POV-Ray : Newsgroups : povray.general : Cloud Rendering? Server Time
14 Jan 2026 20:32:58 EST (-0500)
  Cloud Rendering? (Message 1 to 10 of 13)
Subject: Cloud Rendering?
Date: 22 Dec 2015 04:19:36
Message: <567915a8@news.povray.org>
I heard about cloud rendering, and would like to learn more about it.
If I have a scene to be rendered, or even an entire animation (where the
parsing of one single image takes already over 10 minutes), the cloud
rendering would help me greatly.
How to use such a cloud rendering? Please advise me. Thanks.
Subject: Re: Cloud Rendering?
Date: 22 Dec 2015 12:31:27
Message: <567988ef@news.povray.org>
Parsing takes over 10 minutes, rendering takes more than an entire night
-for ONE frame!
Date: 23 Dec 2015 03:02:58
Message: <567a5532$1@news.povray.org>
> -for ONE frame!
I would suggest that you build your scene objects using an external
modeller like Blender. Resulting mesh2 objects render much faster than
traditional POV-Ray constructs.
Date: 23 Dec 2015 04:46:43
Message: <567a6d83$1@news.povray.org>
Hi.
I try since over ten, 15 years to learn using modellers, but i find them
way too hard to learn. It is much easier for me, to write out of my mind
the coordinate numbers. Seeing all these numbers and functions, I can
easily imagine the scene. Sounds strange, but that's me. Can't change.
Besides, I wished, I could use modellers and therefore meshes...
Date: 23 Dec 2015 04:47:18
Message: <567a6da6$1@news.povray.org>
But that does not give me information, if there is something like Cloud
Rendering I can use.   :-)
Date: 23 Dec 2015 07:22:29
Message: <567a9205$1@news.povray.org>
I don't know. I have heard about render farms from time to time in these
newsgroups here in the past.
Date: 23 Dec 2015 07:35:00
Message: <web.567a93b188dc8b57ac6323910@news.povray.org>
Go to http://www.povray.org/search/ and type fastclouds.pov.txt in the Search
field.
Date: 23 Dec 2015 08:02:23
Message: <567a9b5f$1@news.povray.org>
This thread may be of interest.
http://news.povray.org/povray.general/thread/%3Cweb.4fcd1a5e61bffe2de3f6250f0@news.povray.org%3E/
Regards
Date: 23 Dec 2015 10:46:56
Message: <567ac1f0$1@news.povray.org>
Have you ever tried to drive a modeller from a scripting language? You
can write Python scripts to create geometry in Blender, OpenSCAD is
exclusively driven from scripts, and FreeCAD also allows you to drive it
from Python scripts.
Another alternative maybe worth considering, if you are after
animations, is to write a script to drive the GPU in your machine. You
can do some pretty complex stuff in realtime (or near realtime) on
modern GPUs. For examples look up "shadertoy".
 > -for ONE frame!
Have you looked down every avenue to optimise the scene? There are
usually a lot of shortcuts and tricks that work to speed up complex scenes.
Date: 23 Dec 2015 13:11:24
Message: <567ae3cc@news.povray.org>
I did some optimization to that extend I am knowing, thanks to other
users here. I try to declare each item only one time and then multiply
that declared item if I need it several times.  :-)
