POV-Ray : Newsgroups : povray.general : And once again: compiling and installing 3.7 under Debian Linux... Server Time
12 Nov 2026 01:49:43 EST (-0500)
  And once again: compiling and installing 3.7 under Debian Linux... (Message 1 to 43 of 43)
Subject: And once again: compiling and installing 3.7 under Debian Linux...
Date: 6 Feb 2014 19:11:28
Message: <52f424b0$1@news.povray.org>
Hi(gh)!
I just downloaded the zip package from povray.org, unzipped it into my
home directory... changed to the "unix" directory, read the instructions
in install.txt - but even failed to perform only the first command,
./configure COMPILED_BY="Jörg 'Yadgar' Bleimann <yaz### [at] gmxde>", as
there is no configure program at all!
Where do I have to look?!?
See you in Khyberspace!
Yadgar
Subject: Re: And once again: compiling and installing 3.7 under Debian Linux...
Date: 6 Feb 2014 19:46:32
Message: <52f42ce8$1@news.povray.org>
Jörg 'Yadgar' Bleimann wrote:
> Hi(gh)!
In povray.unix
I dropped a script there to configure/compile/install povray on suse linux.
You should be able to convert it to what you want.
Ger
Date: 6 Feb 2014 23:48:35
Message: <52f465a3$1@news.povray.org>
Am 07.02.2014 01:15, schrieb Jörg 'Yadgar' Bleimann:
> Hi(gh)!
> ../configure COMPILED_BY="Jörg 'Yadgar' Bleimann <yaz### [at] gmxde>", as
Note that the zip package is /not/ a Unix source code package, but a
generic platform-independent one; as such it does not conform to the
typical unixoid conventions.
In order to turn the generic source code package into a Unix-specific
one, you'll have to run "prebuild.sh" from the "./unix" directory.
Among other things, this will create the "./configure" script in the
main directory, which then in turn generates the files needed by "make".
Date: 7 Feb 2014 19:44:13
Message: <52f57ddd$1@news.povray.org>
Hi(gh)!
...which lead to an error message:
error: requires autoconf 2.59 or above
When trying to install autoconf via apt-get, I discovered that the
Debian repositories only keep the 2.13 version! And now?
Yadgar
Now playing: Cover Me (Bruce Springsteen)
Date: 8 Feb 2014 05:36:29
Message: <52f608ad$1@news.povray.org>
On 02/07/2014 07:48 PM, Jörg 'Yadgar' Bleimann wrote:
> Hi(gh)!
http://www.gnu.org/software/autoconf/#downloading
Date: 8 Feb 2014 06:25:35
Message: <52f6142f$1@news.povray.org>
> Hi(gh)!
or try ...
apt-cache search autoconf
i see:
autoconf - automatic configure script builder
autoconf-doc - automatic configure script builder documentation
autoconf2.13 - automatic configure script builder (obsolete version)
autoconf2.64 - automatic configure script builder (obsolete version)
autotools-dev - Update infrastructure for config.{guess,sub} files
autoconf-archive - Autoconf Macro Archive
autoconf-gl-macros - autoconf macros to check for OpenGL/GLU/GLUT
autoconf2.59 - automatic configure script builder (obsolete version)
Date: 8 Feb 2014 11:59:40
Message: <52f6627c$1@news.povray.org>
Hi(gh)!
O.k., now I managed to install an autoconf version higher than 2.59 (and
also automake) just to be able to do prebuild.sh... then I started
./configure - and now it complains about the missing boost libraries!
Which packages exactly do I have to install now?
Yadgar
Date: 8 Feb 2014 12:46:23
Message: <52f66d6f$1@news.povray.org>
On 02/08/2014 12:03 PM, Jörg 'Yadgar' Bleimann wrote:
> Hi(gh)!
apt-get build-dep libboost-all-dev
apt-get install libboost-all-dev
Date: 8 Feb 2014 14:16:45
Message: <52f6829d$1@news.povray.org>
Hi(gh)!
I did that - and got the error message as follows:
checking whether the Boost::Thread library is available... no
configure: error: cannot find a suitable boost thread library
Where do I get that "thread library"?
