POV-Ray : Newsgroups : povray.general : Manipulating rendered pixels Server Time
28 Sep 2024 15:13:31 EDT (-0400)
  Manipulating rendered pixels (Message 1 to 4 of 4)
Subject: Manipulating rendered pixels
Date: 27 Mar 2014 20:41:29
Message: <5334c539$1@news.povray.org>
Hello,
I would like to know if there is a way of reading the resulting pixel
value in the rendered image as it is being rendered and if it is
possible to overwrite it with another value. Possibly based on the
original color.
This is for testing lighting on a scene. If the color at the pixel is
above a certain value it should be marked with another color and would
let me know that the image is being saturated with too much light. Not a
scientifically rigorous method but it works well for most cases.
I can do this manually by just rendering, in EXR or HDR format, the
scene using only a simple diffuse white material for all. Then, after
rendering, load the render into a high-dynamic image viewer or editor to
see if there are any places on the scene that are too bright.
I already looked at ImageMagick but it just overkill for what I need.
FlyerX
Subject: Re: Manipulating rendered pixels
Date: 27 Mar 2014 22:41:55
Message: <5334e173@news.povray.org>
> Hello,
> original color.
> FlyerX
Reading a rendered pixel DURING render? Not possible without patching
and recompiling.
I can propose some alternatives:
Render the scene with a lower light level, say, dividing all
light_source intensity by 10 or some other value.
Have some mirror with a reflection value of 1/8, 1/32 or less showing
the areas where you suspect are affected by clipping.
Date: 29 Mar 2014 06:06:59
Message: <53369b43$1@news.povray.org>
On 3/27/2014 9:43 PM, Alain wrote:
>> Hello,
>> original color.
>> FlyerX
> and recompiling.
> Alain
Thanks for the tip. I think I found an easy way to get an idea of
saturated colors: rendering in HDR/EXR format with Display_Gamma=0.01.
Any colors above 1 will still show.
FlyerX
Date: 26 May 2014 13:32:59
Message: <53837acb$1@news.povray.org>
Am 29.03.2014 11:06, schrieb FlyerX:
Holy cow, here's some smart thinking!
