POV-Ray : Newsgroups : povray.general : POVORAMA database, first rough draft Server Time
25 Nov 2024 19:57:12 EST (-0500)
  POVORAMA database, first rough draft (Message 1 to 6 of 6)
Subject: POVORAMA database, first rough draft
Date: 20 Apr 2013 20:41:38
Message: <517335c2$1@news.povray.org>
Hi(gh)!
As announced, here my first version of a relational database structure
for images on p.b.i:
DATABASE SYSTEM: MySQL (preferably higher than 4.1, allowing subqueries)
TABLES:
images - with the following fields:
- ID (primary key, auto_increment)
- Filename (including path)
- Title
- POVerNick_ID <- table 'povernicks', n:1 relation
- Date (published on p.b.i)
- Format_ID <- table 'formats', n:1 relation
- Size (in bytes)
- Width
- Height
(Number of pixels and aspect ratio can be calculated within MySQL
queries, therefore no explicit field is needed)
- POVVersion <- table 'povversions', n:1 relation
- ImageVersion
- PostProcessed
- (NumColors)
- (AvgBrightness)
- (AvgSaturation)
- (FreqHue0-35)
- (FreqHue36-71)
- (FreqHue72-107) ... (FreqHue324-359)
- (FreqBright0-10)
- (FreqBright11-20) ... (FreqBright91-100)
- (FreqSatur0-10)
- (FreqSatur11-20) .. (FreqSatur91-100)
(the entries for fields given in brackets are to be calculated by an
external utility program)
povernicks (nicknames of POVers)
- Nickname
poverreal (real names of POVers - if known!)
- FirstName
- Surname
povernicks_poverreal (linking table between tables 'povernicks' and
'poverreal', m:n relation)
- POVerNicks_ID <- table 'povernicks'
- POVerReal_ID <- table 'poverreal'
formats
- Extension
- Name
povversions
- Name
keycont1st (content keywords, 1st hierarchy level)
- Name
keycont2nd (content keywords, 2nd hierarchy level)
- Name
- Keycont1st_ID <- table 'keycont1st', n:1 relation
keycont3rd (content keywords, 3rd hierarchy level)
- Name
- Keycont2nd_ID <- table 'keycont2nd', n:1 relation
keycont (content keywords, base level)
- Name
- Keycont3rd_ID <- table 'keycont3rd, n:1 relation
images_keycont (linking table between tables 'images' and 'keycont', m:n
relation)
- Images_ID <- table 'images'
- Keycont_ID <- table 'keycont'
keypov (POV features keywords)
- Name
images_keypov (linking table between tables 'images' and 'keypov', m:n
relation)
- KeyPOV_ID <- table 'keypov'
scripts (scene files, include files)
- Type (main script vs. include)
- Size (in bytes)
- NumLines
images_scripts (linking table between tables 'images' and 'scripts', m:n
relation)
- Scripts_ID <- table 'scripts'
externalfiles (any non-script file used for the calculation of the
scene, such as textures, heightfields, bumpmaps...)
- Type
- Size (in bytes)
images_externalfiles (linking table between tables 'images' and
'externalfiles', m:n relation)
- Externalfiles_ID <- table 'externalfiles'
addsoftware (additionally used software, i. e. modellers,
post-processing tools, script generators etc.)
- ID (primary key, auto increment)
- Name
- Link (to download, if freeware/OpenSource)
images_addsoftware (linking table between tables 'images' and
'addsoftware', m:n relation)
- AddSoftware_ID <- table 'addsoftware'
See you in Khyberspace!
Yadgar
Subject: Re: POVORAMA database, first rough draft
Date: 21 Apr 2013 02:57:06
Message: <51738dc2$1@news.povray.org>
Le 21/04/2013 02:41, Jörg 'Yadgar' Bleimann nous fit lire :
> Hi(gh)!
> TABLES:
Do you have a picture of it (just with table's names ?)
(indeed, the relational schema would be better, before projection in table)
Date: 22 Apr 2013 05:24:13
Message: <517501bd$1@news.povray.org>
Hi(gh)!
Voilà:
(see p.b.i)
Yadgar
Date: 22 Apr 2013 07:55:55
Message: <5175254b$1@news.povray.org>
Looks ok so far. In the images table would it be a good idea to have a
reference to the original p.b.i thread (message ID or http link or
something?).
Should be quite easy to write some code that would trawl p.b.i and
populate the tables (at least most of it, apart from the keywords).
You'd then need something else running that continuously monitors posts
to p.b.i and indexes them in real time.
Date: 22 Apr 2013 14:27:52
Message: <51758128$1@news.povray.org>
Hi(gh)!
> something?).
This would be a simple attribute, not a table on its own!
I don't know how to write code to automatically scan a newsgroup...
Yadgar
Date: 23 Apr 2013 05:16:42
Message: <5176517a$1@news.povray.org>
>> something?).
Yes sorry I didn't mean reference as in a databased reference.
Nor do I, but I doubt the nntp client protocol is particularly taxing to
implement. Just thought it would save a lot of manual work.