Yadgar
Date: 8 Feb 2014 20:34:52
Message: <52f6db3c$1@news.povray.org>
On 02/08/2014 02:20 PM, Jörg 'Yadgar' Bleimann wrote:
> Hi(gh)!
did you use sudo on apt-get commands?
what does you configure command looks like ... did you add appropriate
options? http://wiki.povray.org/content/User:Le_Forgeron/vault/Compilation
Date: 8 Feb 2014 21:40:00
Message: <web.52f6e987f58cc046d19b0ec40@news.povray.org>
=?ISO-8859-1?Q?J=F6rg_=27Yadgar=27_Bleimann?= <yaz### [at] gmxde> wrote:
> Hi(gh)!
> Yadgar
Check the unix section. There are several threads regarding compiling on various
Unix-like system.s
Date: 9 Feb 2014 08:02:18
Message: <52f77c5a$1@news.povray.org>
Hi(gh)!
Not sudo, but generally as su!
I tried Jerômes version for Ubuntu 13.04, g++ version 4.7.3 and got this:
- same as before.
The version for Ubuntu 13.10, g++ version 4.8.1:
checking whether the C compiler works... no
configure: error: in `/home/yadgar/povray-3.7-stable':
configure: error: C compiler cannot create executables
See `config.log' for more details
Why is this all so [beeeeep!] complicated?!? I'm about to contemplate
whether I should change to a 64-bit Windows XP system rather than
Linux... but I do not want to be online under Windows!!! And my wohnklo
(German colloquial for "tiny little apartment") is too small for two big
desktops!
Yadgar
Date: 9 Feb 2014 09:51:22
Message: <52f795ea$1@news.povray.org>
On 02/09/2014 08:06 AM, Jörg 'Yadgar' Bleimann wrote:
> Hi(gh)!
>> options?
> - same as before.
well geee whizzzz the above tells me you don't even have the correct
build environment yet ... you need to get the compiler working first.
apt-cache search build-essential
also of interest (povray basic requirements):
apt-get install zlib1g-dev libpng12-dev libjpeg-dev libtiff5-dev
optional:
apt-get install libopenexr-dev
apt-get build-dep libsdl1.2-dev
apt-get install libsdl1.2-dev
> desktops!
No it's not really complicated ... just new to you. If you're not
willing to dig in and learn it, maybe switching is the right answer, but
hey IMHO building binaries on windows machines is WAY more involved.
Date: 9 Feb 2014 10:10:01
Message: <web.52f799adf58cc046d19b0ec40@news.povray.org>
Well, let's start at the beginning:
1) What kind of computer are you running?
2) What OS are you using? (Debina? Ubuntu? Mint? SteamOS?)
3) If all else fails, I or someone else can compile a static binary and send it
to you.
With regard to boost, I have not had any problems with downloading, compiling,
and installing the boost libraries from www.boost.org (actually only need to
compile two of the threading libraries, but I install all of it anyway).
Date: 9 Feb 2014 10:11:24
Message: <52f79a9c$1@news.povray.org>
On 02/09/2014 02:06 PM, Jörg 'Yadgar' Bleimann a dit:
    Because having a working boost is a moving target ?
http://foo.bar.quux.over-blog.com/article-thsf-2013-114632120.html
Date: 9 Feb 2014 10:15:00
Message: <web.52f79accf58cc046d19b0ec40@news.povray.org>
Have you been using Povray 3.6 this whole time? Were you able to compile any of
the 3.7RCs during the past year?
Date: 9 Feb 2014 11:27:54
Message: <52f7ac8a$1@news.povray.org>
look at his last post ;-)
Date: 9 Feb 2014 11:45:01
Message: <web.52f7afdff58cc046d19b0ec40@news.povray.org>
Doesn't say what OS he's using. He just says he tried instructions for Ubuntu
13.10 and 13.04. That doesn't tell us what OS he's actually using. Assuming apt
works on his system, he could be running any Debian-based OS (Debian, Ubunt,
Mint, SteamOS, etc.).
