POV-Ray : Newsgroups : povray.general : Leaking Animation sample Server Time
16 Mar 2026 14:45:45 EDT (-0400)
  Leaking Animation sample (Message 1 to 10 of 10)
Subject: Leaking Animation sample
Date: 8 May 2016 01:37:28
Message: <572ed098$1@news.povray.org>
Here's a demo of an animation render that leaks memory.
Rotate 2000 spheres about a cylinder while looking down on it.
     Mem      VM
  13,736   7,220 pvengine64.exe @ boot
170,732 169,588 after run #1 (1m 54s)
313,056 313,644 after run #2 (1m 54s)
(standard 640x480 size selected in the dropdown)
povwin command line:
leaktest.ini +SF1 +EF240 -GA
leaktest.ini:
Input_File_Name = leaktest.pov
Width = 720
Height = 480
Quality = 9
Final_Frame = 240
leaktest.pov:
// leaktest.pov
// Make an animation for clipka to demonstrate povwin leaks
// 240 frames
#version 3.7;
global_settings{ assumed_gamma 1.0 }
#default{ finish{ ambient 0.1 diffuse 0.9 }}
#declare Camera_0 = camera {perspective angle 75
   location  <0.0 , 50.0 ,-3.0>
   look_at   <0.0 , 1.0 , 0.0>}
camera{Camera_0}
light_source{< 3000,3000,-3000> color White}
plane { <0,1,0>, 0
	texture { pigment {White}}
// Move a float: from, to, increment
#macro MoveF(_from, _to, __i)
   (_from+((_to-_from)*__i))
#declare Rpos=seed(300);
#declare _maxY=20;
#declare _z = 10;
#local _i=0;
#while (_i<2000)
   #local _startRot=rand(Rpos);
   #local _endRot=rand(Rpos);
   sphere { <0,0,0>, rand(Rpos)*2+.5
     texture {pigment{ color Red }}
     translate<0,rand(Rpos)*_maxY,_z>
     rotate y*MoveF(_startRot, _endRot, clock)*360
   #local _i=_i+1;
Subject: Re: Leaking Animation sample
Date: 8 May 2016 05:32:10
Message: <572f079a$1@news.povray.org>
Am 2016-05-08 01:37, also sprach dick balaska:
Am 2016-05-05 22:50, also sprach clipka:
 > Feel free to email any helpful animation scenes to "christoph", at
 > "lipka-koeln" in the "de" domain.
"Does not follow instructions."
Date: 8 May 2016 10:06:16
Message: <572f47d8$1@news.povray.org>
Am 08.05.2016 um 07:37 schrieb dick balaska:
For starters, I can confirm that it shows significantly different
behaviour than my tests.
I'll have a closer look at why that might be.
Date: 8 May 2016 10:49:06
Message: <572f51e2$1@news.povray.org>
Am 08.05.2016 um 16:05 schrieb clipka:
... and got it.
A true genuine solid memory hole indeed.
Date: 8 May 2016 11:12:54
Message: <572f5776$1@news.povray.org>
Am 08.05.2016 um 16:48 schrieb clipka:
> .... and got it.
Windows binaries will be available in approx. 30 minutes at:
https://github.com/POV-Ray/povray/releases/tag/v3.7.1-alpha.8600570
Date: 8 May 2016 11:18:57
Message: <572f58e1$1@news.povray.org>
>> .... and got it.
Does it impact stable or only master ?
Date: 8 May 2016 11:33:35
Message: <572f5c4f$1@news.povray.org>
Am 08.05.2016 um 17:18 schrieb Le_Forgeron:
>>> .... and got it.
3.7.0 was fine; it's a leak I must have introduced later during one of
my refactoring sprees.
Date: 8 May 2016 17:43:52
Message: <572fb318$1@news.povray.org>
Am 2016-05-08 11:12, also sprach clipka:
WORKSFORME
thanks
dik
Date: 9 May 2016 01:40:01
Message: <web.573021ff5acc868194284cc0@news.povray.org>
> >>> .... and got it.
And you would have gotten away with it if it wasn't for those kids!
Date: 9 May 2016 11:38:37
Message: <5730aefd$1@news.povray.org>
Am 09.05.2016 um 07:37 schrieb jhu:
Yeah; pesky brats, they ruin everything. ;)
