POV-Ray : Newsgroups : povray.general : Re-render same subsection? Server Time
28 Dec 2025 07:23:53 EST (-0500)
  Re-render same subsection? (Message 1 to 6 of 6)
Subject: Re-render same subsection?
Date: 19 Feb 2015 22:55:05
Message: <54e6b019$1@news.povray.org>
Is there a way to re-render the same pixel sub-section of an image over
and over again without manually entering in the column and row numbers?
Thanks.
Subject: Re: Re-render same subsection?
Date: 20 Feb 2015 02:27:22
Message: <54e6e1da$1@news.povray.org>
> Thanks.
If you use an INI file to start your render. You can define the column
and rows.
> 3.2.2.3 Partial Output Options
If you use the animation features you can do multiple renders.
> 3.2.1.3 Subsets of Animation Frames
Regards
Date: 20 Feb 2015 16:48:28
Message: <54e7abac@news.povray.org>
>> Thanks.
> and rows.
Not what I'm looking for, but thanks.
Date: 20 Feb 2015 18:55:05
Message: <54e7c959$1@news.povray.org>
>> Thanks.
> and rows.
yep ... that's how I'd do it I have the following in my Options.ini file:
[Middle]
+sc0.25
+sr0.25
+ec0.75
+er0.75
re-read that section and see if that's /really/ the ticket!
Date: 22 Feb 2015 09:46:44
Message: <54e9ebd4@news.povray.org>
Am 20.02.2015 um 04:55 schrieb Mike Horvath:
> Thanks.
While using the mouse to select a region to render from the render
output window, press the shift key to have POV-Ray automatically enter
column and row numbers for you.
Date: 22 Feb 2015 23:14:39
Message: <54eaa92f$1@news.povray.org>
>> Thanks.
This is what I needed. Thanks!