Date: 9 Feb 2014 12:22:48
Message: <52f7b968@news.povray.org>
lol ... only after posting did I consider that I'd made too big of an
assumption
Date: 9 Feb 2014 18:00:11
Message: <52f8087b$1@news.povray.org>
Hi(gh)!
sbuild - Tool for building Debian binary packages from Debian sources
build-essential - Informal list of packages needed to generate packages
devscripts - Scripts to make the life of a Debian package attendant easier
dh-buildinfo - debhelper enhancement to track package versions used in
building of a package
Is that enough?
Note: »libjpeg62-dev« chosen instead of »libjpeg-dev«
Error: Package libtiff5-dev cannot be found.
Error: Package libopenexr-dev cannot be found.
The following packages have unresolved dependences:
libaa1-dev : depends on: libslang2-dev but shall not be installed
               depends on: libncurses5-dev but shall not be installed
  libarts1-dev : depends on: libartsc0-dev (= 1.5.9-3+b2) but shall not
be installed
                 depends on: libglib2.0-dev but shall not be installed
                 depends on: libjack0.100.0-dev
                 depends on: libmad0-dev but shall not be installed
                 depends on: libogg-dev but shall not be installed
                 depends on: libqt3-mt-dev (>= 3:3.3.5) but shall not be
installed
                 depends on: libvorbis-dev but shall not be installed
  libasound2-dev : depends on: libasound2 (= 1.0.23-2.1)
  libcaca-dev : depends on: libcaca0 (= 0.99.beta17-1) but 0.99.beta18-1
shall be installed
  libdirectfb-dev : depends on: libdirectfb-1.2-9 (= 1.2.10.0-4) but
1.2.10.0-5 shall be installed
                    depends on: libdirectfb-extra but shall not be installed
                    depends on: libfreetype6-dev but shall not be installed
                    depends on: libjpeg-dev
                    depends on: libpng12-dev but shall not be installed
                    depends on: zlib1g-dev (>= 1:1.1.3) soll aber nicht
installiert werden
                    depends on: libsysfs-dev but shall not be installed
  libesd0-dev : depends on: libesd0 (= 0.2.41-8) but 0.2.41-10+b1 shall
be installed
                depends on: esound-common (= 0.2.41-8) but 0.2.41-10
shall be installed
  libgl1-mesa-dev : depends on: libgl1-mesa-glx (= 7.7.1-6) but
8.0.5-4+deb7u2 shall be installed
  libglu1-mesa-dev : depends on: libglu1-mesa (= 7.7.1-6) but
  libpulse-dev : depends on: libpulse0 (= 0.9.21-3+squeeze1) but 2.0-6.1
shall be installed
                 depends on: libpulse-mainloop-glib0 (=
0.9.21-3+squeeze1) but 2.0-6.1 shall be installed
                 depends on: libpulse-browse0 (= 0.9.21-3+squeeze1) but
                 depends on: libavahi-client-dev but shall not be installed
  libsvga1-dev : depends on: libsvga1 (= 1:1.4.3-29) but 1:1.4.3-33
shall be installed
  libx11-dev : depends on: libx11-6 (= 2:1.3.3-4+squeeze1) but
2:1.5.0-1+deb7u1 shall be installed
               depends on: libxau-dev (>= 1:1.0.0-1) but shall not be
installed
               depends on: libxdmcp-dev (>= 1:1.0.0-1) but shall not be
installed
               depends on: libxcb1-dev but shall not be installed
  libxext-dev : depends on: libxext6 (= 2:1.1.2-1+squeeze1) but
2:1.3.1-2+deb7u1 shall be installed
                depends on: x11proto-xext-dev (>= 7.0.99.2) but shall
not be installed
  libxt-dev : depends on: libxt6 (= 1:1.0.7-1+squeeze1) but
1:1.1.3-1+deb7u1 shall be installed
              depends on: libsm-dev soll aber nicht installiert werden
  libxv-dev : depends on: libxv1 (= 2:1.0.5-1+squeeze1) but
2:1.0.7-1+deb7u1 shall be installed
Error: Build dependences for libsdl1.2-dev could not be resolved.
