POV-Ray : Newsgroups : povray.general : Spiral tube? Server Time
30 Jun 2025 18:44:28 EDT (-0400)
  Spiral tube? (Message 11 to 20 of 20)
Subject: Re: Spiral tube?
Date: 8 Jan 2016 13:24:31
Message: <568ffedf$1@news.povray.org>
On 1/6/2016 12:48 AM, Mike Horvath wrote:
> How do I create a spiral tube, like a spring? Like this:
> http://www.f-lohmueller.de/pov_tut/animate/anim16e.htm
> but a single object, not a union of spheres?
> Thanks!
> Mike
I found this parametric function online:
http://math.stackexchange.com/questions/461547/whats-the-equation-of-helix-surface
1. How do I turn this into POV-Ray code?
2. Can I fill this shape with a gas that is denser in the middle of the
tube and less dense at the tube's surface?
Mike
Date: 8 Jan 2016 14:51:07
Message: <5690132b$1@news.povray.org>
>> Thanks!
>> Mike
> Mike
You don't need to convert that parametric function.
You can get that exact shape using f_helix1 or f_helix2 whitch are
builtin function. Builtin functions are inheritently faster than user
defined functions as they use compiled code.
P0 is set to 1 to get only a single helix. Non integer may cause
unexpected results. (not used if f_helix2)
P1, P2 and P3 are renamed to reflect their functions.
P4 elongate the section along the Y axis. Set to 1 to leave the shape
unchanged. (not used if f_helix2)
P5 is set to 1 whitch correspond to a circular section.
0 = square section.
1 = circular section
2 = losange section (I don't get it that a square rotated 45° could be
called "diamond")
 >2 = concave losange section, may become degenarate if larger than 3.
For a circular section, P6 have no effect. It rotate the section shape
when it's not circular.
Start with the following:
f_helix1(x,y,z, 1, Period_per_unit, Minor_radius, major_radius, 1, 1, 0)
or
f_helix2(x,y,z, 0, Period_per_unit, Minor_radius, major_radius, 0, 1, 0)
Both are designed for a threshold of zero. Evaluate as <0 inside, 0 at
the surface and >0 outside.
Negate the function used to use it to controll your media.
Sample from i_internal.pov that you can find in the sample scenes (frame
26, frame 27 for f_helix2):
#declare LCorner = <-1.5, -2.9, -1.5>;
#declare RCorner = <1.5, 2.9,  1.5>;
isosurface {
	function { f_helix1(x,y,z, 1, 8, 0.3, 0.9, 0.6, 0.2, 0) }
		//P0= number of helixes
		//P1= frequency
		//P2= minor radius
		//P3= major radius
		//P4= Y scale cross section
		//P5= cross section
		//P6= cross section rotation (¡)
	contained_by { box { LCorner, RCorner } }
	max_gradient 1.5
	texture { IsoTexture }
	no_shadow
	scale 1.9  rotate z*-54
Date: 8 Jan 2016 15:11:53
Message: <56901809$1@news.povray.org>
>>> Thanks!
>>> Mike
>> Mike
> 0 = square section.
> called "diamond")
> or
> isosurface {
>          //P1= frequency
>          //P2= minor radius
>          //P3= major radius
>          //P5= cross section
>      max_gradient 1.5
>      no_shadow
> Alain
The problem is that the isosurface is clipped within a box. This means
the edges of the cut are not perpendicular to the curve. It looks bad.
Mike
Date: 8 Jan 2016 16:02:14
Message: <569023d6$1@news.povray.org>
>> Thanks!
>> Mike
> Mike
The docs say that parametric objects are hollow. Can they have interiors?
Mike
Date: 8 Jan 2016 16:06:18
Message: <569024ca$1@news.povray.org>
>>> Thanks!
>> In a modeller, this is pretty easy, for instance building a spiral line
>> segment (aka a spline) and an appropriate surface to follow it. However,
>> that may not be what you want.
> generating a spline along an helix is rather easy. Then if sphere_sweep
> is acceptable, the problem is solved.
> Now, do you considere sphere_sweep a single object ?
Can a spline accurately mimic a helix?
Mike
Date: 8 Jan 2016 16:07:59
Message: <5690252f$1@news.povray.org>
Am 08.01.2016 um 21:12 schrieb Mike Horvath:
Make the isosurface container a bit larger, and use difference to cut
away the ends.
Date: 8 Jan 2016 16:10:57
Message: <569025e1$1@news.povray.org>
> away the ends.
I will still need to calculate the tangent of the curve at the cutoff
points. This may be more trouble than it's worth.
Mike
Date: 8 Jan 2016 17:48:55
Message: <56903cd7$1@news.povray.org>
Am 08.01.2016 um 22:06 schrieb Mike Horvath:
>>>> Thanks!
A natural, bezier or other cubic spline -- nope, not precisely.
I read somewhere that a non-uniform rational B-spline /could/ do the
trick (not sure if that's true), but POV-Ray does not support those.
Date: 8 Jan 2016 17:50:43
Message: <56903d43$1@news.povray.org>
Am 08.01.2016 um 22:11 schrieb Mike Horvath:
>> away the ends.
If it's a simple helix, the corresponding formula should be easy to come
up with.
Date: 9 Jan 2016 12:13:51
Message: <56913fcf$1@news.povray.org>
>>>>> Thanks!
But, if you are willing to throw in enough points, the error can be kept
low enough that it's not visible.
