POV-Ray : Newsgroups : povray.general : focal_point Server Time
18 May 2024 10:29:53 EDT (-0400)
  focal_point (Message 8 to 17 of 17)
<<< Previous 7 Messages Goto Initial 10 Messages
Subject: Re: focal_point
Date: 9 Nov 2016 00:43:24
Message: <5822b77c$1@news.povray.org>
Am 09.11.2016 um 01:23 schrieb Mike Horvath:
> If I comment out the focal blur stuff, the text returns. I also tried
> lowering the aperture size, but it does not help.
My guess would be that the text is far too close to the camera, and
therefore hopelessly out of focus.
Subject: Re: Focal Blur
Date: 9 Nov 2016 16:23:23
Message: <582393cb$1@news.povray.org>
On 11/9/2016 12:41 AM, clipka wrote:
> Am 09.11.2016 um 05:28 schrieb Mike Horvath:
>> http://wiki.povray.org/content/Reference:Camera#Focal_Blur
>> The docs say, "The center of the zone of sharpness is specified by the
>> focal_point vector. The zone of sharpness is a plane through the
>> focal_point and is parallel to the camera. Objects close to this plane
>> of focus are in focus and those farther from that plane are more
>> blurred. The default value is focal_point<0,0,0>."
>> How can a plane be parallel to the camera? Can't a plane only be
>> perpendicular to a vector?
> Interpret it as "parallel to the image plane" -- or, in other words,
> "perpendicular to the camera axis".
>> Also, I don't understand why a plane is used at all. All points
>> equidistant from focal_point should form a sphere, don't they?
> Uh, yes, technically, all points equidistant from _any_ given point form
> a sphere, but how would a sphere centered around focal_point (= an
> arbitrary point by which the location of the zone of sharpness is
> defined) be of any relevance?
> Presuming that you mean "all points equidistant from the camera
> location", the answer is: Yes, that would also be a sphere -- but the
> zone of sharpness in a normal camera is _not_ the set of points
> equidistant to the camera lens; rather, in a real-life camera it is the
> set of points equidistant to the image plane, and that's also the case
> for POV-Ray's camera.
Okay, thanks.
Mike
Date: 9 Nov 2016 16:23:41
Message: <582393dd$1@news.povray.org>
You are correct.
Mike
Date: 9 Nov 2016 16:24:53
Message: <58239425$1@news.povray.org>
> Probably parallel in the view sense, every plane forward of the camera view
> would be considered parallel.
> Someone else would need to answer that second part, but I think the way it works
> is to simply use a flat plane like orthographic projection does. Maybe... maybe
> not.
> I looked at your SDL and the new screen.inc (I renamed mine here screen2.inc to
> not mix it up with the old one).
> Found that by using aperture 0.01 to focus the blurring while testing, and using
> the camera location instead of <0,0,0> I could get a look at the text again by
> adding a little z to it.
> Of course, it blurs away immediately after clock increases away from 0.
>      focal_point     CameraLocation+z*0.4
> If 0.3 or 0.5 is used the text blurs out, so obviously there's a very narrow
> focus area.
> I don't know if you will be able to discover a method to keep the text at the
> focal plane but seems like it shouldn't be impossible either.
> Bob
Eventually I got the text to show up, but as you said it doesn't stay in
focus as the clock increases. I gave up and added the text using
ImageMagick instead.
Mike
Date: 10 Nov 2016 08:06:36
Message: <582470dc$1@news.povray.org>
Can I simulate an f-number of the camera by using the focal length and
aperture in a calculation? Is the aperture supposed to be a physical
measurement? Thanks.
Mike
Date: 10 Nov 2016 10:10:51
Message: <58248dfb$1@news.povray.org>
> Mike
For instance, I have the following numbers:
	#local CameraDistance	= 16;
	#local CameraAperture	= clock * 4;
	#local CameraFStop	= CameraDistance/CameraAperture;
Mike
Date: 10 Nov 2016 11:50:07
Message: <5824a53f$1@news.povray.org>
Am 10.11.2016 um 14:06 schrieb Mike Horvath:
The `aperture` setting is the (virtual) size of the diaphragm opening in
POV-Ray units, though I keep forgetting whether it is the diameter or
the radius.
Date: 10 Nov 2016 12:38:03
Message: <5824b07b@news.povray.org>
> the radius.
Thank you. Could you check whether it is the diameter or radius in the
code? It is commonly supposed to be diameter according to Wikipedia.
Mike
Date: 10 Nov 2016 19:00:59
Message: <58250a3b$1@news.povray.org>
> the radius.
In my experience, it's neither.  Comparing aperture to a jittered
camera, it seems that dividing the aperture by about 2.7 or so yields
the diameter.  (Or is it multiplying by 2.7...?)
Date: 10 Nov 2016 22:21:44
Message: <58253948$1@news.povray.org>
Am 10.11.2016 um 18:38 schrieb Mike Horvath:
>> the radius.
There's a line
    r = camera.Aperture * 0.5
in the source code, indicating that the `aperture` parameter is intended
to specify the diameter.
But maybe someone can check Cousin Ricky's claim that the size is off by
a factor.
