POV-Ray : Newsgroups : povray.general : ChromaDepth Server Time
12 Jul 2025 21:10:29 EDT (-0400)
  ChromaDepth (Message 11 to 20 of 20)
Subject: Re: ChromaDepth
Date: 9 Feb 2018 19:20:26
Message: <5a7e3aca$1@news.povray.org>
On 1/19/2016 12:53 PM, clipka wrote:
> Am 19.01.2016 um 11:41 schrieb Mike Horvath:
>>>> Strictly speaking you can expect depth cues to progress in steps:
>>>> There's one fixed distance corresponding to Red, one corresponding to
>>>> Green, and one corresponding to Blue. All of which will depend on your
>>>> display's primary colours.
>>>> Any colour in between just corresponds to a superposition of two
>>>> different depths.
>>>> This is especially true if you have a wide-gamut display, i.e. each
>>>> primary covers only a narrow band of wavelengths.
>>> Are you sure? Yellow definitely looks closer than blue, and blends
>>> smoothly into the neighboring colors.
>>> I *have* noticed a superposition when looking at magenta. It looks both
>>> closer and farther than other colors next to it. It's a hard sensation
>>> to describe.
>>> Mike
>> Forgot to say that this lead me to believe that spectral colors are the
>> only ones that work properly. Magenta is not a spectral color.
> Which is exactly what I'm saying: In computer displays, anything except
> pure Red, pure Green or pure Blue is /never/ a spectral colour -- it's
> always a superposition of those three basic colours.
> In classic displays, even those are not pure spectral colours -- which
> "blurs" them in depth and thus makes the superposition-nature of
> in-between colours less obvious.
> Wide-gamut displays, on the other hand, require comparatively "pure"
> primary colours to achieve their wide gamut, which "sharpens" them in
> depth, and thus will easily reveal the superposition-nature of
> in-between colours.
I was reading their website the other day, and found their technical page:
http://chromatek.com/what-is-chromadepth/chromadepth-technical-explanation/
According to them, the glasses work on computer displays and printed
materials too.
Quote: "On a black background, red will appear closest, blue furthest,
and the other colors will fall in-between according to their place in
the rainbow (red, orange, yellow, green, blue)."
So, any color should work okay, not just the primaries.
Mike
Date: 9 Feb 2018 19:54:50
Message: <5a7e42da$1@news.povray.org>
On 1/17/2016 11:07 PM, Mike Horvath wrote:
> I created the following pigment to be used with ChromaDepth glasses:
>      pigment
>          gradient vnormalize(Camera_Location - Camera_LookAt) * -1
>          color_map
>              [0/4 srgb <1,0,0,>]
>              [1/4 srgb <1,1,0,>]
>              [2/4 srgb <0,1,0,>]
>              [3/4 srgb <0,1,1,>]
>              [4/4 srgb <0,0,1,>]
>          scale vlength(Camera_Location - Camera_LookAt) * 100
>          translate Camera_Location
> However, the relationship between distance and color is linear in my
> example. How do I change this so that the hue is based on atan(distance
> from camera)? Thanks!
> Mike
I am now using a macro.
	#macro MakeChromadepthTexture(CameraLocation, CameraLookAt)
		pigment
			spherical
			color_map
				#for (i, 0, 240, 1)
					[i/240 color rgb CHSL2RGB(<240 - i, 1, 1/2>)]
	//	finish
	//		ambient 1
	//		diffuse 0
		scale vlength(CameraLocation - CameraLookAt) * 2
		translate CameraLocation
But my question is the same. How do I replace `spherical` with
`atan(distance from camera)`? Possibly, the camera measurements will no
longer be necessary.
Thanks.
Mike
Date: 15 Feb 2018 15:24:18
Message: <5a85ec72$1@news.povray.org>
There is some OpenGL shader code here, but I don't know how to read it.
http://web.engr.oregonstate.edu/~mjb/chromadepth/
Mike
Date: 15 Feb 2018 18:45:01
Message: <web.5a861b745228b0755cafe28e0@news.povray.org>
Looks like if you wanted to do that, it's just an HSV-style color map / gradient
in the z-direction.
Just take your object and scale the pattern to that z-size.
Date: 16 Feb 2018 21:47:10
Message: <5a8797ae@news.povray.org>
> in the z-direction.
That's what I'm doing, currently.
Mike
Date: 17 Feb 2018 00:24:38
Message: <5a87bc96$1@news.povray.org>
I found a paper which proposes an alternate color interpolation for the
same glasses. Instead of using red, green and blue to encode depth, the
new method uses red, white and blue.
https://graphics.tudelft.nl/Publications-new/2014/SE14a/
How would I create a pigment that works like this? Thanks.
Mike
Download 'teaser.jpg' (92 KB)
Preview of image 'teaser.jpg'
Date: 17 Feb 2018 02:55:11
Message: <5a87dfdf$1@news.povray.org>
Maybe this?
   gradient z
   color_map {
     [0.00 Red]
     [0.50 White]
     [1.00 Blue]
   scale <1, 1, DepthOfScene>
Maybe you have to switch Blue and Red. Not sure.
Date: 17 Feb 2018 05:52:06
Message: <5a880956$1@news.povray.org>
>> the same glasses. Instead of using red, green and blue to encode
>> depth, the new method uses red, white and blue.
> Maybe this?
> pigment {
>    gradient z
>    color_map {
>      [0.00 Red]
>      [0.50 White]
>      [1.00 Blue]
Would spherical be better than gradient? That's what I've been using.
Mike
Date: 17 Feb 2018 07:24:49
Message: <5a881f11$1@news.povray.org>
>> Maybe this?
>> pigment {
>>    gradient z
>>    color_map {
>>      [0.00 Red]
>>      [0.50 White]
>>      [1.00 Blue]
Yes indeed. See this test file I found in my archives.
Download 'tdg_depth_map.pov.txt' (3 KB)
Date: 21 Feb 2018 03:31:33
Message: <5a8d2e65$1@news.povray.org>
On 1/16/2016 12:53 AM, Mike Horvath wrote:
> http://chromatek.com/what-is-chromadepth/design-guide-2/
> I've been reading their documentation, but I can't figure out if the
> progression from near to far is linear or not. I.e. is blue just as far
> from green as green is from blue? Or is it exponential? I plan on doing
> some experiments in the near future, but I can't figure out for sure
> whether this is the case.
> Mike
Okay, I asked on Stack Exchange, but no one wanted to bite and the topic
got closed. No feedback as always.
https://physics.stackexchange.com/questions/385827/chromadepth-glasses
Mike
