POV-Ray : Newsgroups : povray.general : Anyone use datetime? Server Time
27 Sep 2024 05:25:08 EDT (-0400)
  Anyone use datetime? (Message 1 to 10 of 15)
Subject: Anyone use datetime?
Date: 20 Nov 2014 14:51:33
Message: <546e4645@news.povray.org>
I'm having some trouble.
I'm trying to have POV write datetime to a file in the form:
// Made Wednesday 11-19-2014 07:33 PM
Everything is fine except the hour: it was 1:33 PM
Here what I wrote:
#write(Mfile,"// Made ",datetime(now,"%A %m-%d-%Y %I:%M %p"),"\n")
The (%I) above, I got from my C++ book and don't have a C book.
I don't think there can be much different between them.
Is there something I missing, or is this a POV 3.7 bug?
Subject: Re: Anyone use datetime?
Date: 20 Nov 2014 15:16:26
Message: <546e4c1a$1@news.povray.org>
datetime is from boost.
Your date format is not correct. '-' is for iso 8601, american's date
should use '/'. Iso 8601 is YEAR-Month-Day (the '-' might be omitted in
non-extended format)
There is only one format for date, Iso 8601. All other formats are doomed.
The difference of 6 hours might be due to your timezone (which you did
not print, or its settings somewhere): give a try to "%z", "%Z" or "%ZP"
IQ of crossposters with FU: 100 / (number of groups)
IQ of crossposters without FU: 100 / (1 + number of groups)
IQ of multiposters: 100 / ( (number of groups) * (number of groups))
Date: 20 Nov 2014 15:26:15
Message: <546e4e67$1@news.povray.org>
My bad, povray's datetime is using strftime(), after getting the LC_TIME
environment variable from your environment.
Yep, "%z" or "%Z" might give you a clue about the actual clock.
If you are running something like Windows, the traditional setting of
the bios clock might be "local clock" (and that's not a good idea).
Bios clock are better as UTC clock (Never adjust them on Day-saving
change). Even better, sync them with NTP servers.
Date: 20 Nov 2014 17:50:02
Message: <546e701a@news.povray.org>
Thanks for the quick reply!
  I have Windows XP.
While I was waiting I played with the 'now' in datetime() and figured my
  NOW is .25 to big so I subtracted it and works find :)
       datetime(now-.25,String format)
While playing I found that all the format options in C++ work as
expected, except %I and %H.(both hour formats where 6 hour off)
  You said that datetime uses strftime(), after getting the LC_TIME
environment variable from my environment. Perhaps that is what's off or
the bios. Looks like I need to play some more.
  I've used strftime() before to write a time stamp program to place the
time/date in a POV file and to write a calender program.
  Before I go I have to tell ya about my fun with 'now'.
I put zero in just to what would happen. I got the same date and time as
POV docs. Then for fun I through in bigger numbers, I don't remember all
the different numbers I use but I did get Wednesday 6/22/1926 out of
one. I have to check it out on my calender. It was right!
Thanks for the help, looks like I have some work to do!
Date: 20 Nov 2014 23:43:21
Message: <op.xpnrefddufxv4h@xena.home>
> On Thu, 20 Nov 2014 22:16:24 +0200, Le_Forgeron <jgr### [at] freefr>
> doomed.
Agreed. All other formats don't make sense.
-Nekar Xenos-
Date: 21 Nov 2014 00:22:11
Message: <546ecc03$1@news.povray.org>
Looking at your message's header, I see that you are in -0600 timezone.
That might explain the .25 difference
For the programmers that might want to look at it:
Computation of now is done as follow:
boost::posix_time::ptime y2k(boost::gregorian::date(2000,1,1));
now(boost::posix_time::microsec_clock::universal_time());
Val = (now-y2k).total_microseconds() * (1.0e-6) / (24*60*60);
It's the number of days since 2000-01-01 (fractional part as the time in
day)
datetime adjust the value to convert back to the number of seconds since
1970-01-01 00:00:00 ( it's rounded to the nearest second )
From that number, the date is rebuild via:
std::tm t =
boost::posix_time::to_tm(boost::posix_time::from_time_t(timestamp));
vlen = strftime(val, PARSE_NOW_VAL_LENGTH, FormatStr, &t);
Date: 22 Nov 2014 12:46:41
Message: <5470cc01@news.povray.org>
Your right about the time zone. I check out every thing you said. No luck.
So is the problem my XP or is it in POV 3.7?
Date: 22 Nov 2014 13:07:44
Message: <5470d0f0$1@news.povray.org>
>> doomed.
> ---Nekar Xenos-
I disagree. The format you use should be job specific and a matter of
taste. The information you want to convey and to whom is important to
what format you use. Degrees of Freedom. That's what I like!
Date: 22 Nov 2014 13:58:18
Message: <op.xpqpnb1oufxv4h@xena.home>
>>> doomed.
>>  ---Nekar Xenos-
Well since you put it that way, I can't disagree with you :)
-Nekar Xenos-
Date: 24 Nov 2014 04:11:12
Message: <5472f630$1@news.povray.org>
you forget the third component: the one between the screen and the chair
(no offense intended), it's the one that matter in the end.
You can either:
* move your XP to have its clock as UTC (but that might be problematic
for some already installed programs). Btw, the XP clock does not show
any UTC setting, at best you can opt for Greenwich without summer-saving
adjustment.
* add a %z or similar in the format string to copy the time-zone setting
(so 1:30pm local is displayed 7:30pm -0600 ), then the date and time
should be correct but its reading is harder (that's where the third
component came in play)
* if your script is local (not to be shared with someone in Tokyo),
adjust the now parameter as now-0.25 for your situation (and season, yep
you can be screwed in 6 months by a different offset)
Just because nobody complains does not mean all parachutes are perfect.
