POV-Ray : Newsgroups : povray.general : Random integer Server Time
17 May 2024 05:10:24 EDT (-0400)
  Random integer (Message 11 to 20 of 22)
<<< Previous 10 Messages Goto Latest 10 Messages Next 2 Messages >>>
Subject: Re: Random integer
Date: 1 Feb 2016 07:21:24
Message: <56af4dc4$1@news.povray.org>
On 1-2-2016 13:19, William F Pokorny wrote:
> On 02/01/2016 03:06 AM, Thomas de Groot wrote:
>> On 1-2-2016 3:10, clipka wrote:
>>> Am 01.02.2016 um 02:55 schrieb Mike Horvath:
>>>> How do I calculate a random integer between n and p, inclusively?
>>> floor( rand(R)*((p-n)+1) + 0.5 )
>>> should do the trick
>> Why not this: int(RRand(n,p,R))
> RRand(Min,Max,RandSeededStream) from rand.inc. To get the inclusive part
> of the request I think we need:
> int(RRand(n,p+(1-1e-6),R))
> or
> floor(RRand(n,p+(1-1e-6),R))
> Bill P.
Are the Min and Max not inclusive by default? I always got that impression.
Date: 1 Feb 2016 10:30:14
Message: <56af7a06$1@news.povray.org>
>>>> should do the trick
>> or
>> Bill P.
For floats yes.
Mike wants integers so we are using int() or floor(). Seems to me the
only way we can get the Max integer value is if the rand() function
returns exactly 1.0 - which it will pretty much never do, but might.
The +(1-1e-6) makes it so we get the Max integer value only one
millionth less often than ideally we should.
We could specify a max integer 1 larger than we really want for p, but
then rand() will be a troublemaker and give us that 1.0 value in our
scene.
Bill P.
Date: 2 Feb 2016 02:42:08
Message: <56b05dd0$1@news.povray.org>
>>>>> should do the trick
>>> or
>>> Bill P.
>> impression.
> For floats yes.
> then rand() will be a troublemaker and give us that 1.0 value in our scene.
> Bill P.
OK. Got it. Thanks a lot!
Date: 4 Feb 2016 21:42:42
Message: <56b40c22$1@news.povray.org>
On 1/31/2016 9:08 PM, Ger wrote:
> Ger wrote:
>>> Thanks
>> #declare RSeed = seed(1);
> #declare RandomNumber = int(n + rand(RSeed) * (p - n));
Shouldn't you use floor instead of int? What if n and p are both  negative?
Mike
Date: 4 Feb 2016 21:45:53
Message: <56b40ce1$1@news.povray.org>
On 1/31/2016 11:27 PM, Sven Littkowski wrote:
> Yes, there are two functions to convert a float to a close-by integer:
> 1. Floor
> If the float is, let's say, "11.4676475" (could be a multiplication of a
> "rand" random result), floor returns "11" (the next integer BELOW that
> float).
> 2. Ceil(ing)
> "rand" random result), floor returns "12" (the next integer ABOVE that
> float).
There is also int, which varies depending on if the number is greater or
less than zero.
Date: 4 Feb 2016 21:49:26
Message: <56b40db6$1@news.povray.org>
>>>>> should do the trick
>>> or
>>> Bill P.
>> impression.
> For floats yes.
> Bill P.
So should I use int or floor? The result is different for numbers below
zero.
Mike
Date: 4 Feb 2016 21:50:15
Message: <56b40de7$1@news.povray.org>
On 1/31/2016 10:16 PM, clipka wrote:
> Am 01.02.2016 um 03:10 schrieb clipka:
>> should do the trick
> ... provided you figure out that you need to add n ;)
> Oops.
Where do I add n?
Date: 4 Feb 2016 22:53:30
Message: <56b41cba$1@news.povray.org>
> zero.
> Mike
Good question. If you have negative integers as part of your potential
integer range, use floor().
Aside: In some languages to really get an integer you need int() too as
in : int(floor(...)) because ceil() and floor() in those languages
return floats.
Bill P.
Date: 5 Feb 2016 02:51:55
Message: <56b4549b$1@news.povray.org>
Am 05.02.2016 um 03:50 schrieb Mike Horvath:
>>> should do the trick
>> Oops.
> Where do I add n?
Never mind -- I also included other nonsense in the formula.
Let me try that again:
    min( n+floor( rand(R)*((p-n)+1) ), p )
The min() is there to ensure that the result is never larger than p,
even if R is so close to 1.0 that the expression in floor() is at some
point rounded up to give a result of (p-n)+1, in which case the entire
expression (without the min()) would result in p+1.
I'm adding n only after rounding, because the lower the magnitude of a
floating point number, the higher its absolute precision.
Date: 5 Feb 2016 02:57:10
Message: <56b455d6$1@news.povray.org>
Am 05.02.2016 um 03:49 schrieb Mike Horvath:
> zero.
In your case you want floor(); otherwise, if your interval includes 0,
too many random numbers will be mapped to 0, and not enough random
numbers will be mapped to 0.
