adaptive 0
    fade_distance 0.3 fade_power 2
    rotate P*y
  no_shadow
  torus { 2.475 0.065 hollow // For the glowing aura
   pigment{rgbt 1}
   media{ samples 5 // Enough for that simple media
    emission < 0.8784314,  0.2,  0.003921569 >*5
union{
  object{Light_Torus rotate 90*z }
  object{Light_Torus rotate 90*z rotate 120*y}
  object{Light_Torus rotate 90*z rotate 240*y}
  emission 10
Date: 2 Dec 2017 16:40:25
Message: <5a231dc9$1@news.povray.org>
Alain, thanks a lot for your advise.
I decided, to use radiosity.
But my question remains, how to create a glow-producing media in or
around the torus. I started already, but it does not produce the desired
glow effect.
http://www.avg.com
Date: 2 Dec 2017 16:54:12
Message: <5a232104$1@news.povray.org>
Thanks! If I understand correctly, the existing torus cannot be made
glowing (having an aura around it). I have to create a new torus
(thicker diameter), which then is filled with the glow, am I correct?
I will go ahead and create a new surrounding torus, and fill it with
media. Please see below and advise me (I do not have any experience with
media).
union
 union // original torus
  pigment { color rgb < 0.8784314,  0.1,  0.003921569 > } // mandatory
orange
  finish { emission 30.0  }
 union // larger glowing torus
  torus { 2.475 0.150 rotate < 0.0, 0.0, 90.0 > translate < 20.0, 0.0,
  hollow
orange
  interior
   media
    samples 100
    scattering
     1
     extinction 0.5
http://www.avg.com
Date: 2 Dec 2017 17:10:01
Message: <web.5a2323d429de4f055cafe28e0@news.povray.org>
Take a look at some of what went on in recent threads:
http://news.povray.org/povray.general/thread/%3Cweb.59f243919b56bbddbb23337d0%40news.povray.org%3E/
http://news.povray.org/povray.binaries.images/thread/%3Cweb.59fa2a48231a9fe3ec54f04a0%40news.povray.org%3E/