  libsdl1.2-dev : Depends on: libsdl1.2debian (= 1.2.14-6.1) but
1.2.15-5 shall be installed
                  Depends on: libx11-dev shall not be installed
                  Depends on: libglu1-mesa-dev shall not be installed
                  Depends on: libasound2-dev shall not be installed
                  Depends on: libartsc0-dev shall not be installed
                  Depends on: libesd0-dev shall not be installed
                  Depends on: libpulse-dev shall not be installed
                  Depends on: libdirectfb-dev (>= 0.9.22) shall not be
installed
                  Depends on: libsvga1-dev shall not be installed
                  Depends on: libaa1-dev shall not be installed
                  Depends on: libcaca-dev shall not be installed
                  Depends on: libxt-dev shall not be installed
                  Depends on: libxext-dev shall not be installed
Error: Problems cannot be corrected, you have defect packages held back.
I'm fed up with it... Linux sucks!!!
I give up! Linux sucks!
I want my Commodore 64 back!
Yadgar
Date: 9 Feb 2014 18:02:15
Message: <52f808f7$1@news.povray.org>
Hi(gh)!
A hexacore AMD Phenom.
Debian stable 6.0.5.
> to you.
O.k....
When I tried to install 3.7 RC3 back in 2011, I did this - and wrecked
my entire system! Please not again!
Yadgar
Date: 9 Feb 2014 18:03:19
Message: <52f80937$1@news.povray.org>
Hi(gh)!
Yes, I did.
No, I wasn't.
Yadgar
Date: 9 Feb 2014 19:05:00
Message: <52f817ac@news.povray.org>
LOL ... should have seen this coming a mile away.
Date: 9 Feb 2014 21:30:00
Message: <web.52f8398cf58cc046d19b0ec40@news.povray.org>
> Hi(gh)!
> > to you.
> O.k....
> Yadgar
Check http://news.povray.org/povray.binaries.misc/ in a few minutes. A static
binary for povray should show up momentarily.
Date: 10 Feb 2014 00:20:03
Message: <web.52f86163f58cc046d19b0ec40@news.povray.org>
Oops! The last one I posted was compiled for Ivy Bridge. I posted a new one
compiled for Phenom. It should run faster. Again, it' in the binary/misc area.
Date: 10 Feb 2014 07:44:36
Message: <52f8c9b4$1@news.povray.org>
Hi(gh)!
I downloaded it, but I couldn't open it, neither with Ark nor with
another archive manager - it simply seems to contain nothing at all!
Perhaps I'm just to stupid for raytracing, I should content myself with
drinking beer and watching TV, like all the other rednecks...
See you in Huntsville, Alabama!
Yadgar
Date: 10 Feb 2014 08:35:13
Message: <52f8d591$1@news.povray.org>
On 02/10/2014 07:48 AM, Jörg 'Yadgar' Bleimann wrote:
> Hi(gh)!
>> new one
>> binary/misc area.
both archives downloaded and extracted fine on my end ... perhaps bz2
format isn't supported. I'm using ark as well and IIRC bz2 support was
/not/ part of the standard install
trust me ... Huntsville Alabama is /not/ the redneck capital world. Oh
and BTW: ... it's moonshine not beer
Date: 10 Feb 2014 09:15:01
Message: <web.52f8ddfdf58cc046d19b0ec40@news.povray.org>
> Hi(gh)!
> Yadgar
apt-get install bzip2
Date: 10 Feb 2014 09:30:00
Message: <web.52f8e143f58cc046d19b0ec40@news.povray.org>
ok, uploaded a gzipped version. Check again.
Date: 10 Feb 2014 09:35:01
Message: <web.52f8e2bdf58cc046d19b0ec40@news.povray.org>
Well, this is silly. Looks like the file gets zipped or gzipped or something
when it's uploaded (even though I've already gzipped it!!!) so you'll need to
double gunzip it as follows:
cat povray.barcelona.gz | gunzip | gunzip > povray
Date: 10 Feb 2014 09:51:42
Message: <52f8e77e$1@news.povray.org>
Hi(gh)!
apt says bzip2 is already installed!
Yadgar
Date: 10 Feb 2014 09:58:44
Message: <52f8e924@news.povray.org>
Hi(gh)!
