POV-Ray : Newsgroups : povray.general : And once again: compiling and installing 3.7 under Debian Linux... Server Time
23 Jun 2026 00:56:47 EDT (-0400)
  And once again: compiling and installing 3.7 under Debian Linux... (Message 1 to 10 of 43)
Subject: And once again: compiling and installing 3.7 under Debian Linux...
Date: 6 Feb 2014 19:11:28
Message: <52f424b0$1@news.povray.org>
Hi(gh)!
I just downloaded the zip package from povray.org, unzipped it into my
home directory... changed to the "unix" directory, read the instructions
in install.txt - but even failed to perform only the first command,
there is no configure program at all!
Where do I have to look?!?
See you in Khyberspace!
Yadgar
Subject: Re: And once again: compiling and installing 3.7 under Debian Linux...
Date: 6 Feb 2014 19:46:32
Message: <52f42ce8$1@news.povray.org>
Jörg 'Yadgar' Bleimann wrote:
> Hi(gh)!
> ./configure COMPILED_BY="Jörg 'Yadgar' Bleimann <yaz### [at] gmxde>", as
In povray.unix
I dropped a script there to configure/compile/install povray on suse linux.
You should be able to convert it to what you want.
Ger
Date: 6 Feb 2014 23:48:35
Message: <52f465a3$1@news.povray.org>
> Hi(gh)!
Note that the zip package is /not/ a Unix source code package, but a
generic platform-independent one; as such it does not conform to the
typical unixoid conventions.
In order to turn the generic source code package into a Unix-specific
one, you'll have to run "prebuild.sh" from the "./unix" directory.
Among other things, this will create the "./configure" script in the
main directory, which then in turn generates the files needed by "make".
Date: 7 Feb 2014 19:44:13
Message: <52f57ddd$1@news.povray.org>
Hi(gh)!
...which lead to an error message:
error: requires autoconf 2.59 or above
When trying to install autoconf via apt-get, I discovered that the
Debian repositories only keep the 2.13 version! And now?
Yadgar
Now playing: Cover Me (Bruce Springsteen)
Date: 8 Feb 2014 05:36:29
Message: <52f608ad$1@news.povray.org>
> Hi(gh)!
http://www.gnu.org/software/autoconf/#downloading
Date: 8 Feb 2014 06:25:35
Message: <52f6142f$1@news.povray.org>
> Hi(gh)!
or try ...
apt-cache search autoconf
i see:
autoconf - automatic configure script builder
autoconf-doc - automatic configure script builder documentation
autoconf2.13 - automatic configure script builder (obsolete version)
autoconf2.64 - automatic configure script builder (obsolete version)
autotools-dev - Update infrastructure for config.{guess,sub} files
autoconf-archive - Autoconf Macro Archive
autoconf-gl-macros - autoconf macros to check for OpenGL/GLU/GLUT
autoconf2.59 - automatic configure script builder (obsolete version)
Date: 8 Feb 2014 11:59:40
Message: <52f6627c$1@news.povray.org>
Hi(gh)!
O.k., now I managed to install an autoconf version higher than 2.59 (and
also automake) just to be able to do prebuild.sh... then I started
./configure - and now it complains about the missing boost libraries!
Which packages exactly do I have to install now?
Yadgar
Date: 8 Feb 2014 12:46:23
Message: <52f66d6f$1@news.povray.org>
> Hi(gh)!
apt-get build-dep libboost-all-dev
apt-get install libboost-all-dev
Date: 8 Feb 2014 14:16:45
Message: <52f6829d$1@news.povray.org>
Hi(gh)!
I did that - and got the error message as follows:
checking whether the Boost::Thread library is available... no
configure: error: cannot find a suitable boost thread library
Where do I get that "thread library"?
Yadgar
Date: 8 Feb 2014 20:34:52
Message: <52f6db3c$1@news.povray.org>
> Hi(gh)!
did you use sudo on apt-get commands?
what does you configure command looks like ... did you add appropriate
options? http://wiki.povray.org/content/User:Le_Forgeron/vault/Compilation
