POV-Ray : Newsgroups : povray.general : HLS in color_maps? Server Time
23 Aug 2025 00:59:10 EDT (-0400)
  HLS in color_maps? (Message 1 to 5 of 5)
Subject: HLS in color_maps?
Date: 22 Jan 2016 18:53:12
Message: <56a2c0e8$1@news.povray.org>
I know there is a macro to convert HLS colors into RGB colors. But can
this be done in color_maps?
Mike
Subject: Re: HLS in color_maps?
Date: 22 Jan 2016 19:05:43
Message: <56a2c3d7@news.povray.org>
Am 23.01.2016 um 00:53 schrieb Mike Horvath:
Sure, why not.
Note however that this will /not/ give you colour interpolation in HLS
space.
Date: 22 Jan 2016 19:17:05
Message: <56a2c681$1@news.povray.org>
> Sure, why not.
> space.
I meant being able to go from hls <0,1/2,1> to hls <1,1/2,1> inside the
color_map with smooth gradations.
Mike
Date: 22 Jan 2016 20:28:07
Message: <56a2d727@news.povray.org>
>> Sure, why not.
>> space.
> Mike
Copy the macro in your scene.
Build your colour_map with a loop that goes through the hue values in
relatively small steps, say 0.01 to 0.03.
Use the macro to convert each values to the appropriate RGB values.
That way, the disparity between the two colour spaces are kept small
enough so that they are not perceptible.
The initial copy of the macro is done to speed up the parsing.
Otherwise, you need to read the whole source file each times the macro
is used.
Date: 22 Jan 2016 22:19:01
Message: <56a2f125$1@news.povray.org>
>>> Sure, why not.
>>> space.
>> Mike
> is used.
I guess that's a workaround until I decide to switch to POV-Ray 3.7.1.
Mike
