POV-Ray : Newsgroups : povray.general : Random integer Server Time
19 May 2024 20:48:53 EDT (-0400)
  Random integer (Message 13 to 22 of 22)
Subject: Re: Random integer
Date: 2 Feb 2016 02:42:08
Message: <56b05dd0$1@news.povray.org>
On 1-2-2016 16:30, William F Pokorny wrote:
> On 02/01/2016 07:21 AM, Thomas de Groot wrote:
>> On 1-2-2016 13:19, William F Pokorny wrote:
>>> On 02/01/2016 03:06 AM, Thomas de Groot wrote:
>>>> On 1-2-2016 3:10, clipka wrote:
>>>>> Am 01.02.2016 um 02:55 schrieb Mike Horvath:
>>>>>> How do I calculate a random integer between n and p, inclusively?
>>>>> floor( rand(R)*((p-n)+1) + 0.5 )
>>>>> should do the trick
>>>> Why not this: int(RRand(n,p,R))
>>> RRand(Min,Max,RandSeededStream) from rand.inc. To get the inclusive part
>>> of the request I think we need:
>>> int(RRand(n,p+(1-1e-6),R))
>>> or
>>> floor(RRand(n,p+(1-1e-6),R))
>>> Bill P.
>> Are the Min and Max not inclusive by default? I always got that
>> impression.
> For floats yes.
> Mike wants integers so we are using int() or floor(). Seems to me the
> only way we can get the Max integer value is if the rand() function
> returns exactly 1.0 - which it will pretty much never do, but might.
> The +(1-1e-6) makes it so we get the Max integer value only one
> millionth less often than ideally we should.
> We could specify a max integer 1 larger than we really want for p, but
> then rand() will be a troublemaker and give us that 1.0 value in our scene.
> Bill P.
OK. Got it. Thanks a lot!
Date: 4 Feb 2016 21:42:42
Message: <56b40c22$1@news.povray.org>
On 1/31/2016 9:08 PM, Ger wrote:
> Ger wrote:
>>> Thanks
>> #declare RSeed = seed(1);
> #declare RandomNumber = int(n + rand(RSeed) * (p - n));
Shouldn't you use floor instead of int? What if n and p are both  negative?
Mike
Date: 4 Feb 2016 21:45:53
Message: <56b40ce1$1@news.povray.org>
On 1/31/2016 11:27 PM, Sven Littkowski wrote:
> Yes, there are two functions to convert a float to a close-by integer:
> 1. Floor
> If the float is, let's say, "11.4676475" (could be a multiplication of a
> "rand" random result), floor returns "11" (the next integer BELOW that
> float).
> 2. Ceil(ing)
> "rand" random result), floor returns "12" (the next integer ABOVE that
> float).
There is also int, which varies depending on if the number is greater or
less than zero.
Date: 4 Feb 2016 21:49:26
Message: <56b40db6$1@news.povray.org>
>>>>> should do the trick
>>> or
>>> Bill P.
>> impression.
> For floats yes.
> Bill P.
So should I use int or floor? The result is different for numbers below
zero.
Mike
Date: 4 Feb 2016 21:50:15
Message: <56b40de7$1@news.povray.org>
On 1/31/2016 10:16 PM, clipka wrote:
> Am 01.02.2016 um 03:10 schrieb clipka:
>> should do the trick
> ... provided you figure out that you need to add n ;)
> Oops.
Where do I add n?
Date: 4 Feb 2016 22:53:30
Message: <56b41cba$1@news.povray.org>
> zero.
> Mike
Good question. If you have negative integers as part of your potential
integer range, use floor().
Aside: In some languages to really get an integer you need int() too as
in : int(floor(...)) because ceil() and floor() in those languages
return floats.
Bill P.
Date: 5 Feb 2016 02:51:55
Message: <56b4549b$1@news.povray.org>
Am 05.02.2016 um 03:50 schrieb Mike Horvath:
>>> should do the trick
>> Oops.
> Where do I add n?
Never mind -- I also included other nonsense in the formula.
Let me try that again:
    min( n+floor( rand(R)*((p-n)+1) ), p )
The min() is there to ensure that the result is never larger than p,
even if R is so close to 1.0 that the expression in floor() is at some
point rounded up to give a result of (p-n)+1, in which case the entire
expression (without the min()) would result in p+1.
I'm adding n only after rounding, because the lower the magnitude of a
floating point number, the higher its absolute precision.
Date: 5 Feb 2016 02:57:10
Message: <56b455d6$1@news.povray.org>
Am 05.02.2016 um 03:49 schrieb Mike Horvath:
> zero.
In your case you want floor(); otherwise, if your interval includes 0,
too many random numbers will be mapped to 0, and not enough random
numbers will be mapped to 0.
Date: 10 Feb 2016 01:39:16
Message: <56badb14$1@news.povray.org>
On 02/05/2016 08:56 AM, clipka a dit:
>> zero.
*BREAKING NEWS*
Annoucing POVray 3.9, _Now_ with quantum computation !
*wip* http://la.buvette.org/vrac/essai.avi *wip*
Date: 10 Feb 2016 02:34:59
Message: <56bae823$1@news.povray.org>
Am 10.02.2016 um 07:39 schrieb tth:
>>> zero.
> *BREAKING NEWS*
Whoops. That should read, "... and not enough random numbers will be
mapped to n."
Sorry, no support for quantum computers in the near future ;)
