POV-Ray : Newsgroups : povray.general : Square or X gradient Server Time
14 Jan 2026 13:23:21 EST (-0500)
  Square or X gradient (Message 1 to 4 of 4)
Subject: Square or X gradient
Date: 21 Feb 2017 17:36:52
Message: <58acc104$1@news.povray.org>
How would I create a pattern such as this:
https://www.filterforge.com/wiki/images/3/32/Square_gradient.jpg
Thanks!
Mike
Subject: Re: Square or X gradient
Date: 21 Feb 2017 17:52:39
Message: <58acc4b7$1@news.povray.org>
> Thanks!
> Mike
Never mind. I was able to piece it together using four triangles, each
with a different linear gradient.
Mike
Date: 21 Feb 2017 23:25:01
Message: <web.58ad1216933428799c5d6c810@news.povray.org>
Mike, maybe you didn't remember the boxed pattern?
plane{
    z,0
    pigment{
        boxed
        color_map{
            [0 rgb 0][1 rgb 1]
That should be same, except 'finish' statement to adjust.
Date: 22 Feb 2017 20:02:52
Message: <58ae34bc@news.povray.org>
> Thanks!
> Mike
box{<-1,-1,0><1,1,1> pigment{boxed}}
or
plane{z, 0 pigment{boxed}}
The pattern appears only once, centered at the origin.
It start at a value of 1 at the origin and drop to zero at the edge of
box{-1,1}
You can use :
translate 1 // make it fit the warp span
  warp{repeat x*2}
  warp{repeat y*2}
  warp{repeat z*2}
translate -1 // take it back to it's otiginal location
to make it fill the space.
