POV-Ray : Newsgroups : povray.general : Example no longer renders Server Time
10 Oct 2025 07:36:56 EDT (-0400)
  Example no longer renders (Message 1 to 3 of 3)
Subject: Example no longer renders
Date: 12 Mar 2013 10:36:44
Message: <513f3d7c$1@news.povray.org>
I just tried to render this (old?) example scene in the newest 3.7 RC7:
	http://www.oyonale.com/modeles.php?page=40
However, I get a completely black image.
It works fine if I turn radiosity off. I notice that when you turn
radiosity on, the scene has no light sources... but it renders fine in
POV-Ray 3.6.
Is this a bug in 3.7?
Timwi
Subject: Re: Example no longer renders
Date: 12 Mar 2013 11:34:46
Message: <513f4b16$1@news.povray.org>
Am 12.03.2013 15:36, schrieb Timwi:
> POV-Ray 3.6.
No, it's actually a feature. (And I'm not kidding.)
3.7 introduces a major change to the "ambient" mechanism, with the goal
of making it easier to use one and the same material definition for both
non-radiosity and radiosity renders.
The "ambient" term is now reserved for modeling ambient light reflected
diffusely by the respective material - which is exactly what radiosity
does (albeit at a much more sophisticated level), so the "ambient"
mechanism is disabled when radiosity is enabled.
For modeling materials that emit light by themselves, a new "emission"
term has been added to the finish block instead. This is enabled in both
non-radiosity and radiosity renders, and is also independent of the
global ambient_light setting.
Of course we're aware that using the "ambient" mechanism for what is now
catered to by the "emission" mechanism has been ubiquitous, and that
this change would break plenty of existing scenes, if it wasn't for a
backdoor we're providing: If "#version 3.6" (or anything lower than 3.7)
is specified, the "ambient" mechanism remains enabled in radiosity
renders as well.
Obviously this backdoor only works if the scene in question has a
corresponding "#version" statement. Unfortunately Gilles' scene does not.
So you have two options for fixing the scene:
(a) Place a "#version 3.6;" statement at the beginning of the .pov file;
this is what I'd recommend if you just want to render the scene and
maybe toy around with it a little.
(b) Replace all occurrences of "ambient" with "emission" (and, if
applicable, multiply the respective parameter by whatever value is
specified as "ambient_light"); this is what I'd recommend if you intend
to use the scene as a basis for some work of your own, to be sure all
the bells & whistles of 3.7 work as they should. (The "ambient"
behaviour is not the only thing that depends on the #version setting,
although most of the other stuff is more subtle.)
Date: 15 Mar 2013 11:33:35
Message: <51433f4f$1@news.povray.org>
Wow, thanks for the detailed explanation!
Timwi
