POV-Ray : Newsgroups : povray.general : solid parametric Server Time
28 Dec 2025 07:24:00 EST (-0500)
  solid parametric (Message 1 to 3 of 3)
Subject: solid parametric
Date: 23 Feb 2015 02:53:06
Message: <54eadc62$1@news.povray.org>
Is there any way I can turn this into something with thickness? I want
to create a spiral ramp for people to walk upon.
	#local Fx = function(u,v) {u*cos(v)}
	#local Fy = function(u,v) {u*sin(v)}
	#local Fz = function(u,v) {v}
	#local platform_ramp_1 = object
		Parametric(Fx,Fy,Fz,<0,0>,<1,pi>,12,12,"")
		rotate +x * 90
		rotate -y * 90
		scale y/pi
		translate y
Subject: Re: solid parametric
Date: 23 Feb 2015 04:05:46
Message: <54eaed6a$1@news.povray.org>
>          rotate +x * 90
>          rotate -y * 90
>          scale y/pi
>          translate y
Fx, Fy and Fz describes so far a single segment (in regard to u) that is
rotated and translated according to v.
If you want some thickness, you probably want v to keep its current
effect, but need to describe more than a segment with u. basic idea
would be to have u runs along a rectangle.
Such rectangle could be the vertical section, so Fz would be impacted,
or it could be the horizontal section (keeping Fz simple)
As an horizontal section, it does not have to be a rectangle, a kind of
triangle could do it too (with a round edge at the exterior of the ramp).
To break the functions of Fx and Fy in three parts, you can use
select(), especially the form with 4 arguments.
#local Fx = function(u,v){ select( floor(u)-1, u*cos(v),
cos(v+factor*(u-1)), (3-u)*cos(v) ) }
#local Fy = function(u,v){ select( floor(u)-1, u*sin(v),
sin(v+factor*(u-1)), (3-u)*sin(v) ) }
and of course, the range of u is now 0 to 3 insteand of 0 to 1.
Notice: untested code, you might have to test and amend it. (factor
should be replaced with hardcoded value, it is in radian the angle of
the triangle (at the axis of the ramp))
Just because nobody complains does not mean all parachutes are perfect.
Date: 24 Feb 2015 18:59:27
Message: <54ed105f$1@news.povray.org>
This is beyond me. My algebra is not very good.
