POV-Ray : Newsgroups : povray.general : Solid from bicubic_patch Server Time
17 May 2026 01:25:02 EDT (-0400)
  Solid from bicubic_patch (Message 1 to 2 of 2)
Subject: Solid from bicubic_patch
Date: 25 Feb 2013 16:31:33
Message: <512bd835@news.povray.org>
Is there any way to generate a solid with a well-defined interior from a
bicubic patch?
Preferably from a set of patches that match up perfectly, but would be
What I actually want is a glassy object (i.e. with refraction and IOR)
whose surface is defined by bicubic patches. If this is not possible the
/looks/ like this?
Timwi
Subject: Re: Solid from bicubic_patch
Date: 25 Feb 2013 17:07:22
Message: <512be09a$1@news.povray.org>
> bicubic patch?
> /looks/ like this?
> Timwi
The ior effect is evaluated only at the surface. The same goes for the
dispersion. Colour fading within an object is evaluated between the
entry point and exit point. What lies between don't mather.
If your bicubic_patch form a reasonably closed shape, it can be
considered as "solid". It's solid in the sense that it can have an
interior where you define an ior, some dispersion and colour fading.
You may also apply sone media, but I'm not sure that it will behave
correctly. Some testing is needed.
The same can be done with an union of triangles.
