POV-Ray : Newsgroups : povray.general : Macro problem Server Time
29 Jul 2024 02:24:36 EDT (-0400)
  Macro problem (Message 1 to 10 of 13)
Subject: Macro problem
Date: 11 Oct 2013 03:55:01
Message: <web.5257adf44d8f0d3941a177270@news.povray.org>
I'm trying to write a macro that randomly either returns -1 or 1. This is what I
have:
#macro randsign()
 #if (rand(HPlanet_Seed_Value) > 0.5)
  1
 #else
  -1
However, POVray stops rendering and says "All #declares of float, vector, and
 color require semi-colon ';' at end if the language version is set to 3.5 or
 higher."
What am I doing wrong? Adding the semi-colon causes the scene to quit for other
reasons.
Subject: Re: Macro problem
Date: 11 Oct 2013 05:25:00
Message: <web.5257c34630eb22c641a177270@news.povray.org>
I'm using RC7 by the way.
> have:
> #macro randsign()
>   1
>  #else
>   -1
>  #end
> #end
>  higher."
> reasons.
Date: 11 Oct 2013 06:10:01
Message: <web.5257cd4e30eb22c6e83c0f490@news.povray.org>
> > have:
> > #macro randsign()
> >   1
> >  #else
> >   -1
> >  #end
> > #end
> >  higher."
> > reasons.
I tried your code, but got no idea about this semi-colon issue.
This one works for me:
#declare Zufall=seed(317);
#macro randsign()
   #local Z1=rand(Zufall)-0.5;
   Z1/abs(Z1)
#declare Count=0;
#while(Count<100)
   #declare ZufallsZahl=randsign();
   #debug concat("Zufallszahl: ",str(ZufallsZahl,8,4),"\n")
   #declare Count=Count+1;
Best regards,
Michael
Date: 11 Oct 2013 06:15:01
Message: <web.5257ce9030eb22c6e83c0f490@news.povray.org>
> > have:
> > #macro randsign()
> >   1
> >  #else
> >   -1
> >  #end
> > #end
> >  higher."
> > reasons.
Better thsi one:
#macro randsign()
   #if (Z1=0) Z1=0.1; #end     // avoid division by zero
   Z1/abs(Z1)
#declare Count=0;
#while(Count<100)
Message: <web.5257ced630eb22c641a177270@news.povray.org>
> > > have:
> > > #macro randsign()
> > >   1
> > >  #else
> > >   -1
> > >  #end
> > > #end
> > >  higher."
> > > reasons.
> #macro randsign()
>    Z1/abs(Z1)
> #end
> #declare Count=0;
> #while(Count<100)
> #end
> Best regards,
> Michael
Should I file a bug report?
Message: <web.5257cef730eb22c6e83c0f490@news.povray.org>
Sorry again:
#macro randsign()
   #if (Z1=0) #local Z1=0.1; #end     // avoid division by zero
   Z1/abs(Z1)
#declare Count=0;
#while(Count<100)
Date: 11 Oct 2013 06:19:24
Message: <5257d0ac$1@news.povray.org>
> #macro randsign()
>    1
>   #else
>    -1
>   #end
> #end
It seems you can't do that (IDK why - maybe a bug, or more likely a
"feature" of the parser). In fact you can't even do this:
#macro A()
#if(true)
1
It doesn't like having anything to return inside a #if within a #macro
A solution is to just use a temporary variable:
#macro randsign()
   #local temp = 1;
  #else
   #local temp = -1;
  temp
Date: 11 Oct 2013 06:50:00
Message: <web.5257d79430eb22c6e83c0f490@news.povray.org>
I'm not sure, if it is a bug. May be we both have overlooked something. I wanted
to provide you with a quick workaround.
Best regards,
Michael
Date: 11 Oct 2013 13:23:48
Message: <52583424@news.povray.org>
posfan12 <nomail@nomail> wrote:
> #macro randsign()
>   1
>  #else
>   -1
>  #end
> #end
It's not a bug, but by design (even though it might not be intuitive.)
You have to assign the value you want to "return" from the macro to a
local variable and then have the name of that variable as the last thing
in the macro.
Date: 11 Oct 2013 13:33:07
Message: <52583653$1@news.povray.org>
> have:
> #macro randsign()
>    1
>   #else
>    -1
>   #end
> #end
>   higher."
> reasons.
It may depend on how you call your macro.
You can call it this way:
#declare Var= randsign();
Or edit the macro this way:
#macro randsign()
   1;
  #else
   -1;
and sue it this way:
#declare Val= randsign()
OR, use it in some calculation:
#declare Val= randsign()* Value;
