POV-Ray : Newsgroups : povray.general : applying a finish to an object ? Server Time
18 Aug 2025 13:50:33 EDT (-0400)
  applying a finish to an object ? (Message 1 to 2 of 2)
Subject: applying a finish to an object ?
Date: 22 Aug 2017 15:47:44
Message: <599c8a60$1@news.povray.org>
EHLO
I have some computer generated .INC files with this type of object :
#declare essai = object {
union {
sphere { <0.000000, 0.000000, 0.000000> 0.300000
    pigment { color <0.500000, 0.500000, 0.500000> } }
sphere { <0.361449, 0.271070, 0.291044> 0.251914
    pigment { color <0.000000, 0.000000, 0.000000> } }
In the main scene, I try that :
object { essai finish { reflection 0.9 ambient 0 diffuse 0.1 } }
And,  noway to have all my little bubbles be a mirror...
http://la.buvette.org/POV/fractal-agregat/bug_finish.gif
I can post the complete poc...
tTh
Subject: Re: applying a finish to an object ?
Date: 22 Aug 2017 19:43:39
Message: <599cc1ab@news.povray.org>
Le 17-08-22 à 15:50, tth a écrit :
> EHLO
> union {
> tTh
It just can't work.
Any texture that is explicitely applyed to any object are never replaced
nor layered over by any texture or finish applyed to the CSG object.
object{sphere{0 1 pigment{rgb<1,0,0>}} pigment{rgb<0,1,1>}}
Will result in a pure red sphere, without any hint of cyant.
If you where to add some untextured object, then, that object will get
reflective.
A possible workaround would be as follow:
#declare O_Default = texture{}
  // Save the original default texture.
  // An empty texture block always return the current default texture.
#default{finish{ reflection 0.9 ambient 0 diffuse 0.1 } }
  // Set a new default texture with the reflection that you want
object { essai }
  // Place your object
#default texture { O_Default }
  // Restore the original default texture
