POV-Ray : Newsgroups : povray.general : Layering detail textures Server Time
10 Nov 2026 18:35:17 EST (-0500)
  Layering detail textures (Message 1 to 12 of 12)
Subject: Layering detail textures
Date: 9 Oct 2012 05:15:01
Message: <web.5073e9f7dae1fbb2d97ee2b90@news.povray.org>
I have a prop object I just finished creating, it is built from individually
textured elements.
what I'd like to do is add detail textures to the whole thing, based on image
maps, but I can't figure out how to make it work.
Any help on this would be appreciated.. I'd post code, but I'd like to debut the
finished object as a whole.
A.D.B.
Subject: Re: Layering detail textures
Date: 9 Oct 2012 07:18:19
Message: <507407fb$1@news.povray.org>
> individually textured elements.
> on image maps, but I can't figure out how to make it work.
   You mean layering transparent textures onto the textured CSG isn't
working? ...I don't remember ever trying something like that, but my
"POV-Ray instinct" tells me it should work (well, perhaps with some
workaround).
Jaime
Date: 9 Oct 2012 16:06:15
Message: <507483b7$1@news.povray.org>
> textured elements.
IIRC you cannot override (or add to) textures of subcomponents. If you
wish to layer textures you need to apply all textures on the same level.
In some situations this forces you to a less elegant solution.
Date: 9 Oct 2012 16:10:01
Message: <web.5074848c207c714ed97ee2b90@news.povray.org>
> workaround).
> Jaime
it is not working.  The texture shows up on the untextured surfaces (such as
clipping surfaces from differences and intersections) but not on the textured
surfaces.
A quick search shows a post from 2008 requesting extension of the texturing
system to allow overlays:
http://news.povray.org/povray.pov4.discussion.general/thread/%3Cweb.4799def8e1857b77c150d4c10%40news.povray.org%3E/
apparently you can only layer textures over previously textured objects if the
object in question is a single primitive.
This makes it nearly impossible - or, at least, unnecessarily dificult - to do
complex textures on csg objects.
Correct me if I'm wrong.
A.D.B.
Date: 9 Oct 2012 21:20:21
Message: <5074cd55@news.povray.org>
> textured elements.
> Regards,
> A.D.B.
No individualy textured CSG component can ever receive any texturing
applied to the whole SCG. Any pigment, texture, finish, interior, normal
or material applied to a SCG object affect only the untextured
components. This allow you to have a main texture, then, add individual
textures as needed to specific elements. It's by design.
If you want to apply some overlay texture to individualy textured
component, you need to apply that overlay texture as a layered texture
over the existing texture of each textured component.
Date: 9 Oct 2012 22:25:01
Message: <web.5074dc38207c714ed97ee2b90@news.povray.org>
> > textured elements.
> > Regards,
> > A.D.B.
> Alain
The reason the elements are individually textured is that, though they may use
the same texture, the orientation of that texture is important w/r/t the
individual object, and cannot be placed on the whole model.
The problem is that I want to apply a series of overlays to the object as a
whole, to simulate the effects of age, decals, spray-paint etc...  doing this to
individual objects would make the csg ten times as complicated - making it
impossible for me to construct the object procedurally, and use different
overlays for different situations - and involve complex transformations of
textures on the micro-level.
I've tried turning the image maps into isosurfaces and differencing them from
the object, but that's not working either because of sharp edges.
the only other things I can think of is constructing them as csg objects, which
would be tedious if not impossible, or "spraying" them on as microscopic
particles using trace and eval_pigment...
A.D.B.
Date: 10 Oct 2012 03:21:04
Message: <507521e0$1@news.povray.org>
Depending on how complex your CSG is, it might be possible to make a
copy of the whole CSG object (without textures) and make it marginally
larger than the original. Then you can apply a mainly transparent
texture with your decals applied.
It's not an ideal solution though, I've come up against that before when
making a wooden table where the top was made up of several different
bits of wood. In my case it was easy to add an additional transparent
object just above the surface, but in general it's not always that easy.
Personally I think it's counter-intuitive that a "texture" statement at
a higher level wouldn't act on *all* lower level objects (obviously
making them redundant if totally opaque). If I apply a translate, rotate
etc it acts on the whole thing, not only on sub-objects that haven't
been translated/rotated already.
If needed there should be a special flag to say "don't apply this
texture to sub-objects that are already textured".
Date: 10 Oct 2012 03:45:32
Message: <5075279c$1@news.povray.org>
>> may use
I actually don't mind the idea of a spray-paint macro - other than the
shear number of objects involved - it seems as though it would provide
an ideal way to apply certain textures, like stencilled lettering.
Where a texture overlay might wrap around objects, the spray-paint
method would not, it would only cover front surfaces.
I've been thinking that, if I limit the sprayer to a single color, and
union all the particles to be textured as a set, it would be more efficient.
I also have ideas for allowing the use of a spline as a pattern, rather
than an image, but I'd like to get it working for images first (black
and white only, for now)
suggestions are welcome.
A.D.B.
Date: 10 Oct 2012 17:45:51
Message: <5075ec8f$1@news.povray.org>
I agree it is inconvient and not very elegant, but usually it is
still possible. Basically you could turn your procedurally created
objects into macros that takes an array of textures as input, then
you can create instances with correctly layered textures for all
CSG objects you need them in.
I added a feature request in the bug tracker so the issue
doesn't get lost. It does pop up from time to time.
http://bugs.povray.org/task/256
Date: 10 Oct 2012 18:10:01
Message: <web.5075f172207c714ed97ee2b90@news.povray.org>
Thanks
ITMT, I am going to try writing a spray-paint macro.
A.D.B.
Date: 11 Oct 2012 03:24:15
Message: <5076741f$1@news.povray.org>
That is a good idea. There should indeed be provision for this kind of
feature.
Date: 12 Oct 2012 12:25:01
Message: <web.5078441f207c714e4b0aa1fd0@news.povray.org>
The texture transformations needn't be complex, internally POV represents them
as just a matrix. You just need to know the transformation for your object, then
you can do transform { ... inverse }.
For example if you're doing a recursive object, just keep track of the
transform:
#macro Object(ParentTransform)
   #local ObjectToParent = transform { rotate 20 scale .2 translate .1*y };
   #local ObjectToWorld = transform { ParentTransform ObjectToParent };
   object {
      TheObject
      texture { LocalTexture }
      texture { GlobalTexture transform { ObjectToWorld inverse } }
      transform { MyTransform }
   // recurse
   Object(ObjectToWorld)
But I agree it would be much nicer if POV could provide a more general solution
for handling layered textures (I'm always annoyed that it doesn't let you layer
over a texture_map).
