POV-Ray : Newsgroups : povray.general : Survey: Gamma Handling Server Time
19 May 2024 06:15:51 EDT (-0400)
  Survey: Gamma Handling (Message 11 to 20 of 29)
<<< Previous 10 Messages Goto Latest 10 Messages Next 9 Messages >>>
Subject: Re: Survey: Gamma Handling
Date: 17 Oct 2016 08:42:20
Message: <XnsA6A495989CB87seed7@news.povray.org>
in news:5803ed6b$1@news.povray.org clipka wrote:
> Do you care about gamma handling?
> ( ) Not enough to bother answering any more of this survey.
> ( x) Enough to be willing to help you with this survey.
> Thank you for deciding to provide some feedback on gamma; please take
> the time to answer the following questions (feel free to tick more than
> one box per question, and elaborate where you think it might be helpful)
> -- or just ignore them and write some prose on what's really on your
> mind regarding the topic.
> Bystanders, please refrain from replying to people's feedback; we can
> have a discussion in a separate thread.
> What version of POV-Ray are you typically using?
> ( x) POV-Ray 3.7 (or a derivative, e.g. UberPOV, HG-Povray)
> ( ) POV-Ray 3.6 (or a derivative, e.g. MegaPOV, MCPov)
> ( ) Other: [___]
> What "assumed_gamma" setting are you typically using?
> ( ) none
> ( x) 1
> ( ) 1.8
> ( ) 2.2
> ( ) srgb
> ( ) Other: [___]
> Why are you using that setting?
> ( ) I find it easiest to work with.
> ( ) I think it gives the most pleasing results.
> ( x) I think it gives the most accurate results.
> ( ) I think it is the recommended setting.
> ( ) Other: [___]
> What keyword do you typically use to specify colours?
> ( x) "rgb"
> ( ) "srgb"
> ( ) Other (e.g. a macro): [___]
> Why are you using that keyword?
> ( ) I get colour values from elsewhere in that format.
> ( ) I think it is the recommended format.
> ( x) Other: [think lineair, let the soft calculate]
> What other gamma-related features do you know?
> ( x) "Display_Gamma" INI setting
> ( ) "File_Gamma" INI setting
> ( ) "Antialias_Gamma" INI setting
> ( x) "gamma" setting for input images
> ( ) "blend_gamma" setting for colour and pigment maps
> ( ) Other: [___]
> Which of them do you make frequent use of?
> ( ) "Display_Gamma" INI setting
> ( ) Other: [___]
> Why are you using those other features?
> ( ) I like to toy around with them.
> ( ) I like the flexibility they provide.
> ( x) I need them to handle special cases.
> ( ) They don't default to the settings I typically want.
> ( ) Other: [___]
> How do you feel in general about gamma handling in POV-Ray 3.7?
> ( x) I really like it.
> ( ) I think it's mostly ok.
> ( ) I think it's so-so.
> ( ) I think it's mostly broken.
> ( ) I really detest it.
> ( ) Dunno - I'm not using POV-Ray 3.7.
> How well do you get along with gamma handling in POV-Ray 3.7?
> ( x) It works like a charm for me.
> ( ) It has its quirks, but I can live with them.
> ( ) I'm still learning to deal with its quirks.
> ( ) Its quirks still keep getting in my way.
> ( ) It just doesn't work for me at all.
> What's your opinion on the claim that "assumed_gamma 1.0" gives more
> realistic render results than other settings?
> ( x) Yes, "assumed_gamma 1.0" is more realistic.
> ( ) No, "assumed_gamma" has no effect on realism.
> ( ) No, "assumed_gamma 1.0" is actually less realistic.
> ( ) Dunno - I haven't heard that claim before.
> ( ) Dunno - I haven't made up my mind yet.
> ( ) Dunno - I don't really care.
> How did you come to that opinion?
> ( ) People say so, and that's good enough for me.
> ( ) The docs imply it, and that's good enough for me.
> ( ) That's what sounds most plausible to me.
> ( x) My own research led me to that conclusion.
> ( ) It can be proven beyond doubt.
> ( ) Dunno - I don't have a clear opinion yet.
> How do you feel about "assumed_gamma 1.0" in POV-Ray 3.7, compared to
> the same setting 3.6?
> ( ) It is an overall improvement.
> ( x) It seems to work just the same.
> ( ) The following behaviour came as a negative surprise to me: [___]
> ( ) Dunno - I don't use it.
