POV-Ray : Newsgroups : povray.general : free CAD software supporting POV-Ray Server Time
25 Feb 2026 11:33:10 EST (-0500)
  free CAD software supporting POV-Ray (Message 1 to 9 of 9)
Subject: free CAD software supporting POV-Ray
Date: 3 Jun 2015 06:56:59
Message: <556edd7b@news.povray.org>
Hi folks,
looks like there's a free 3D CAD package out there that can generate
POV-Ray files, yet hasn't gotten any attention in these newsgroups yet
whatsoever.
The software is aptly named "FreeCAD". It has been under development
since 2001 based on the Open Cascade CAD kernel, and is currently
available for Windows, Linux and Mac OS.
See http://www.freecadweb.org/ for details.
Subject: Re: free CAD software supporting POV-Ray
Date: 3 Jun 2015 07:31:04
Message: <556ee578$1@news.povray.org>
Looks interesting. I shall investigate
John
Protect the Earth
It was not given to you by your parents
You hold it in trust for your children
Date: 3 Jun 2015 08:24:26
Message: <556ef1fa$1@news.povray.org>
It does. I might have a look myself.
Regards
Date: 3 Jun 2015 08:31:07
Message: <556ef38b$1@news.povray.org>
Is there an echo in here?
Regards
Date: 3 Jun 2015 10:06:23
Message: <556f09df$1@news.povray.org>
Interesting. However, it has a strong 1990's flavour and appearance.
Maybe useful for architectural purposes but I guess I shall not use it
overly much. Thanks for the tip though.
Date: 3 Jun 2015 11:34:13
Message: <556f1e75$1@news.povray.org>
> whatsoever.
Unfortunately it seems to convert all geometry to a mesh before
exporting to POV :-( I was hoping that finally someone had written a
proper POV exporter from CAD data...
As a CAD tool though it looks an excellent introduction and hobby tool.
Perfect for creating those "engineered" type objects (especially with
lots of rounded edges) with the same parametric flexibility that you
have in SDL.
Date: 8 Jun 2015 11:27:36
Message: <5575b468$1@news.povray.org>
Another alternative I just came across is a web-based CAD package called
"onshape". It allows export of stl files which can be converted to POV
meshes with stl2pov, and more importantly when exporting it allows you
to specify the parameters used when generating the mesh.
It's still in beta at the moment, and it looks like the free version
allows you to work on up to 5 projects at once.
Date: 9 Aug 2015 03:12:32
Message: <55c6fd60$1@news.povray.org>
On 6/3/2015 6:56 AM, clipka wrote:
> Hi folks,
> whatsoever.
Couple of questions that you might not be able to answer.
1. What 3D format does it use natively? What can it import and export?
2. Can I recreate this script using it?
http://lib.povray.org/searchcollection/index2.php?objectName=LegoRoad&version=2.5.5&contributorTag=SharkD
3. How does it handle materials/textures? Can they be generated
programmatically as well or are only bitmap textures supported?
Mike
Date: 28 Sep 2015 13:45:06
Message: <web.56097c3bcec2ef8cbf08205f0@news.povray.org>
> > whatsoever.
> have in SDL.
I started using FreeCAD because of its scripting capabilities.  I've been using
it to build a model of a spaceship (Tajemnica, from a novel by Rolf Nelson).
It's a nice tool for that job because I can place walls and attach stuff to
them, then move them and everything just follows.
And yes, the POVray export machinery generates meshes, which is not a good thing
for anything that isn't flat.  But here too, the Python scripting machinery can
help.  I added machinery to define the desired POVray object definition as part
of the definition of the objects in my model.  That works very nicely.
So I get a way to interact with a model, then once I like it I get a POVray
equivalent I can raytrace.
