POV-Ray : Newsgroups : povray.general : pov editor for windows (replacing numbers with text) Server Time
15 Jan 2026 00:59:44 EST (-0500)
  pov editor for windows (replacing numbers with text) (Message 1 to 3 of 3)
Subject: pov editor for windows (replacing numbers with text)
Date: 2 Mar 2014 10:24:33
Message: <53134d31@news.povray.org>
I noticed something odd with the pov editor for windows when I decided to
replace a number with some text using the Search/Replace menu item.
When I replaced the number, whether with plain "replace" or "replace all",
the text appears in all upper case.  When I tried to replace the "replaced"
text with some lower case text, the lower case text was converted to upper
case as well.  Is there some editor setting that I am unaware of that is
causing this?  Does this occur for other operating systems as well?  Any
info or suggestions will be appreciated.
p.s. for now, if I run into this situation again, I'll just use my word
processor program to replace the numbers.
Subject: Re: pov editor for windows (replacing numbers with text)
Date: 2 Mar 2014 10:35:18
Message: <53134fb6$1@news.povray.org>
> to replace a number with some text using the Search/Replace menu item.
> all", the text appears in all upper case.  When I tried to replace the
> "replaced" text with some lower case text, the lower case text was
> converted to upper case as well.  Is there some editor setting that I am
> unaware of that is causing this?  Does this occur for other operating
> systems as well?  Any info or suggestions will be appreciated.
Did you check the boxes for 'match case' or 'preserve case'? That should
take care of the problem.
Date: 3 Mar 2014 06:30:01
Message: <web.531466f85c0a5672c2d977c20@news.povray.org>
> > to replace a number with some text using the Search/Replace menu item...
> [and Thomas wrote...]
I've never come across this problem in Windows. (I assume you're typing ctrl/H
to bring up the 'Find & Replace' menu.) The replaced text *should* show up in
the proper case, even with all the boxes left un-checked. A mystery.
