POV-Ray : Newsgroups : povray.general : Question: Area Render Position Server Time
16 Jul 2025 06:13:50 EDT (-0400)
  Question: Area Render Position (Message 1 to 6 of 6)
Subject: Question: Area Render Position
Date: 6 Feb 2016 13:19:28
Message: <56b63930@news.povray.org>
POV-Ray inserted this into the command line parameters, when I made an
area render with an image size of 8000x4500 pixels:
+sc0.248406 +sr0.444099 +ec0.441055 +er0.635475
I finished maybe a bit less than half of that area, had to stop. Now I
want to continue, but need to know, how the float numbers above compute
into row line numbers, because I have to alter "sr" consequently. Thanks.
Subject: Re: Question: Area Render Position
Date: 6 Feb 2016 14:58:53
Message: <56b6507d$1@news.povray.org>
Am 06.02.2016 um 19:19 schrieb Sven Littkowski:
> Hi,
The values specify the start and end in fractions of the screen size; so
e.g. if your image is 1920 by 1200 pixels in size and you specify
+sr0.25 +er0.75, POV-Ray will (or at least should, to the best of my
knowledge) render lines 300 to 899.
Date: 6 Feb 2016 19:15:00
Message: <web.56b68bf5828d5af5f4950fc50@news.povray.org>
Sven Littkowski <jam### [at] yahoocom> wrote:
> Hi,
Why don't you just use the row numbers directly? That is way simpler to use...
Date: 6 Feb 2016 19:54:32
Message: <56b695c8@news.povray.org>
Le 16-02-06 13:19, Sven Littkowski a écrit :
> Hi,
Just change your command line to:
+sc0.248406 +sr0.444099 +ec0.441055 +er0.635475 +c
The render will proceed from where it stopped in the requested area.
Date: 6 Feb 2016 23:09:39
Message: <56b6c383$1@news.povray.org>
Hi.
It is not that I was the one who decided to use float numbers. That was
done by POV-Ray, it is a POV feature: when pressing SHIFT while creating
the area in which to render (inside the render image), POV-Ray copies
then that data into the command line. But that data uses floats, not
line numbers. Well, it makes sense, as this allows you to get the same
area being rendered independently from selected screen size (inside the
QuickRes.ini).
Date: 6 Feb 2016 23:11:08
Message: <56b6c3dc$1@news.povray.org>
Thanks! :-)