> How do you feel about "assumed_gamma 2.2" (or any non-1.0 setting) in
> POV-Ray 3.7, compared to the same setting 3.6?
> ( ) It seems to work just the same.
> ( x) Dunno - I don't use it.
Date: 17 Oct 2016 09:17:25
Message: <5804cf65$1@news.povray.org>
On 16.10.2016 23:13, clipka wrote:
> *NOTE: Please also reply if you don't care!*
> *NOTE: This thread is not intended for discussion!*
> Since the topic of gamma handling has recently been brought to the dev
> team's attention again, I'd like to get a clearer picture of how POV-Ray
> users have come to feel about the issue. Even if you don't care, please
> answer at least the following question:
> (x) Enough to be willing to help you with this survey.
 > (x) Admittedly its been a time since I rendered anything
> (x) POV-Ray 3.7 (or a derivative, e.g. UberPOV, HG-Povray)
> ( ) Other: [___]
> ( ) none
> (x) 1
> ( ) 1.8
> ( ) 2.2
> ( ) srgb
> ( ) Other: [___]
> (x) I think it gives the most accurate results.
> (x) I think it is the recommended setting.
> ( ) Other: [___]
> (x) "rgb"
> ( ) "srgb"
> (x) Other: [I'm used to it and usually define colors manually. I would use srgb if I
got the result from a color picker.]
> (x) "Display_Gamma" INI setting
> (x) "File_Gamma" INI setting
> (x) "gamma" setting for input images
> ( ) Other: [___]
> ( ) "gamma" setting for input images
> ( ) Other: [None]
> ( ) I need them to handle special cases.
> (x) Other: [Defaults appear to be fine. Also I work mostly with PNG where I think
gamma is already considered]
> ( ) I really like it.
> (x) I think it's mostly ok.
   (X) Really I don't worry about it too much. My monitor is also not
well calibrated. While I did a simple calibration procedure it is
probably useless since I adjust brightness depending on what feels
comfortable for the eye in current lighting conditions
> (x) It works like a charm for me.
> (x) See above. But also I don't really remember getting much feedback along
 >     the lines of "your image look super dark to me" etc.
> (x) Yes, "assumed_gamma 1.0" is more realistic.
> (x) That's what sounds most plausible to me.
> ( ) My own research led me to that conclusion.
> (x) It is an overall improvement.
> (x) But also I don't remember what 3.6 did exactly :)
> (x) Dunno - I don't use it.
> What other feedback would you like to give about the gamma handling in
> POV-Ray 3.7?
> [___]
Date: 17 Oct 2016 09:30:02
Message: <5804d25a$1@news.povray.org>
>> (x) "rgb"
>> use srgb if I got the result from a color picker.]
Adding to that I also got the impression linear rgb is more
directly related to the physical characteristics of the material
(even if it is just a 3 element spectrum :D).
Date: 17 Oct 2016 10:05:21
Message: <5804daa1$1@news.povray.org>
> ( ) none
> (x) 1
> ( ) 1.8
> ( ) 2.2
> ( ) srgb
> ( ) Other: [___]
> ( ) Other: [___]
> ( ) "rgb"
> (x) "srgb"
> (x) I get colour values from elsewhere in that format.
> ( ) Other: [___]
> (x) "Antialias_Gamma" INI setting
> ( ) Other: [___]
> ( ) Other: [___]
> (x) I like to toy around with them.
> (x) I like the flexibility they provide.
> (x) I need them to handle special cases.
> ( ) Other: [___]
> ( ) It works like a charm for me.
> (x) It has its quirks, but I can live with them.
> ( ) Yes, "assumed_gamma 1.0" is more realistic.
> ( ) Dunno - I haven't made up my mind yet.>
 > (x) Other: [Accurate. 'realistic' perhaps too subjective a term]
 > (x) Other: [I believe the math more accurate.]
 > (x) Other: [Don't routinely use non-1.0 or compare to 3.6 when I do.]
> POV-Ray 3.7?
Date: 17 Oct 2016 14:00:49
Message: <580511d1$1@news.povray.org>
 > ( ) Enough to be willing to help you with this survey.
 > (X) Thought it was a quiz.
 > (X) POV-Ray 3.7 (or a derivative, e.g. UberPOV, HG-Povray)
 > (X) POV-Ray 3.6 (or a derivative, e.g. MegaPOV, MCPov)
 > ( ) Other: [ I use both. 3.7 for integration with Bishop3d and
 > 3.7/UberPov for speed.]
