POV-Ray : Newsgroups : povray.general : Is this a bug? Server Time
14 Jul 2025 17:53:53 EDT (-0400)
  Is this a bug? (Message 32 to 41 of 41)
Subject: Re: Is this a bug?
Date: 20 Jan 2016 15:41:44
Message: <569ff108$1@news.povray.org>
Am 20.01.2016 um 20:31 schrieb clipka:
> - In your example, the 10th (give or take 1) "#declare" in "data.inc"
> happens to be at the very same position as the "#end" of
> ParseCenterOfMass() in your main file.
Slight flaw in my analysis there: I was under the impression "data.inc"
would grow with another line every frame.
Truth is, there is /some/ "#declare" that /sometimes/ coincides in file
position, depending on the values written. That's the case in frame 10,
but not earlier.
Date: 20 Jan 2016 18:08:26
Message: <56a0136a$1@news.povray.org>
> Am 17.01.2016 um 20:43 schrieb Ger:
>> Including a datafile in the main body works, but
>> including it inside a #macro results in an error
>> at random frames in the animation. It can be at
>> frame 10 or at frame 500.
> *HA!*
> Got that son of a bitch!
A fix is available now at https://github.com/POV-Ray/povray (source
code) and https://github.com/c-lipka/povray/releases (semi-official
Windows build).
Date: 20 Jan 2016 19:30:03
Message: <56a0268b@news.povray.org>
>> *HA!*
> Windows build).
Compile fails
Ger
Date: 20 Jan 2016 20:08:03
Message: <56a02f73$1@news.povray.org>
>>> *HA!*
>> Windows build).
> Compile fails
difficult to diagnose. "Compile fails" doesn't grep out of the source code.
Date: 20 Jan 2016 20:14:39
Message: <56a030ff$1@news.povray.org>
>>>> *HA!*
>>> Windows build).
>> Compile fails
:) Yeah, I know. I was still digging at it.
It was just meant as an early shout that something is out of line.
Ger
Date: 20 Jan 2016 20:50:02
Message: <56a0394a$1@news.povray.org>
>>>>> *HA!*
>>>> Windows build).
>>> Compile fails
>> code.
Fails at
make[1]: Entering directory '/home/ger/Downloads/povray-master/source'
depbase=`echo backend/interior/interior.o | sed 's|[^/]*$|.deps/&|;s|
\.o$||'`;\
g++ -DHAVE_CONFIG_H -I. -I..  -I../unix/povconfig -I.. -I../unix -I../vfe -
I../vfe/unix -I/usr/include/SDL -D_GNU_SOURCE=1 -D_REENTRANT -
I/usr/include/OpenEXR  -pthread -I/usr/include  -I/usr/include  -pipe -Wno-
multichar -Wno-write-strings -fno-enforce-eh-specs -Wno-non-template-friend -
s -O3 -ffast-math -march=native -pthread -MT backend/interior/interior.o -MD
-MP -MF $depbase.Tpo -c -o backend/interior/interior.o
backend/interior/interior.cpp &&\
mv -f $depbase.Tpo $depbase.Po
In file included from ./backend/render/trace.h:44:0,
                 from ./backend/interior/media.h:39,
                 from ./backend/interior/interior.h:37,
                 from backend/interior/interior.cpp:36:
./backend/bounding/bbox.h:59:7: error: redefinition of ‘class pov::Rayinfo’
 class Rayinfo
Ger
Date: 21 Jan 2016 00:03:11
Message: <56a0668f$1@news.povray.org>
Am 21.01.2016 um 02:49 schrieb Ger:
>>>>> Windows build).
> Fails at
> \.o$||'`;\
> ../backend/bounding/bbox.h:59:7: error: redefinition of ‘class pov::Rayinfo’
>  class Rayinfo
I have no idea what source code you are compiling there -- it is
definitely /not/ what the doctor prescribed, because all the files
"interior.cpp", "interior.h", "media.h" and "trace.h" and "bbox.h" no
longer reside in the "backend" directory sub-tree.
Let me reiterate: You do /not/ want the "stable" branch. You want "master".
Also, make sure you don't have any zombie source files from the "stable"
branch (or any other older version for that matter) lying around when
building.
The source code in question demonstrably builds fine with both g++ 4.6.3
on Ubuntu 12.04 and with g++ 4.8 on Ubuntu 14.04.
Date: 21 Jan 2016 02:37:13
Message: <56a08aa9$1@news.povray.org>
> building.
You're right, my bad, sorry for that.
I had some old master zip thingy stuck under the keyboard or to the back of
the monitor and mistakenly unpacked that one.
It compiled just fine on a clean installed opensuse tumbleweed. I'll try and
let you know tomorrow about the macro bug story.
Ger
Date: 21 Jan 2016 02:56:30
Message: <56a08f2e$1@news.povray.org>
> and let you know tomorrow about the macro bug story.
This the correct version?
Persistence of Vision(tm) Ray Tracer Version 3.7.1-alpha.8443996.unofficial
(g++
 5 @ x86_64-suse-linux-gnu)
This is an unofficial version compiled by:
Ger
Date: 21 Jan 2016 07:45:01
Message: <web.56a0d27fc0eb7a16ad6fa18f0@news.povray.org>
The 3996 looks familiar.
