POV-Ray : Newsgroups : povray.general : Rent a server? Server Time
19 May 2024 10:48:32 EDT (-0400)
  Rent a server? (Message 10 to 19 of 19)
<<< Previous 9 Messages Goto Initial 10 Messages
Subject: Re: Rent a server?
Date: 28 Jan 2016 21:17:22
Message: <56aacbb2@news.povray.org>
On 1/15/2016 10:36 PM, Mike Horvath wrote:
> About how much would it cost to rent a server or cluster just for
> POV-Ray? Is the rate usually an hourly one? Does anyone have experience
> in this? Thanks.
> Mike
I got a email reply from FoxRenderfarm also. They do not support POV-Ray.
Mike
Date: 28 Jan 2016 21:54:52
Message: <56aad47c$1@news.povray.org>
I found this:
http://blog.megafaunasoft.com/2015/02/worlds-cheapest-render-farm.html
However, you are limited to 60 seconds of render time (or what happens?)
and you have to use node.js (what is it?).
Date: 28 Jan 2016 22:40:14
Message: <56aadf1e$1@news.povray.org>
> in this? Thanks.
> Mike
Hi Mike,
Have you seen this thread in the news group?
http://news.povray.org/povray.general/thread/%3Cweb.4fcd1a5e61bffe2de3f6250f0@news.povray.org%3E/
Here "cloud rendering" is not to be confused with POV-Ray's rendering of
clouds. :-)
Folks have done it as you'll see in the thread. I have only a couple
times started to investigate the possibility - always getting side
tracked before trying. The Amazon web services spot prices look
reasonably cheap to me, but they are variable.
Bill P.
Date: 29 Jan 2016 00:32:57
Message: <56aaf989@news.povray.org>
On 1/28/2016 10:40 PM, William F Pokorny wrote:
> Hi Mike,
> clouds. :-)
> Bill P.
Thanks for the tip. I read through the tutorial you linked to
https://aws.amazon.com/blogs/compute/better-together-amazon-ecs-and-aws-lambda/
and this:
https://github.com/awslabs/lambda-ecs-worker-pattern
but still don't understand what to do. For instance, the instructions
don't mention whether you have to install POV-Ray on the VM yourself, or
if it comes pre-installed.
It is all very complex.
Mike
Date: 29 Jan 2016 00:40:20
Message: <56aafb44$1@news.povray.org>
>> Hi Mike,
>> clouds. :-)
>> Bill P.
> and this:
> Mike
Also, do I need to be running Linux on my local machine in order to
follow the tutorial?
Mike
Date: 29 Jan 2016 08:57:55
Message: <56ab6fe3$1@news.povray.org>
>> and this:
>> Mike
> Mike
:-) Please remember, in me, you are asking someone who hasn't yet done
it himself.
Firstly, I am not aware of any canned, off the shelf, solution ready to
run POV-Ray on a render farm / in the cloud. If that is what you want,
the thread I pointed out isn't the path. If you find a canned solution,
you are likely to pay extra for the work others have done to provide
such a service.
Yes, a VM with POV-Ray installed would need to be created. The most
useful part of the AWS article/tutorial - which is mostly about other
AWS features - is the section showing how to do this VM set up for
Ubuntu 14.04 with POV-Ray.
I don't believe you need to be running linux locally.
Bill P.
Date: 29 Jan 2016 10:43:16
Message: <56ab8894$1@news.povray.org>
On 1/29/2016 8:57 AM, William F Pokorny wrote:
>The most
Where does it say this? I must have overlooked it.
Mike
Date: 29 Jan 2016 10:55:58
Message: <56ab8b8e$1@news.povray.org>
>> The most
> Mike
Also, are you charged for the time it takes to set up the VM?
Mike
Date: 29 Jan 2016 16:29:59
Message: <56abd9d7$1@news.povray.org>
>>> The most
>> Mike
> Mike
I don't know. The answers are out there somewhere. :-)
If I again get interested & successfully work through it myself, I'll
post my experience.
Likewise, if you get something going or find a ready cloud service for
POV-Ray rendering, please let us know.
Bill P.
Date: 30 Jan 2016 07:28:26
Message: <56acac6a$1@news.povray.org>
I have contacted two render farm services and told them about POV-Ray.
They might install it, they say. Let's see.
But my advise is, to encourage any render farm you meet to enable
POV-Ray rendering, too.