 > ( ) none
 > ( ) 1
 > ( ) 1.8
 > ( ) 2.2
 > ( ) srgb
 > (X) Other: [1 When I can remember.]
 > ( ) I think it gives the most accurate results.
 > ( ) Other: [I will feel guilty if I don't.]
 > (X) "rgb"
 > ( ) "srgb"
 > (X) I find it easiest to work with.
 > ( ) Other: [___]
 > (X) "Display_Gamma" INI setting
 > ( ) Other: [___]
 > ( ) Other: [___]
 > (X) Other: [N/A]
 > (X) Do not know - I've not thought about it much.
 > (X) I'm still learning to deal with its quirks.
 > ( ) Do not know - I'm not using POV-Ray 3.7.
 > ( ) Do not know - I haven't heard that claim before.
 > (X) Do not know - I haven't made up my mind yet.
 > ( ) Do not know - I don't really care.
 > (X) Do not know - I don't have a clear opinion yet.
 > ( ) The following behaviour came as a negative surprise to me: [I've
not paid much attention, to be honest.]
 > ( ) Do not know - I don't use it.
 > POV-Ray 3.7?
 > [___]
Regards
Date: 17 Oct 2016 14:02:09
Message: <58051221$1@news.povray.org>
On 10/17/2016 7:00 PM, Stephen wrote:
>  > ( ) Other: [ I use both. 3.6 for integration with Bishop3d and >
Regards
Date: 17 Oct 2016 16:44:06
Message: <58053816@news.povray.org>
Am 17.10.2016 um 09:24 schrieb scott:
>> POV-Ray 3.7?
> "assumed_gamma" is still a bit unintuitive IMO in what it actually does.
> I'm pretty sure if you took a person who knew a lot about gamma handling
> but had never used POV before, and asked them what they thought it did,
> they would most likely get it wrong.
Do you think the naming of the setting plays a major role in this, or
would you expect it to be just about as unintuitive under any other name?
Date: 17 Oct 2016 19:10:34
Message: <58055a6a@news.povray.org>
> (*) Enough to be willing to help you with this survey.
> (*) POV-Ray 3.7 (or a derivative, e.g. UberPOV, HG-Povray)
> ( ) Other: [___]
> ( ) none
> (*) 1
> ( ) 1.8
> ( ) 2.2
> ( ) srgb
> ( ) Other: [Did not use in versions before 3.7]
> (*) I find it easiest to work with. Seems more "intuitive" for me.
> ( ) Other: [___]
> (*) "rgb"
> ( ) "srgb"
> ( ) Other: [___]
> (*) "Display_Gamma" INI setting
> (*) "File_Gamma" INI setting
> (*) "Antialias_Gamma" INI setting
> (*) "gamma" setting for input images
> ( ) Other: [___]
> ( ) Other: [___]
> ( ) Other: [___]
> (*) I think it's mostly ok.
> (*) It works like a charm for me.
> (*) Dunno - I don't really care.
> (*) It is an overall improvement.
> (*) Dunno - I don't use it. Never used in 3.6.
> POV-Ray 3.7?
> [___]
Date: 18 Oct 2016 03:25:22
Message: <5805ce62@news.povray.org>
>>> POV-Ray 3.7?
Both I think - AFAIK it effectively does two things (set the gamma
assumed for non-gamma-corrected input values, and set the gamma used in
the internal engine calculations). If it just did one or the other, the
name could probably be more self-explanatory then.
Date: 18 Oct 2016 23:46:44
Message: <5806eca4$1@news.povray.org>
> ( ) Other: [___]
> ( ) none
> ( ) 1
> ( ) 1.8
> ( ) 2.2
> ( ) srgb
> (X) Other: [1.7]
> (X) I think it gives the most pleasing results.
> (X) I think it is the recommended setting.
> ( ) Other: [___]
> (X) "rgb"
> ( ) "srgb"
> ( ) Other: [___]
> ( ) Other: [___]
> ( ) Other: [___]
> ( ) Other: [___]
> (X) I think it's mostly ok.
> (X) It works like a charm for me.
> (X) Dunno - I haven't made up my mind yet.
> (X) My own research led me to that conclusion.
> (X) Dunno - I don't use it.
> POV-Ray 3.7?
> [___]
dik
