POV-Ray : Newsgroups : povray.general : moray 3.7 problem -- won't render Server Time
23 Aug 2025 07:01:40 EDT (-0400)
  moray 3.7 problem -- won't render (Message 1 to 8 of 8)
Subject: moray 3.7 problem -- won't render
Date: 7 Jan 2015 22:03:53
Message: <54adf399$1@news.povray.org>
I was testing out moray 3.7 windows.
was checking out some of the mdl samples that came with it.
did the usual, export it to povray and then render it. the render part
didn't work.  got a message saying:
"moray has stopped working, a problem caused the program to stop working
correctly.  windows will close the program and notify you of a solution"
I'm not really familiar with windows version of moray.  My prior
experience was with Moray (forget what version) dos version in the late
'90s; 1998-1999 before I abandoned it due to computer's slow render times.
Back then, I was on OS/2.
now, I'm on win7.
Dilbert Firestorm
remove *byteme* to email me
Subject: Re: moray 3.7 problem -- won't render
Date: 8 Jan 2015 01:31:53
Message: <54ae2459$1@news.povray.org>
Moray only works with PovRay version 3.5. Sorry.
Regards
Date: 8 Jan 2015 01:40:02
Message: <web.54ae2638ccaa00add19b0ec40@news.povray.org>
Could you save to Pov format and just edit the file to be able to render in
Povray 3.7 instead?
Date: 8 Jan 2015 02:00:58
Message: <54ae2b2a$1@news.povray.org>
> Povray 3.7 instead?
I do that with Bishop3D, now freeware. Start the render in Pov 3.6 and
load it in Pov 3.7, manually.
Regards
Date: 8 Jan 2015 03:05:48
Message: <54ae3a5c$1@news.povray.org>
> Povray 3.7 instead?
Yes that is the way to go with Moray. Export the scene to POV-Ray and
render in version 3.7. Otherwise, it is a good idea to have POV-Ray 3.5
along too. You can test your scenes and only in the final version export
and change for POV-Ray 3.7. It was what I did for years before I stopped
using Moray.
Date: 10 Jan 2015 05:04:59
Message: <54b0f94b$1@news.povray.org>
> Povray 3.7 instead?
I guess that is one way to do it.
Dilbert Firestorm
Date: 10 Jan 2015 05:11:18
Message: <54b0fac6@news.povray.org>
found this, settings for moray 3.5 & povray 3.7 under win7
anyone try it?  He doesn't say what the compatibility settings were in
the properties folder.
from the moray.win newsgroup:
On 4/20/2011 5:49 AM, MartinB wrote:
> Hi there,
>   +++ I FOUND A SOLUTION +++
> I was also looking for a solution of running Moray 3.5 and POV-Ray 3.x
> integrated under Windows 7 Enterprise 64bit.
> I discovered that the version of POV-Ray is not the matter. No povray version
> did run on my machine properly!
> So I checked out the TROUBLESHOOTING from the Win7 Control Panel. Here is what I
> did:
> PART I (moray):
> - I clicked 'Run programs made for previous versions of Windows'
> - 'Next' to get to a list of old progs.
> - select Moray...
> - on the next page clicked on 'Try recommended settings'
> - on the next page clicked 'Start the program...'
>    Them Moray started and I loaded a scene - fine.
> - clicked next and pressed 'Yes, save the settings for this program'
> - closed the troubleshooter
> PART II (POV-ray):
> - select POV-Ray...
> - clicked 'TROUBLESHOOT PROGRAM'
> - selected the first three checkboxes (in other words all, except 'I dont see
> my...'
> - clicked 'next' and selected WinXP SP2 (SP3 might also do)
> - clicked 'next' and selected 4th and 5th checkbox:
>     'Program does not display properly...'
>     'Windows controls appear cut off...'
> - POV-Ray started fine and the Demo render was successful.
> NOW I CAN DO THE F9 (Raytrace) in MORAY - YEAH!!
> I hope that helps
> Regards,
>    Martin  :-)
Dilbert Firestorm
Date: 10 Jan 2015 06:53:35
Message: <54b112bf$1@news.povray.org>
Try Vista and if that doesn't work XP should.
It won't work with Pov 3.7 IIRC but it will work with Pov 3.5.
Regards
