POV-Ray : Newsgroups : povray.general : Latitude, longitude, radius pattern? Server Time
25 Feb 2026 09:51:58 EST (-0500)
  Latitude, longitude, radius pattern? (Message 1 to 5 of 5)
Subject: Latitude, longitude, radius pattern?
Date: 21 Aug 2015 00:19:17
Message: <55d6a6c5$1@news.povray.org>
How would I create a checker pattern that wraps around a globe? I would
like the checker to alternate between latitude, longitude, etc. Thanks!
Mike
Subject: Re: Latitude, longitude, radius pattern?
Date: 21 Aug 2015 01:04:22
Message: <55d6b156$1@news.povray.org>
Am 21.08.2015 um 06:19 schrieb Mike Horvath:
"Checker pattern and a spherical warp" would be my first thought.
Date: 21 Aug 2015 01:19:44
Message: <55d6b4f0$1@news.povray.org>
Hash: SHA256
>> would like the checker to alternate between latitude, longitude,
>> etc. Thanks!
sphere { 0,av_ra
checker texture { pigment { color rgb <1,1,0> } },texture { pigment
{color rgb 0.5} }
 scale 1/4 warp { spherical orientation y } } }
you can adjust the frequency of alternating by tuning the scale 1/4 to
your need, even with a non uniform scale.
av_ra is the radius of your globe.
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2
iJwEAQEIAAYFAlXWtO8ACgkQhKAm8mTpkW08CwQArMiLp2P1MnvfGZku14Ajnc3m
MjdceqGAAKPAyUJAm55d1trNbovtY5rnSpGNgMljji5ruI92Eq85ti9S7hCcXTK0
WTjN16Tcjhs5kljCkMVdoYTQNhe9eB55kY4V8BzUrNfoKiCCV/wvYvw/BC7Y0nXZ
FSQZnqlXqqVo/8C/Tjc=
=7G3o
-----END PGP SIGNATURE-----
Date: 21 Aug 2015 01:37:08
Message: <55d6b904$1@news.povray.org>
I forgot I did this once before for an object collection item. I ended
up copying the code and re-using it.
#declare latitude_pigment_1 = pigment
	radial
	color_map
		[0.5 color srgb <040,066,018>/255]
		[0.5 color srgb <067,084,029>/255]
	frequency longitude_div/2
#declare latitude_pigment_2 = pigment
	radial
	color_map
#declare radius_pigment = pigment
	function {f_r(x,y,z)}
	pigment_map
		[0 color srgb 1/2]
		[1 latitude_pigment_1]
#declare longitude_pigment = pigment
	function {f_ph(x,y,z)/pi}
	pigment_map
		[0.5 latitude_pigment_1]
		[0.5 latitude_pigment_2]
	frequency longitude_div/4
#declare checker_sphere_pigment = pigment {longitude_pigment}
Date: 22 Aug 2015 01:15:30
Message: <op.x3q7jxcnufxv4h@xena>
On Fri, 21 Aug 2015 07:37:17 +0200, Mike Horvath <mik### [at] gmailcom>
> 	radial
> 	color_map
> 	radial
> 	color_map
> 	pigment_map
> 		[0 color srgb 1/2]
> 	pigment_map
I was going to post something similar to this, but with a gradient map for
the longitude pigment. Yours is more accurate anyway.
-Nekar Xenos-