That (respectively doing it with Ark) worked generally... but obviously,
you included only the bare executable, so povray does not find any
configuration file, neither system-wide nor user specific! Can I use
POV-Ray 3.6's configuration file (at least for the time being)?
Yadgar
Date: 10 Feb 2014 11:25:01
Message: <web.52f8fc92f58cc046e82a2b810@news.povray.org>
> Hi(gh)!
> Yadgar
From the main povray source you downloaded, copy the following directories to
/usr/local/share/povray-3.7
ini
include
scenes
scripts
The only thing that's really neceasary is what's in the include directory.
Date: 11 Feb 2014 19:03:38
Message: <52faba5a$1@news.povray.org>
Hi(gh)!
> ini
> include
> scenes
> scripts
After having also copied povray.conf and povray.ini into the respective
(newly created) directories, it works fine... thank you for compiling, jhu!
Two issues remain: firstly, I still get a warning message "Problem with
option setting", and, as already with 3.6 on my Linux system, I have no
proper preview window, instead of displaying the scene, merely the
non-white parts of backdrop (non-POV-Ray) windows are tinted. I assume
that this is a problem of my graphics driver... do you know of any
workarounds for this (in earlier installations of Debian Linux, I in
fact had a real rendering preview!)?
Yadgar
Now playing: To Germany With Love (Alphaville)
Date: 11 Feb 2014 19:15:00
Message: <web.52fabbe6f58cc046d19b0ec40@news.povray.org>
> Hi(gh)!
> > ini
> > include
> > scenes
> > scripts
> Yadgar
Glad it works now! With regard to preview window, I don't know. It's not
something I've noticed mainly because I'm usually rendering on headless
computers.
Date: 11 Feb 2014 19:22:11
Message: <52fabeb3$1@news.povray.org>
On 02/11/2014 07:07 PM, Jörg 'Yadgar' Bleimann wrote:
> Hi(gh)!
>> directories to
>> ini
>> include
>> scenes
>> scripts
in regards to the lack of preview window, perhaps the binary was built
without libsdl (simple directmedia layer) ... see what povray --version
returns (hint look for X Window display enabled/disabled)
Date: 11 Feb 2014 19:25:05
Message: <web.52fabf29f58cc046d19b0ec40@news.povray.org>
> computers.
Looks like it's compiled with X window disabled. That's probably why there's no
preview window. Let me see if I can enable X window support...
Date: 11 Feb 2014 19:25:17
Message: <52fabf6d$1@news.povray.org>
> computers.
IIRC I used to have to run 3.6 with the option -visual DirectColor. I
put an alias in my ~/.bashrc thus:
alias povray=povray\ -visual\ DirectColor
I haven't had to do this for 3.7. But it might be worth trying it.
BTW Are you running Gnome or KDE? What version?
John
Protect the Earth
It was not given to you by your parents
You hold it in trust for your children
Date: 11 Feb 2014 19:30:15
Message: <52fac097$1@news.povray.org>
Oops. I posted at the same time as jhu and Jim. They seem to have the
solution. I hadn't thought that jhu might have compiled with the display
disabled.
John
Protect the Earth
Date: 11 Feb 2014 22:35:00
Message: <web.52faeab6f58cc046d19b0ec40@news.povray.org>
> > computers.
Unfortunately, not able to compile a static binary with X Window support.
Incidentally, I can compile a dynamic binary with X Window support, but that is
unlikely to work on your system since I'm compiling on Ubuntu 12.04.
Date: 12 Feb 2014 09:29:02
Message: <52fb852e$1@news.povray.org>
HI(gh)!
> computers.
No monitor at all? Blind POVing... fascinating!
Yadgar
Date: 12 Feb 2014 22:43:59
Message: <52fc3f7f$1@news.povray.org>
On 02/12/2014 03:33 PM, Jörg 'Yadgar' Bleimann a dit:
   Not fascinating. Just efficiency.
http://foo.bar.quux.over-blog.com/article-annlor-fait-des-bulles-121970031.html
Date: 14 Feb 2014 11:45:01
Message: <web.52fe46e6f58cc046d19b0ec40@news.povray.org>
Posted a new binary in misc section. It should be 8% faster the current one you
have. But don't take my word for it. Try testing it via the benchmark.
