On 11/9/2016 12:28 AM, omniverse wrote:
> Mike Horvath <mik### [at] gmail com> wrote:
>> http://wiki.povray.org/content/Reference:Camera#Focal_Blur
>> How can a plane be parallel to the camera? Can't a plane only be
>> perpendicular to a vector?
>> Also, I don't understand why a plane is used at all. All points
>> equidistant from focal_point should form a sphere, don't they?
> Probably parallel in the view sense, every plane forward of the camera view
> would be considered parallel.
> Someone else would need to answer that second part, but I think the way it works
> is to simply use a flat plane like orthographic projection does. Maybe... maybe
> not.
> I looked at your SDL and the new screen.inc (I renamed mine here screen2.inc to
> not mix it up with the old one).
> Found that by using aperture 0.01 to focus the blurring while testing, and using
> the camera location instead of <0,0,0> I could get a look at the text again by
> adding a little z to it.
> Of course, it blurs away immediately after clock increases away from 0.
> focal_point CameraLocation+z*0.4
> If 0.3 or 0.5 is used the text blurs out, so obviously there's a very narrow
> focus area.
> I don't know if you will be able to discover a method to keep the text at the
> focal plane but seems like it shouldn't be impossible either.
> Bob
Eventually I got the text to show up, but as you said it doesn't stay in
focus as the clock increases. I gave up and added the text using
ImageMagick instead.
Mike
Can I simulate an f-number of the camera by using the focal length and
aperture in a calculation? Is the aperture supposed to be a physical
measurement? Thanks.
Mike
> Mike
For instance, I have the following numbers:
#local CameraDistance = 16;
#local CameraAperture = clock * 4;
#local CameraFStop = CameraDistance/CameraAperture;
Mike
Am 10.11.2016 um 14:06 schrieb Mike Horvath:
The `aperture` setting is the (virtual) size of the diaphragm opening in
POV-Ray units, though I keep forgetting whether it is the diameter or
the radius.
> the radius.
Thank you. Could you check whether it is the diameter or radius in the
code? It is commonly supposed to be diameter according to Wikipedia.
Mike
> the radius.
In my experience, it's neither. Comparing aperture to a jittered
camera, it seems that dividing the aperture by about 2.7 or so yields
the diameter. (Or is it multiplying by 2.7...?)
Am 10.11.2016 um 18:38 schrieb Mike Horvath:
>> the radius.
There's a line
r = camera.Aperture * 0.5
in the source code, indicating that the `aperture` parameter is intended
to specify the diameter.
But maybe someone can check Cousin Ricky's claim that the size is off by
a factor.
